Oscar the TJ gets a CUMMINS - Page 14 - JeepForum.com
post #196 of 545 Old 09-12-2012, 06:03 PM Thread Starter
10-3-TJ
Okay gentlemen and ladies if those exist in jeep land..
The engine has breathed life. I couldnt be more excited. Let me catch everyone up.
First my boost air pipe was bothering me becuase it wss even and level. So i spent a couple hours cutting and welding and turned out with this. First picture is an old one and second is the new.
Then moved onto the exhuast. I cut and clearanced my battery box and then added some more pipe. First picture is showing the pipe and box before cutting.
"We have enough youth, how about a fountain of smart"
"Look no further than yourself, for all of the good and all of the evil that exist in this world, resides in the heart of man and his propensity to use it".
10-3-TJ is offline
post #197 of 545 Old 09-12-2012, 06:09 PM Thread Starter
10-3-TJ
Then it was time to move onto the alternator bracket. I made it adjustable which was necessary but i wanted to be able to if i had to.
It was simple just took flat stock one inch wide 1/8 thick about 6 inches long and drilled three holes on each end then ground the holes together to make one long hole.
10-3-TJ is offline
post #198 of 545 Old 09-12-2012, 06:40 PM Thread Starter
10-3-TJ
Next up was the alternator bracket. I made it adjustable and out of one inch by 1/8 flat stock.
Attachment 471199
It didnt have to be adjustable i just wanted to make sure i was going to have enough room for my new belt.
I went to the local NAPA and had measure for my new belt. My measurement said 82 and 1/8. However they didnt have that belt but they did have one which was 81 1/8 so i got it.
It fits really good with one exception. I keep throwing the belt on the top of the ac compressor.
So tonight i am going to move my ac comp. Back about half an inch. Drill and tap new holes. No biggie.
I will post a video of it running tonight. Its a beasts. The entire jeep shakes in fear of the engine. Literally the entire jeep shakes at idle. Pretty awesome.
10-3-TJ is offline
post #199 of 545 Old 09-12-2012, 06:51 PM Thread Starter
10-3-TJ
Attachment 471199
Attachment 471200
Attachment 471204
Attachment 471212
10-3-TJ is offline
post #200 of 545 Old 09-12-2012, 06:53 PM
CumminsYj88
Freakin Awesome dude!! I'm so excited to see this video!!
CumminsYj88 is offline
post #201 of 545 Old 09-13-2012, 06:46 PM
Cowboyup94
I keep checking every hour on my phone and still no video!!!!
JEEP
Just Emptying Every Pocket
Cowboyup94 is offline
post #202 of 545 Old 09-13-2012, 06:51 PM
jknate
I know right!
jknate is offline
post #203 of 545 Old 09-13-2012, 06:58 PM
cycleguy04
I hear the belt problem with your York is common. It's a good idea to order a dual channel alternator pully from Kilby and have a seperate compressor belt that runs off the second channel. That's what I plan on doing when I finally get around to building my setup.
'98 Wrangler Sahara - SOLD
'91 Ranger XLT 2WD - 4.0 V6, A4"hell"D, contemplating twin turbo 5.3
'79 C10 Big Ten 2WD - 350, TH350, contemplating rebuilding to 355ci with supercharger and programmable EFI
'12 Subaru Forester (AKA: Arctic Cat) - 2.5, non-CVT, wife's, still begging her to let me get an exhaust system
'01 SV650 - snorkelectomy, ebay slip-on, cam swap and re-jet in the near future
cycleguy04 is offline
post #204 of 545 Old 09-16-2012, 12:06 PM
jeepwrangler89
any updates? still waiting on a video!
jeepwrangler89 is offline
post #205 of 545 Old 09-16-2012, 08:20 PM
CumminsYj88
Must have had a heart attack from all the excitement!?
post #206 of 545 Old 09-17-2012, 06:47 AM Thread Starter
10-3-TJ
Hey fella's. No heart attack here. Work has been stupid crazy. Any how i have finished the exhaust and only need to cut a hole in the fender.
Current speed bumps are a few. I have been starting and running the engine for only about a minute because i have no radiator but i am not getting an oil pressure reading. I first was very scared that i didnt have any pressure, but i also have ZERO gauges on the dash.
Me thinks i cut the wrong wire SOMEWHERE ... so the search continues for that.
Last night i was able to fab up a clutch fork. Basically what i did was cut the end of the clutch fork off then moved the bottom of the piece i cut off to the top. Basically off set it then welded it back up.
Will take pictures of the finished part tonight and post it.
How do i post a video from my phone to jeepforum? Everything i try says the video file is to large.
The next pictures are of my new Borgeson HD steering shaft. Easy easy upgrade just darn expensive. I had to do it because my old orginal was shot.
10-3-TJ is offline
post #207 of 545 Old 09-17-2012, 06:51 AM Thread Starter
10-3-TJ
Also finished miving the ac compressor. Moved it back half and inch and now my belt stays in just fine.
Basically just used a square and scribed two lines then punched the hole location drilled and taped.
Well fellas the rat race calls my name. I am working my weekends to pay for Oscars heart transplant . I will take and post all the updates tonight.
10-3-TJ is offline
post #208 of 545 Old 09-17-2012, 01:24 PM
jeepwrangler89
Sweet progress! Can't wait to see it at the show. Are you planning on going on their November fall ride at rausch?
post #209 of 545 Old 09-17-2012, 03:05 PM Thread Starter
10-3-TJ
Okay so I just figured out how to post the video. The sound is slightly delayed but whatever.. I am def not a computer person. Sounds pretty sick right!!!!
I will post a few more videos I took.
10-3-TJ is offline
post #210 of 545 Old 09-17-2012, 03:21 PM Thread Starter
10-3-TJ
http://static.photobucket.com/player.swf" flashvars="file=http%3A%2F%2Fvid1223.photobucket.com%2Falbums %2Fdd506%2F10-3-tj%2F0911121344.mp4">
10-3-TJ is offline
4bt , cummins , tj
Diesel Cummins 4BT TJ doc_dyer Jeep Builds 174 12-29-2013 04:10 PM
Show me your Cummins! Ptr Jeep Picture Requests 37 09-03-2013 02:37 PM
Cummins 4BT YJ TimP Jeep Builds 5 10-25-2011 04:11 PM
looking for used 4bt cummins engine bobbyp10 Jeep Builds 3 03-02-2010 01:51 PM
Cummins Diesel ralf Jeep Builds 6 03-02-2010 09:44 AM
