Oscar the TJ gets a CUMMINS - Page 3 - JeepForum.com
post #31 of 544 Old 07-27-2012, 11:26 PM Thread Starter
10-3-TJ
Well while i am waiting for my turbo to soak in my mystery solution i started on the crankshaft sensor and cam shaft sensor. Both of these will allow me to use my stock tach.
"We have enough youth, how about a fountain of smart"
"Look no further than yourself, for all of the good and all of the evil that exist in this world, resides in the heart of man and his propensity to use it".
10-3-TJ is offline
post #32 of 544 Old 07-28-2012, 06:40 PM
JASON_77
Subscribed
~Jason~
1998 TJ 4.0L,2.5 Skyjacker,1.25 JKS, MML,Flat belly,35-12.50-17 Mud Grapplers,17x9 Classic Locks,HP30/8.8 4.56
2000 WJ 4.7, 6.5" LA, 33's, 4.56's
JASON_77 is offline
post #33 of 544 Old 07-29-2012, 12:48 AM
ksilovich
Originally Posted by 10-3-TJ View Post
Do you plan on cutting a hole in your hood.
The 4bt is a tall engine as it is. Why stick it all the way in the air like that.
This is how I did mine.
I used a 5.9 manifold cut down also. But I have an HE341 turbo installed.
If you want to check out my build here a link.
Jeffery 2.0 : Cummins 4bt, 40's, ORI's, D60, 14B, lots of AL
ksilovich is offline
post #34 of 544 Old 07-29-2012, 02:30 AM
justanotherjpr
Subbed!
justanotherjpr is offline
post #35 of 544 Old 07-29-2012, 06:05 PM Thread Starter
10-3-TJ
Ksilovich.. You make a great point about the turbo up so high. I am also worried about it. I chose the manifold that had a complete 90 bend in it rather than the 45. I had both in front of me and called shawn at Jeff Daniels and he suggested the 90. I like how yours sets down lower. Just have to wait and see what happens. Worst case. I get to cut and weld more on another manifold.
10-3-TJ is offline
post #36 of 544 Old 07-29-2012, 06:09 PM Thread Starter
10-3-TJ
I am also thinking about running a snorkel kit for a YJ from ARB. The YJ snorkel exits the drivers side fender. I cant use my passenger side fender cause that is where my 4 inch exhaust is gonna exit. Much like marstache. ( spelling is prolly way off) i was very impressed by his build and love the way his jeep looked with that stak
10-3-TJ is offline
post #37 of 544 Old 07-29-2012, 10:36 PM Thread Starter
10-3-TJ
Here are some pics from Jeff Daniels Jeeps webiste of a TJ with a high mount turbo which is identical to mine
10-3-TJ is offline
post #38 of 544 Old 07-29-2012, 10:38 PM Thread Starter
10-3-TJ
Agian these are NOT MY jeep.. but just examples of what mine " should " look like when jammed back into the TJ.
10-3-TJ is offline
post #39 of 544 Old 07-29-2012, 10:40 PM Thread Starter
10-3-TJ
For anyone looking to put a Cummins in your Jeep check out kssilovich build. It is awesome. I wish mine was going that direction. AWESOME JOB ksilovich
10-3-TJ is offline
post #40 of 544 Old 07-30-2012, 06:23 PM
Renegade88
CRAWLED! This is fun to watch.
2006 LJ
PanhandlePierFishing.com
Renegade88 is offline
post #41 of 544 Old 07-31-2012, 07:36 PM
rubidriver
I am very anxious to see this.
2005 Black Rubicon - OME 933/942 - 4" Bilstein 5100 (canister up) - JKS Adj Track Bars Front/Rear - JKS Quicker Discos - 285/75/16
Originally Posted by bigj1974 View Post
your money will go farther in College Station.
rubidriver is offline
post #42 of 544 Old 07-31-2012, 07:54 PM
jknate
This is the route I want to take with my jk.
jknate is offline
post #43 of 544 Old 07-31-2012, 09:56 PM Thread Starter
10-3-TJ
JKNATE
Contact Shawn and Dan at jeff daniels jeep and discuss with them what you have and want to do. They sell kits for your JK. On their website the have one or two JK's with a cummins and pictures also. Good luck
10-3-TJ is offline
post #44 of 544 Old 07-31-2012, 10:08 PM Thread Starter
10-3-TJ
UPDATES UPDATES UPDATES
So the last couple posts I was waiting for my mystery solution to work its magic. WELL IT DIDNT WORK. So i contacted Stacy and Columbus Diesel Supply told him my dilemma. He told me to bring the turbo on in and he would get it apart. I was very skeptical because i already took it to one shop and they laughed at me.
To my relief Stacy came through and got the exhaust housing seperated. Fast forward to this morning. I attempted to clean and clock the turbo so it would work for my application. Well i am no turbo builder for sure.. some how i got the exhaust housing on crooked and the fan blades where hitting bad!
So again i went back to Columbus Diesel Supply for Stacy to rescue me. Stacy and another mechanic saved my as* . They took my turbo apart again sand blasted my housing and cleaned the center housing and re installed the housing FOR FREE!!!!!!!! I couldnt believe it..
The turbo spins like a brand new one. I couldnt be happier.
10-3-TJ is offline
post #45 of 544 Old 07-31-2012, 10:13 PM Thread Starter
10-3-TJ
So feeling that my karma bank was now empty i figured i better go get parts like oil filter, fuel filter , thermostat , front cover gasket and the like. Well luck strikes again. Turns out there is a Cummins dealer about 15 minutes away... I also stopped at NAPA and picked up some cummins beige spray paint in a rattle can.
10-3-TJ is offline
4bt , cummins , tj
Diesel Cummins 4BT TJ doc_dyer Jeep Builds 174 12-29-2013 04:10 PM
Show me your Cummins! Ptr Jeep Picture Requests 37 09-03-2013 02:37 PM
Cummins 4BT YJ TimP Jeep Builds 5 10-25-2011 04:11 PM
looking for used 4bt cummins engine bobbyp10 Jeep Builds 3 03-02-2010 01:51 PM
Cummins Diesel ralf Jeep Builds 6 03-02-2010 09:44 AM
