Oscar the TJ gets a CUMMINS - Page 30 - JeepForum.com
post #436 of 544 Old 07-08-2013, 08:45 PM Thread Starter
10-3-TJ
Propjockey,
Thanks man.. you will love your jeep in a whole new way. There is nothing better than diesel fumes, turbo whistle and the raw torque and knowing you did it yourself..
I so badly want to get an old 12vavle cummins and put it in a 70's ford 4x4.
"We have enough youth, how about a fountain of smart"
"Look no further than yourself, for all of the good and all of the evil that exist in this world, resides in the heart of man and his propensity to use it".
10-3-TJ is offline
post #437 of 544 Old 07-08-2013, 09:02 PM
propjockey2002
Originally Posted by 10-3-TJ View Post
Propjockey,
I'm really interested in what your mpg turns out to be. The initial numbers sounded great.
My build
propjockey2002 is offline
post #438 of 544 Old 07-10-2013, 01:33 PM Thread Starter
10-3-TJ
Propjockey
I do believe that I can get a few more mpg when I go to larger tires. I am thinking 35 or 37 which will lower the Rpms quite a bit. Which will make freeway driving better. I have read that the Cummins like to hang around 1800 Rpm on the freeway.
As you guys already know I am running a front Dana 30 . If I run the synergy heavy duty ball joints and maybe add a truss so you think it would be reliable with 37s?
10-3-TJ is offline
post #439 of 544 Old 07-10-2013, 01:47 PM
propjockey2002
Propjockey
Beautiful! Keep me posted. On 60'a it shouldn't be a problem.
My build
post #440 of 544 Old 07-10-2013, 04:20 PM
Luke95
Propjockey
Be smart and yes it will.
But sleeve it truss it an gusset the cs
I <3 rockrash
5.2 ZJ Pushing a dana 30 as far as it will go.
Luke95 is offline
post #441 of 544 Old 07-10-2013, 04:41 PM
propjockey2002
I <3 rockrash
I'm sorry. I read Dana 60.
My build
post #442 of 544 Old 07-10-2013, 05:55 PM
ThomasYJ
for wheeling 37s, you'd be pushing your luck on that 30. Even with upgraded shafts and u joints, does that not make your ring gear one of the weak spots? FWIW, I know for YJ types the HP D44 out of a '77-79 f250 is a common upgrade. Guys who aren't going full width get the tubes cut to waggy width and use those size shafts. Maybe something worth looking into, as far as adding spring buckets etc.
just throwing it out there
The Toy:93 YJ
The DD:00 F250 7.3
Build:
ThomasYJ is offline
post #443 of 544 Old 07-16-2013, 06:16 PM Thread Starter
10-3-TJ
Power steering nightmare
Currently had to drive Oscar 37.6 miles through country roads with no power steering.
No idea what happen. It just stopped working directly after running over a decently large bush while wheeling on my buddies land.
No pinched lines or hoses, plenty of fluid. Just stopped working
Any ideas boys? I haven't looked into what a new runs.
10-3-TJ is offline
post #444 of 544 Old 07-16-2013, 06:46 PM
propjockey2002
Did you maybe break a gear inside the box?
My build
post #445 of 544 Old 07-16-2013, 08:21 PM Thread Starter
10-3-TJ
It's a newer box maybe three years old.
I don't know if I broke a gear it's a possibility! ?!?!
Though I am assuming that if a gear was broken I wouldn't be able to steer it. I can steer it, it's just unassisted.
I called Jeff Daniels Jeep and everyone who was familiar with my Jeep was either off or busy. I would expect them to call tomorrow.
10-3-TJ is offline
post #446 of 544 Old 07-17-2013, 10:17 AM
youngjeeper11
youngjeeper11's Avatar
1987 YJ Wrangler
sounds like a seal or something broke, either in the box or the pump.
I cant not think of an easy way to test the pressure coming out of the pump, maybe pop off the low pressure hose and see if anything is pumping out?
Jeep 1:Used to have a 93 YJ 2.5l- 3.5" Black Diamond, Chevy TBI 5.7l V8, SM 465 4 speed, 8.8 rear( 4.10, L/S), rhinoline, Mile Marker 9000, NP 231, Had to sell it due to college
Jeep 2: 89/91 YJ, 4BT Cummins, NV4500, NP 231, Old Man Emu 2.5" suspension lift, 1" body lift.....Runs and drives, but very much a project
Interned at Novak Conversions 2 summers ago
Ask me about my 4BT Cummins Motor Mounts!!
youngjeeper11 is offline
post #447 of 544 Old 07-17-2013, 10:42 AM Thread Starter
10-3-TJ
Youngjeeper..
That's a really good idea, I was trying to think of some stupid way to put a gauge on the high pressure side. But your suggestion seems much easier.
I found a new pump from NAPA for 57 dollars. I am gonna pull the low side tonight and see if it's doing anything.
When the pump stopped my front axle was locked and I was turning. Is there any evidence that locked axles make the life expectancy shorter on power steering pumps
Bad part is the power steering pump is a complete pain in the A S S to remove. The vacuum pump has to come out to, and that's a real treat.
Remember about a week ago when I said if you do this swap be ready to wrench all the time!! Well here we go again.
Now maybe my experience is different because I drive long distance on roads and freeways, pull a 3500 pound trailer every week and drive on un improved roads. But. ..I TOLD YOU SO.
or it could be because I am not a mechanic. .
10-3-TJ is offline
post #448 of 544 Old 07-17-2013, 10:49 AM
youngjeeper11
1987 YJ Wrangler
Well,
I am not really sure what to conclude if fluid pours out, but if nothing is coming out, well, I am still not sure what to conclude then either, just that there is a problem haha
post #449 of 544 Old 07-17-2013, 08:01 PM
papitt
If my memory serve me correct from Back when I worked at the Dodge stealership about 7 years ago os so . I believe the power steering pump Looks about like a Love Joy connection and one side breaks off. Nothing on a Cummins every breaks regular so If you see a problem about 3 time . You most likely won't see that again.
.. Except for the new 24 valve Ditry Fuel trucks. Any truck above 2003. really .
papitt is offline
post #450 of 544 Old 07-17-2013, 08:20 PM Thread Starter
10-3-TJ
Pappit
I am gonna pull the pump right now and see what's up! If I have to fix everything 3 times I may have a jeep for sale.! !!
Guys thanks for the advise I will try to post pics as I go
10-3-TJ is offline
4bt , cummins , tj
Diesel Cummins 4BT TJ doc_dyer Jeep Builds 174 12-29-2013 04:10 PM
Show me your Cummins! Ptr Jeep Picture Requests 37 09-03-2013 02:37 PM
Cummins 4BT YJ TimP Jeep Builds 5 10-25-2011 04:11 PM
looking for used 4bt cummins engine bobbyp10 Jeep Builds 3 03-02-2010 01:51 PM
Cummins Diesel ralf Jeep Builds 6 03-02-2010 09:44 AM
