Oscar the TJ gets a CUMMINS - Page 5 - JeepForum.com
post #61 of 544 Old 08-03-2012, 04:21 PM
cycleguy04
Yessss!!! Finally, somebody who is doing the same thing I am! Subscribed!
I will have many questions and input, but right now I am at work.
'98 Wrangler Sahara - SOLD
'91 Ranger XLT 2WD - 4.0 V6, A4"hell"D, contemplating twin turbo 5.3
'79 C10 Big Ten 2WD - 350, TH350, contemplating rebuilding to 355ci with supercharger and programmable EFI
'12 Subaru Forester (AKA: Arctic Cat) - 2.5, non-CVT, wife's, still begging her to let me get an exhaust system
'01 SV650 - snorkelectomy, ebay slip-on, cam swap and re-jet in the near future
cycleguy04 is offline
post #62 of 544 Old 08-03-2012, 05:44 PM
cycleguy04
Originally Posted by 10-3-TJ View Post
Well while i am waiting for my turbo to soak in my mystery solution i started on the crankshaft sensor and cam shaft sensor. Both of these will allow me to use my stock tach.
Attachment 441745
Attachment 441747
Now that's cool!
post #63 of 544 Old 08-03-2012, 06:00 PM
cycleguy04
Are you fabbing your own engine mounts? Or are you buying a set? The engine is looking great. Once it's done you've got to get a video posted.
post #64 of 544 Old 08-03-2012, 07:21 PM Thread Starter
10-3-TJ
Cycleguy04. I bought a set of engine mounts from Shawn and Dan from jeff daniels jeep. I will post a picture of them when i get one.. are you doing a build on your cummins? I would love to see it. Thanks for the compliments...
"We have enough youth, how about a fountain of smart"
"Look no further than yourself, for all of the good and all of the evil that exist in this world, resides in the heart of man and his propensity to use it".
10-3-TJ is offline
post #65 of 544 Old 08-03-2012, 07:31 PM Thread Starter
10-3-TJ
Here are three pics from jeff daniels website. My mounts are identical. The mounts will require a trimming but nothing the normal person couldnt handle.
10-3-TJ is offline
post #66 of 544 Old 08-03-2012, 07:46 PM
cycleguy04
I don't have a Cummins yet, but it's in the overall build itinerary. Nice brackets!
post #67 of 544 Old 08-03-2012, 10:31 PM Thread Starter
10-3-TJ
Tonight i had a little extra time and got my oil drain cut, re positioned , welded and painted. It wasnt that hard. My welds arent anything to write home home about but they will hold.. then cleaned my aluminium turbo side and painted it with VHT aluminum color paint. Looks great.
10-3-TJ is offline
post #68 of 544 Old 08-04-2012, 08:47 AM
terpsmandan
2009 JK Wrangler
terpsmandan is offline
post #69 of 544 Old 08-04-2012, 01:10 PM
ssquier92
subscribed!!
2002 TJ 3.25" RC lift, 1.25 BL, MML, 33X12.50 Goodyear MTR w/ Kevlar, adjustable front trac bar, cut stock bumper, poison hood louver, B&M short shifter, chromoly rear axle shafts in the d44 4.88s Grizzly locker, Aussie locker up front in d30,10,500lb winch w/ synthetic rope, antirock, jcr sliders, savvy arms
Work harder, thousands of people on welfare are counting on you.
ssquier92 is offline
post #70 of 544 Old 08-04-2012, 06:43 PM
jeepjoe4
work faster
jeepjoe4 is offline
post #71 of 544 Old 08-05-2012, 01:31 PM
SHAKEnBLAKE
Wow, that hard top looks 100x better with a coat of paint!
Looks like you're taking your time to get this thing running right. You'll be happy with the final product!
Ohio4x4.com
SHAKEnBLAKE is offline
post #72 of 544 Old 08-05-2012, 02:16 PM Thread Starter
10-3-TJ
I agree the hardtop looks a lot better. It took some prep though.. there was so much wax on that s.o.b. it took me a whole day and a complete bottle of prep cleaner to get it clean. Then three coats of satin black.
Thanks for the compliments fella's I i will have more updates tomorrow afternoon.
10-3-TJ is offline
post #73 of 544 Old 08-05-2012, 07:58 PM
papitt
.. I know I'm late but sometimes on a stuck bolt or a rusty bolt Heat up the area as much as you dare.. And stick a birthday candle to it let the wax migrate into the pours .. It'll work when other penetrates don't. ''SOMETIMES''.
... Good job on that weld on the manifold. I have a 4BT in my 1972 Bronco and lover it . I'm in Texas and I do not even run a fan .. It stays about 170 or so. If I'm stopped idling in the pasture Then I do have a cooling fan I can switch on .. Even in 100+ temps it'll cool it right down to 140 or so. I only use mine in the country checking cows an hunting around in the pasture so I'm in 4 wheel drive about 50% of the time .. My Mileage is only about 15 .. But that is so much better than the 4 mpg on gas and overheating in 20 minutes too 250+.
... You'll like it I'm sure.
papitt is offline
post #74 of 544 Old 08-05-2012, 08:28 PM Thread Starter
10-3-TJ
PAPITT,
Thanks for the candle idea. I havent heard of that one. I am sure there will be more than one bolt on the jeep that wont want to come out.
Do you have any pictures of your Bronco. My parents had a 79 Bronco that they GAVE away because the rust wat sooo bad. To bad at the time i didnt care about the Bronco.
I plan on running either an electric fan like the ford tarus fan or a fixed fan to the motor.
Any suggestions on fan choice i am all open to ideas.
Everyone i need help tracking down a used YJ arb snorkel. I really dobt want to spend 400 bucks on a new one.
10-3-TJ is offline
post #75 of 544 Old 08-05-2012, 09:54 PM
papitt
Back when I was building this bronco I worked at a Chrysler Stealership. So I got lot of pull offs .. My Cooling fan is off a PT/Cruiser . It fits my radiator perfect . It was one that was pulling too much amp-ridge, But I just installed it with a larger fuse and it has ran for 2 years .. Those were good square cooling fans about 17 in or so . and I really think they have a 2 speed fan on them . Most of the times only one side of the fan was bad.
papitt is offline
4bt , cummins , tj
Diesel Cummins 4BT TJ doc_dyer Jeep Builds 174 12-29-2013 04:10 PM
Show me your Cummins! Ptr Jeep Picture Requests 37 09-03-2013 02:37 PM
Cummins 4BT YJ TimP Jeep Builds 5 10-25-2011 04:11 PM
looking for used 4bt cummins engine bobbyp10 Jeep Builds 3 03-02-2010 01:51 PM
Cummins Diesel ralf Jeep Builds 6 03-02-2010 09:44 AM
