From Overhaul to Overkill. The Ballad of a TJ - Page 2 - JeepForum.com
post #16 of 732 Old 03-16-2013, 05:02 PM Thread Starter
AndyE
I like that you have an open mind. Also don't forget.... 16 JJ's is like $800 so almost ALL the cost of a set of short arms is in the joints. Scary huh! You don't want to regret the joint choice. I just don't think you will going with the MC.
Actually I think you only get 14... but whatever... they expensive when you buy a bunch.
Wow. Guess I never really figured they were that expensive in mass. Regretting is something I defiantly don't want to do, considering the amount of money involved. Lots of thinking to be done. On the issue of track bars, ran the numbers for stock replacements from a site like Quadratec. $140 for both before shipping. Currie TB's from say Savvy are $638 for both without the discount and before shipping. Thats a savings of $489! That would cover the cost of my Currie steering or the cost of a set of Savvy half doors. Interesting...
Build Thread
AndyE is offline
post #17 of 732 Old 03-16-2013, 05:25 PM
gst95dsm
Chop, Wheel and Rebuild..
gst95dsm's Avatar
Haha, Currie steering is a very worthwhile mod, One I should have done a while ago. My only steering upgrade is a big daddy tie rod. which has served me very well @ $89, and is BEEF compared to a stock tie rod that I bent and bent back and bent again several times. What I worry about is the stock Tie rod ends now. I've never broke one but they look puny. The savvy half doors are PIMP, but I would only even consider them if you can use them more than half the year and even at that you really are only buying them cause they're cool....... and that is FINE!
gst95dsm is offline
post #18 of 732 Old 03-16-2013, 06:01 PM Thread Starter
AndyE
It was tough pulling the trigger on the Currie steering because of the price. But after watching videos of guys popping the stock tie rod like a twig, I figured it would be a worth while investment. Nice to hear the Big Daddy tie rod worked out for ya. I looked at the ZJ and a few aftermarket tie rods, but figured if I'm going to upgrade one I might as well do the other. The Savvy half doors are defiantly PIMP! I've had my eye on them since they came out, just haven't had an excuse to buy them. We'll see how this summer goes.
Build Thread
AndyE is offline
post #19 of 732 Old 03-16-2013, 10:49 PM Thread Starter
AndyE
Jeep thoughts of the day:
I've been continuing to think on the other parts of phase 2, namely sway bar end links, shocks, and brakes. For the brakes I'm thinking one of the kits from Black Magic brakes that covers the front and rear. For the sway bar end links I'm thinking basic extended links from BDS. Simple and cheap, they should correct my sway bar geometry without putting me so deep in the hole I won't want to change to something better later. As for shocks, I'm thinking Bilstein. Not sure what size to go with since 2.5" is kind of a middle ground in terms of their sizes. I'll probably shoot the Bilstein vendor here on the forum a pm and see what he recommends.
Some days I hate trying to do this right.
Build Thread
AndyE is offline
post #20 of 732 Old 03-17-2013, 12:55 AM
gst95dsm
gst95dsm's Avatar
Me again.... haha! Hey on the shocks. Only YOU, can pick the right ones out, and it's going to take some homework, measuring up travel, down travel, available droop, and spring extended length will play a part in picking the right shock length. So don't just go with X shock is good for this or that amount of lift. I know personally it took me hours to find a specific shock that was perfect length. Anyways you may already have been thinking along these lines and if so please disregard, but most people are not running the correct length shocks and don't even know it. Or they are close enough and just don't care. You'll want the longest shock body you can run (compressed length basically) for the amount of up travel you want but no more extended length than your coils will allow (until they unseat). I guess what I'm trying to say is that yes Bilstein is a great shock.... but they might not even make one that's the right size for you. Maybe close enough though. If mine were even a 1/2" longer or shorter in the front, there would be issues though. So it can be that close.
gst95dsm is offline
post #21 of 732 Old 03-17-2013, 02:52 PM Thread Starter
AndyE
Yea, I figured it might turn into that. I did plan on cross checking any recommendations I got to make sure they would actually work for me. But it sounds like my best bet is to get some measurements and start from scratch. Well, Funny story. The only reason I want to change shocks is because my current ones are the wrong size. While I don't mind how the 2.2s ride, I have maybe 2" of up travel in the rear. While not a big deal on the road, I've bottomed out the shocks way to many times off road. So I'm hoping to switch to something with better up travel. I hope Bilsteins will work, but I guess I'll have to keep an open mind. Hopefully tomorrow is warmer and less windy so I can go out and cycle the suspension. I need to figure out how much bump stop extension I need as well.
