Oscar the TJ gets a CUMMINS - Page 28 - JeepForum.com
post #406 of 544 Old 04-07-2013, 07:43 PM Thread Starter
10-3-TJ
I have gotten a lot done in the last couple weeks.
I got the HX35W mounted and plumbed. It required me to scoop the hood. The hood is from jegs and all I did was cut it to length
I think it looks great.
"We have enough youth, how about a fountain of smart"
"Look no further than yourself, for all of the good and all of the evil that exist in this world, resides in the heart of man and his propensity to use it".
10-3-TJ is offline
post #407 of 544 Old 04-07-2013, 08:30 PM
ThomasYJ
whaaat... That's BADASS!!!
The Toy:93 YJ
The DD:00 F250 7.3
Build:
ThomasYJ is offline
post #408 of 544 Old 04-08-2013, 08:27 AM Thread Starter
10-3-TJ
I also was able to get my turn signals built.
I am no professional but it works fine. Did the best I could.
The heat shrink help cover my sins
The turn signals act as running, marker lights like the original and then blink when turning.
These lights are from a motor cycle shop on e bay and have a smoked lens. They look super sweet.
10-3-TJ is offline
post #409 of 544 Old 04-08-2013, 08:31 AM Thread Starter
10-3-TJ
Here is Oscar in his natural environment. The diesel is completely unbelievable. The amount of torque and power is awesome.
The fastest I can go with the pedal to the floor and 2500 RPM is 74. Hey that's fine with me Jack.. it isn't a race car.
But with that said. I crushed a newer Cummins dodge pickup for the dirst
10-3-TJ is offline
post #410 of 544 Old 04-08-2013, 08:34 AM Thread Starter
10-3-TJ
Oops my thumb slipped.
I crushed a Cummins dodge pick up all the way through 4 th gear and shifting into 5th. Then I was left in a cloud of dust and embarrassment while coughing soot.
10-3-TJ is offline
post #411 of 544 Old 04-08-2013, 08:38 AM Thread Starter
10-3-TJ
The two pictures above are of the HX and my plumbing.
Here is where I put my gauges. I bought the pod from quadratec. And the gauges are automated phantom 2. Backlit leds.
10-3-TJ is offline
post #412 of 544 Old 04-08-2013, 08:44 AM Thread Starter
10-3-TJ
Damn auto correct autometer gauges not automated.
A problem I ran into after installing the HX was the larger intake pipe. The HX runs a 4 inch intake. The problem was my water neck into the thermostat is in front of the turbo and no stock four inch bend would clear it. So I made this
The finished pipe works great. I cleaned all the welds up and used a little filler to smooth everything. Looks like it belongs there.
10-3-TJ is offline
post #413 of 544 Old 04-09-2013, 02:23 PM
TexasTJ
No Longer DD
TexasTJ's Avatar
Originally Posted by 10-3-TJ View Post
Attachment 603489
I'm pretty much speechless.
May TJ of the Month 2015
TexasTJ is offline
post #414 of 544 Old 04-16-2013, 04:35 PM
ksilovich
How much boost are you pushin?
Jeffery 2.0 : Cummins 4bt, 40's, ORI's, D60, 14B, lots of AL
ksilovich is offline
post #415 of 544 Old 04-16-2013, 09:48 PM Thread Starter
10-3-TJ
Ksilovich,
I am getting 20 - 25 psi. 25psi is the max. My waste gate isn't opening either. My turbo already had a home made waste gate bracket on it. The waste gate points down from the turbo which works great with my setup. I think the homemade bracket is longer than stock therefore holding the waste gate closed. I am running rubber fuel injection hose from the boost pipe to the waste gate and with an air compressor it took 40 psi to open the waste gate. I tried to find the heavy duty plastic tubing for the waste gate and the only place I found it, they wouldn't sell it to me!
I am still really new to the diesel world. is 20-25 psi good. It is a challenge to get any boost in first and second because I run out of gear and the governor starts killing the fuel. I tuned my injection pump and that helped a lot. I have a boost elbow installed by it is completely open right now. Like I said the waste gate is NOT actuating at the moment.
10-3-TJ is offline
post #416 of 544 Old 04-16-2013, 09:52 PM Thread Starter
10-3-TJ
Just noticed the gauges didn't post.
10-3-TJ is offline
post #417 of 544 Old 04-17-2013, 05:55 AM
tytec95
nice nice
tytec95 is offline
post #418 of 544 Old 04-18-2013, 05:23 PM
ksilovich
Ksilovich,
I only have off road driving on mine right now and that is mostly in second gear, but I can reach about 30psi on mine. I have my waste-gate welded shut. I think 30psi (at the intake after the intercooler) is a good top end for the 4bt's.
IMO unless your going all out on the engine, there is no real reason for the waste-gate.
post #419 of 544 Old 04-19-2013, 10:29 AM Thread Starter
10-3-TJ
Oh okay. Well maybe I won't spend the money to change the Wastegate. Thanks for the info.. I also used your advice on the turn signals and they work great.
Great build by the way. I really like your suspension setup..
10-3-TJ is offline
post #420 of 544 Old 05-05-2013, 06:59 PM
ksilovich
Thought Id post a little update after putting 100 road miles on. I am not sure if you have a different gov spring installed. If you don't I would recommend the 3200 rpm. With that installed, and my pump turned up one turn, and my new fuel pin. I am able to get about 10lbs in first. (but my first is a granny gear.) 2nd = 25ish, and 3rd = 35lbs.
Thanks on the complement. I am glad to hear that you found that useful for your lights.
4bt , cummins , tj
Diesel Cummins 4BT TJ doc_dyer Jeep Builds 174 12-29-2013 04:10 PM
Show me your Cummins! Ptr Jeep Picture Requests 37 09-03-2013 02:37 PM
Cummins 4BT YJ TimP Jeep Builds 5 10-25-2011 04:11 PM
looking for used 4bt cummins engine bobbyp10 Jeep Builds 3 03-02-2010 01:51 PM
Cummins Diesel ralf Jeep Builds 6 03-02-2010 09:44 AM
