Oscar the TJ gets a CUMMINS - Page 8 - JeepForum.com
post #106 of 545 Old 08-12-2012, 07:23 PM
Cowboyup94
Originally Posted by 10-3-TJ View Post
I think i am going to cut the body channel out from the bottom and drill the spot welds. Replace the damage. I am not going to start that until the cummins is in and running.
Before I ask my 2 questions I must first say you are doing something I really love and have always wanted to do. I almost bought a TJ with a 4bt already in but decided I couldnt drive someone elses art work. EXCELLENT JOB!
First question: With half the body lift in isn't that going to make it challenging to allign everything? I have done swaps in muscle cars, compacts, and trucks and I know doing them your pushing and prying to fit it sometimes.
second question: How are you running the exhaust? I'm know expert in 4Bt's in Jeeps so I don't know what you can fit and what you can't, so I guess the second part of my question is what are your restrictions?
Sorry for the long post I just like to learn
JEEP
Just Emptying Every Pocket
Cowboyup94 is offline
post #107 of 545 Old 08-12-2012, 11:19 PM
tdij
I can't imagine Oscar would drive anything but a diesel.
Great start to a grouchy build. I like your attention to detail.
Wish I would have had the time to really pay attention to the little stuff when I did mine. Maybe I'll paint the next engine I put in mine. I have had so many fluid leaks in my build that I would have been very grouchy if I would have really cleaned mine up and then coated it in every fluid the jeep has.
Really like that you'll be able to run stock gauges. That is awesome!
I'll be watching this one!
Welcome to the oil burner club!
BOBCAT: TDI powered YJ
tdij is offline
post #108 of 545 Old 08-13-2012, 06:09 PM Thread Starter
10-3-TJ
Okay, today I got a lot done.
First Cowboyup94 ask as many questions as you can think of. Doesnt bother me at all. I wanted this thread to be instructional and convince normal everyday guys that they can do this swap. You were absolutely correct when you asked about finishing the Jeep with half the body lift in. I thought about it all night and after sleeping on it I finished the body lift today. I was able to salvage a bolt which i thought was a gonner, so only two bolts broke and are needing repair. The Jeep now sits one inch higher everywhere Good Advice sir!!
Second question was about the exhaust. Jeff daniels sells an entire stainless steel exahust for folks who have inspections or want the stock look. However I am planning on running 2.5 steel pipe out of the turbo down to approxmiately the oil pan where it will turn 90 degrees and expand to a 4 inch pipe and exit from my fender. The 4 inch pipe will run through the battery box support and then exit. After exiting the fender the pipe will run straight up as a stack and then have a 45 degree bend to the rear and side at the top. It will look very similiar to Garrets Diesel Jeep. search Garrets diesel jeep on youtube and thats what it will look like, only I am going to do either black chrome or powder coat flat black.
Now the legallity of the exhaust is simple... its not.. I am willing to take my chances. Its gonna be loud and smokey..just how a diesel should be.
"We have enough youth, how about a fountain of smart"
"Look no further than yourself, for all of the good and all of the evil that exist in this world, resides in the heart of man and his propensity to use it".
10-3-TJ is offline
post #109 of 545 Old 08-13-2012, 06:28 PM Thread Starter
10-3-TJ
On to the updates. I got the bellhousing all bolted up. It didnt go as smoothly as one would think. The top bolts were being obstructed by the transmisson by about 1/8th of a inch. I used a dremel with a stone grinder to make access easier. Its wasnt hard just awkard postions.
After that i moved onto the cutting out the stock engine mounts. Passenger side was easy. Easy to get my grinder in with a cut off wheel.
The last picture is showing how bad the jeep welds were. Literally the welds broke from the frame. If you closley you can even see all the holes in the welds..
Well what the passenger side lacked in strength the drivers side made up for.. i beat the drivers side like a red headed step child until it finally gave up.
Now i still have to grind the old welds and clean the frame rails
10-3-TJ is offline
post #110 of 545 Old 08-13-2012, 06:42 PM Thread Starter
10-3-TJ
Here are some more pictures of how the jeep sets now with the inch body lift. I like how it looks. Please disregard the junky soft top. I typically only use the actaul top and not the windows but it has been raining and i am tired of working under a dripping jeep from the floor boards filling with water.
Now onto the part i honestly hate. So i must fix the body mount bolts which broke and the offending captured nuts. Well i broke down and bought a very nice air saw from Chicago Pneumatic . The next picture shows how i going to fix the damage. I am taking a different approach. I am going to go in from the bottom, cut the rail out and weld it back.. easier said than done.
Notice the rust holes to the top right of the rail. Yup gonna cut that also. Now a little back ground on this body rail junk. I replaced a 18 inches or so of the passenger side. I went in through the top cut out my floors and made a body rail. Then removed ALL the body bolts and put anti seize on them because i knew the body lift was coming.. At that point all the bolts came out and everything was great. So i prepped and raptor lined the entire tub. It looks great and i am so happy with it.