Build Thread
AndyE is offline
post #22 of 732 Old 03-18-2013, 01:03 AM Thread Starter
AndyE
Had a weird, random thought. Since the lower front control arms control caster, and aftermarket adjustable control arms don't use the stock method to adjust caster. Can any shop do an alignment? Do you have to find a shop that specializes in 4X4s with aftermarket parts? Or is it a case by case kind of thing? Gotta love the small details.
Build Thread
AndyE is offline
post #23 of 732 Old 03-18-2013, 09:01 AM
KateKGB
From what I have been told they can do the toe and the camber but I believe the tech said that the caster is set into the knuckle already. The values weren't that off from the specs- so I haven't thought much of it.
Ill be ordering my parts today- hopefully they get here by this weekend.
'05 Unlimited Rubicon - Sahara Edition #431
We are the diamonds that choose to stay coal
A generation born, to witness the end of the world
KateKGB is offline
post #24 of 732 Old 03-18-2013, 10:22 AM
gst95dsm
gst95dsm's Avatar
I was under the assumption that only the toe was adjustable, and the cam bolts were simply to account for axle "squareness" and not any significant change in caster. Camber is non adjustable, unless you get offset balljoints to account for bent C's.
Basically after you get to the point of aftermarket adjustable Control arms, you're going to want to be able to take the, wheelbase measurements, caster measurements (that directly translate into pinion angle) and axle squareness measurements yourself. Most people even set their toe..... I suck at setting my toe and still pay the money to have it done. I also have to measure from about 10 different places before I am confident in a squareness measurement. Haha.... This is an area I'm working on myself.
To answer your question though.... YES i'm sure some competent 4x4 shop can do the job... I just don't know of any around me that I'd trust to do it without having to explain things to the point that I should just do it myself.
gst95dsm is offline
post #25 of 732 Old 03-18-2013, 01:34 PM Thread Starter
AndyE
In all honesty I might be talking out my *** in regards to caster adjustment. I could have sworn I read that the lower control arms adjusted it. But I sometimes have the bad habit of reading one thing and remembering it the complete opposite. Well it sounds like I need to stop being lazy and break out the tape measure and a write up. With that said however, there is supposed to be a pretty good shop that specializes in Jeep modifications just down the road. Might have to go check them out.
Hell yea! Hope they make it in time.
Build Thread
AndyE is offline
post #26 of 732 Old 03-18-2013, 01:52 PM
redrelyt12
Always nice to join Jeepers in CT. Too bad there isn't a lot for legal offroading, but I'll be creeping your build from now on.
I never make the same mistake twice - it's more like three or four times.
Build - http://www.jeepforum.com/forum/f22/unlimicon-build-1477723/
redrelyt12 is offline
post #27 of 732 Old 03-18-2013, 02:05 PM
KateKGB
Me too. With the logistical luck I have had recently- I fully expect them to be here by weekend. Should be fun!
We should all meet up sometime in the near future. CT is a small state- I am sure it wouldn't be too hard to find somewhere between us to grab dinner or something and plot the demise of our checking accounts.
KateKGB is offline
post #28 of 732 Old 03-18-2013, 04:12 PM Thread Starter
AndyE
Welcome! It's defiantly nice to see others on here from CT. I hear you on the offroading. It's my biggest beef with CT, especially coming from CA.
If you bought from ECGS and Rock Auto you should be good.
That would be interesting for sure; getting together and crashing one of the upcoming Jeep events here in CT or Mass would be fun as well.
Build Thread
AndyE is offline
post #29 of 732 Old 03-18-2013, 05:07 PM Thread Starter
AndyE
Something Jeep for the Day:
No real thoughts for the day. But some goodies did show up in the mail.
Should keep me occupied while I'm dropping the Cosby Kids off at the pool.
Build Thread
AndyE is offline
post #30 of 732 Old 03-18-2013, 05:20 PM
KateKGB
I ended up going with 4wd, best prices and customer service - and I also ordered the new soft top from them
I'll definitely plan to be down in Groton this weekend if you are up for it. Even if my stuff isn't in yet. Its just a hop and a skip around one of the worst highway systems in america gives my Bilsteins a workout. Lol.
KateKGB is offline
