Oscar the TJ gets a CUMMINS - Page 15 - JeepForum.com
post #211 of 544 Old 09-17-2012, 04:22 PM Thread Starter
10-3-TJ
http://s1223.photobucket.com/albums/...0911121344.mp4
"We have enough youth, how about a fountain of smart"
"Look no further than yourself, for all of the good and all of the evil that exist in this world, resides in the heart of man and his propensity to use it".
10-3-TJ is offline
post #212 of 544 Old 09-17-2012, 09:18 PM
papitt
Well I'm going to say .. Your going to love it once you get it going..
Tonight I planted oats for the Deer with my Bronco 4BT pulling the Grain Drill ... So cool radio power steering good seat .. Taco the Dog setting in the other seat .. I didn't even need 4by4 .. 4BT... Cold Beer in hand & your Best Dog .. Wonder What the Poor Folks are DOING... I never even needed my cooling fan today.
papitt is offline
post #213 of 544 Old 09-17-2012, 10:23 PM
contdevelop
subscribed
contdevelop is offline
post #214 of 544 Old 09-17-2012, 10:59 PM
austinaubinoe
WOW that is very nice! Makes it very tempting to swap it into my dads 2000 SE, but he really wants a V8.
austinaubinoe is offline
post #215 of 544 Old 09-18-2012, 07:19 AM
crockett07
1992 XJ Cherokee
BLASPHEMY
crockett07 is offline
post #216 of 544 Old 09-18-2012, 11:30 AM
Vonguido
I can't wait to see the finished product, sounds great in the video. Looking forward to seeing that thing cruising around C-Bus! Long term goal for my XJ is to put a diesel in it, but that's a long way out. Keep up the solid work man
Vonguido is offline
post #217 of 544 Old 09-18-2012, 02:48 PM
cycleguy04
What a BEAST! I want one and I'm horrendously jealous...
'98 Wrangler Sahara - SOLD
'91 Ranger XLT 2WD - 4.0 V6, A4"hell"D, contemplating twin turbo 5.3
'79 C10 Big Ten 2WD - 350, TH350, contemplating rebuilding to 355ci with supercharger and programmable EFI
'12 Subaru Forester (AKA: Arctic Cat) - 2.5, non-CVT, wife's, still begging her to let me get an exhaust system
'01 SV650 - snorkelectomy, ebay slip-on, cam swap and re-jet in the near future
cycleguy04 is offline
post #218 of 544 Old 09-18-2012, 09:51 PM Thread Starter
10-3-TJ
Thanks for all the great comments guys. I have been busting my tail today.
So last night i broke off a brass fitting in the bottom oil port on the passenger side of the motor. Honestly if i had a stick of dynamite i would have blown Oscar up. He has been fighting me left and right.
So it wasnt as bad as i thought it would be to fix but... so i had to take that large plate off the engine and then used an easy out like tool.
So it came right out with little to no effort.
10-3-TJ is offline
post #219 of 544 Old 09-18-2012, 09:52 PM
2002TJX65
Awesome swap, subscribed.
03 Rubicon: Build in Progress
02 TJ: Built and totaled
86 CJ7: Sold
2002TJX65 is offline
post #220 of 544 Old 09-18-2012, 10:06 PM Thread Starter
10-3-TJ
I mentioned i finished the exhaust. I think it looks pretty killer. So i started with this...
I used that for mock up and was even planning on using it as is was but when i got my elbow i realized that the bend and reducer would need shortened. So i ended up with this...
Then shortened my elbow and she fit like a charm. Then added my 45 elbow and cut it the stack to length.
Before the stack was cut
The stack is obviously not mounted for final because i am going to use my fender as support for the weight of the exhaust.
Then moved on to my coolant lines. Long story short i didnt feel like spending a ton of time at NAPA looking for coolant lines. So i thought what the heck i will make my own using rubber to make the connections. This is what i ended up with..
I did not grind my welds yet but i plan on grinding them smooth..
Ohh. I forgot to mention my engine idles at 55 psi.
10-3-TJ is offline
post #221 of 544 Old 09-18-2012, 10:45 PM
Jeep1998XJ
wow nice build
Jeep1998XJ is offline
post #222 of 544 Old 09-19-2012, 09:50 AM
scoutboater
1974 CJ5
55 psi of boost?
scoutboater is offline
post #223 of 544 Old 09-19-2012, 11:01 AM Thread Starter
10-3-TJ
55 psi of oil pressure
10-3-TJ is offline
post #224 of 544 Old 09-19-2012, 11:22 AM
crockett07
1992 XJ Cherokee
Sweet oil pressure!
post #225 of 544 Old 09-20-2012, 12:04 AM Thread Starter
10-3-TJ
So i finished up my coolant pipes tonight and finished grinding all my welds down. I ended up re welding both coolant lines at all the seems and grinding them silky smooth.
I decided to weld again because i didnt like seeing the weld seams at the edge of the puddles.
These two are the upper
And exhaust stack
And the lower
Tomorrow i plan on adding the advanced adapters transfere case adapter for the four wheel drive.
10-3-TJ is offline
4bt , cummins , tj
Diesel Cummins 4BT TJ doc_dyer Jeep Builds 174 12-29-2013 05:10 PM
Show me your Cummins! Ptr Jeep Picture Requests 37 09-03-2013 03:37 PM
Cummins 4BT YJ TimP Jeep Builds 5 10-25-2011 05:11 PM
looking for used 4bt cummins engine bobbyp10 Jeep Builds 3 03-02-2010 02:51 PM
Cummins Diesel ralf Jeep Builds 6 03-02-2010 10:44 AM