Now comes yesterday and the bolts break. I wish this would have happened last year when i had the passenger side cut out. That side turned out great.
10-3-TJ is offline
post #111 of 545 Old 08-13-2012, 11:14 PM
Beowill
Coming along nicely!
Not all those who wander are lost - J.R.R. Tolkien
My LJ Cummins 4BT with 1 Ton's Build:
Beowill is offline
post #112 of 545 Old 08-14-2012, 12:20 PM
Largo1024
Ok, since legallity of the exhaust has been mentioned. What about this whole swap? I'm in cook county illinois, no inspection but biannual emissions test for OBD2 vehicles.
Largo1024 is offline
post #113 of 545 Old 08-14-2012, 02:33 PM Thread Starter
10-3-TJ
It will vary state to state what you can and cant do legally .
I suggest going to 4btswaps.com and search there. The topic of whats legal for swaps is covered numerous times there.
In ohio all i have to do is re-register the jeep as diesel. Thankfully we got rid of the awesome E-check like 10 years ago..
10-3-TJ is offline
post #114 of 545 Old 08-14-2012, 03:08 PM Thread Starter
10-3-TJ
I just got off the phone with the BMV and the receptionist stated that the title will be listed as mileage ( not actual ) and engine type DIESEL. I am not worried about the title being listed as Not Actual because if on the slim chance I ever part with the Jeep I will direct the buyer to this thread..
Thanks for the comments and questions guys keep em coming.
More update hopefullly tonight. I am headed to the garage right now. gonna try to set the engine in and weld the motor mounts.
10-3-TJ is offline
post #115 of 545 Old 08-14-2012, 09:31 PM Thread Starter
10-3-TJ
Let the updates roll
Today i didnt get started until early evening and truly thought the days was a waste.. i started by grinding down the old motor mount welds
Then added some zinc weld through primer.
Click image for larger version
10-3-TJ is offline
post #116 of 545 Old 08-14-2012, 09:39 PM
Cowboyup94
Last exhaust question from me, Is it at all possible to do a hood stack type of ordeal? My dad's F250 was tight but it's possible. So assuming the tightness I am guessing not?
Bet you can't wait to roll coal!
JEEP
post #117 of 545 Old 08-14-2012, 09:43 PM Thread Starter
10-3-TJ
After that i decided that it was time for motor mounts. So i pushed the jeep in my garage and started the test fitting.
Surprisingly the engine fits very well with only minor problems with clearances . The high mount turbo fits great and will not cause any problems with the hood.
I have two clearance issues. First is the starter on the upper control arm ob the passenger side. This problem was mentioned by another guy here also.
Second problem i see is the slave cylinder and the front drive shaft.
Just another pic showing how the hood will clear.
I did not get the motor mounts in or even measured. I will do that tomorrow morning. But at least its temporarily bolted to the tranny.
10-3-TJ is offline
post #118 of 545 Old 08-14-2012, 09:49 PM Thread Starter
10-3-TJ
Cowboyup94.
There us a guy on youtube running a 5.9 6BT in a YJ with a hood stack. Runs straight through the hood.
I just dont know how he opens the hood!
To be very honest it would be less work and easier for me to run the exhuast out of the hood but its just not what i want. There is plenty of room in there surprisingly .
10-3-TJ is offline
post #119 of 545 Old 08-14-2012, 09:53 PM Thread Starter
10-3-TJ
I forgot mention that if it appears that the engine isnt sitting on straight. Its because it isnt. The drivers side is sitting lower just because it has no motor mounts and is supported by the hoist and only two tranny bolts.. just fyi. I didnt realize it looked so off until i looked at the pics on jeepforum.
10-3-TJ is offline
post #120 of 545 Old 08-14-2012, 10:01 PM
cycleguy04
One inch? Is that all? Do you plan on cutting the tub at all?
'98 Wrangler Sahara - SOLD
'91 Ranger XLT 2WD - 4.0 V6, A4"hell"D, contemplating twin turbo 5.3
'79 C10 Big Ten 2WD - 350, TH350, contemplating rebuilding to 355ci with supercharger and programmable EFI
'12 Subaru Forester (AKA: Arctic Cat) - 2.5, non-CVT, wife's, still begging her to let me get an exhaust system
'01 SV650 - snorkelectomy, ebay slip-on, cam swap and re-jet in the near future
cycleguy04 is offline
4bt , cummins , tj
Diesel Cummins 4BT TJ doc_dyer Jeep Builds 174 12-29-2013 04:10 PM
Show me your Cummins! Ptr Jeep Picture Requests 37 09-03-2013 02:37 PM
Cummins 4BT YJ TimP Jeep Builds 5 10-25-2011 04:11 PM
looking for used 4bt cummins engine bobbyp10 Jeep Builds 3 03-02-2010 01:51 PM
Cummins Diesel ralf Jeep Builds 6 03-02-2010 09:44 AM
