Oscar the TJ gets a CUMMINS - Page 13 - JeepForum.com
post #181 of 544 Old 09-02-2012, 09:37 AM
CumminsYj88
What size fuel line are you running?
CumminsYj88 is offline
post #182 of 544 Old 09-02-2012, 10:15 AM Thread Starter
10-3-TJ
The feed line remains the exact same . When i did the fuel lines all i had to do was run a 5/16return fuel line. Everything else inxluding the stock pump is left in place and will be used.
"We have enough youth, how about a fountain of smart"
"Look no further than yourself, for all of the good and all of the evil that exist in this world, resides in the heart of man and his propensity to use it".
10-3-TJ is offline
post #183 of 544 Old 09-02-2012, 12:31 PM
papitt
I too used the stock steel line . I did replace the rubber sections and had my fuel tank steamed out . Then I put in a pt of 2cycle motor oil and a qt of trans fluid then put in about 10 gallons of fuel . Then I ran my lift pump about 3 night pushing the fuel up to the injection . I added a inline filter before my injection pump an the stock BT filter and I also added another filter in the return line. I took these 2 filters out after I had cycled my fuel through the system..
... I dought these step were necessary but it made me feel good.. My motor had set for about 2 years and I thought it would be hard to start. But it started on about the 5 turn. I was shocked .. I've wondered if all that cycling of the fuel through the system may have prime the pump for me.
papitt is offline
post #184 of 544 Old 09-02-2012, 12:41 PM Thread Starter
10-3-TJ
Pappit ,
Thats a great idea about cycling the intanj pump. I had thoughts of doing the same. I am looking forward to tomorrow i have the entire day off and plan on crushing the to do list.
Its getting close to being ready to start.
10-3-TJ is offline
post #185 of 544 Old 09-02-2012, 01:20 PM
TexasYJ
10-3-TJ,
Really enjoying your build thread and I am seriously considering a 4BT swap as well......further down the road, a swap from four angry squirrels to 4 oily squirrels. I have a question, is the in tank pump compatible with diesel fuel use? I have read a couple of other threads, non JF, where there appears to be issues/failures using the stock gasoline in tank pump in a diesel fuel application, as the stock in tank pump is not really compatible with diesel fuel.
TexasYJ is offline
post #186 of 544 Old 09-02-2012, 04:52 PM Thread Starter
10-3-TJ
Little off topic but i was at work when i saw this fellow jeeper who had been shrink wrapped. Funny stuff.
The shrink wrap bandits even got the entire undercarriage. Hope this person removes the plastic from things which get hot
10-3-TJ is offline
post #187 of 544 Old 09-02-2012, 06:37 PM Thread Starter
10-3-TJ
Texasyj
You bring up a great point. Before starting this great adventure i was reassurred by Dan from jeff daniels that there would be not problems . His explaination was that diesel has more of a lubrication factor to it than gas.
While i have also read other forums where fuel pumps have failed presumably from diesel i am not certain there is a connection and maybe a coincident . At any rate i no joke just replaced my tj pump last year. I spent big money on an oe Bosch pump.
So if mine fails shortly after sucking diesel we will truly know. I also see the argument that diesel is killibg the pumps. Guess i am thinking that both agruments make sense.
We shall see!
10-3-TJ is offline
post #188 of 544 Old 09-02-2012, 07:32 PM
TexasYJ
Originally Posted by 10-3-TJ View Post
Texasyj
We shall see!
It seems like, from what I have read, they were seeing failures in somewhere between six months to a year.....
The only reason I asked was I could see a material incompatibility issue with pumps used for gasoline vs. those used for diesel fuel applications. Not totally related, but similar issues involving diesel systems using bio-diesel applications, primarily related to o-rings and rubber hoses. Just thought I would put it out there.
Look forward to following the rest of this build.
TexasYJ is offline
post #189 of 544 Old 09-02-2012, 08:56 PM Thread Starter
10-3-TJ
TexasYj..
You make complete sense. I could see where the stock gasoline fuel pump would encounter issues while pumping diesel. After all it was designed to pump gasoline.
Pappit have you had any issues with your stock pump?
10-3-TJ is offline
post #190 of 544 Old 09-02-2012, 09:30 PM
TexasYJ
I am assuming here, but does your 4BT not have the mechanical lift pump and if so, what reason is there for the addition of tank pump?
TexasYJ is offline
post #191 of 544 Old 09-02-2012, 09:43 PM Thread Starter
10-3-TJ
TexasYj.
The engine does have the mechanical lift pump. Basically what it boiled down to was i didnt want to remove the tank and drill a hole in a brand new fuel pump to make room for the new feed line. I have installed a check vavle which will open once the lift pump sees pressure drom the tj pump. The excess diesel will be returned to the tank. Basically re circulating the fuel.
10-3-TJ is offline
post #192 of 544 Old 09-02-2012, 09:45 PM
TexasYJ
Got, it. Just curious if there was another reason.
Back to the updates......
TexasYJ is offline
post #193 of 544 Old 09-02-2012, 10:33 PM
papitt
hEY OSCAR .. I may be a little late with this info but maybe some info you can use.. I was just over on the 4BTSWAPS.COM and here a post from a fellow member there that did your swap sometime back.. Hopefully I can post up a link to his build post. http://www.4btswaps.com/forum/showth...d-a-4bt-diesel........
... Looky there I'm getting handy as Pockets on a shirt......
papitt is offline
post #194 of 544 Old 09-08-2012, 10:22 PM Thread Starter
10-3-TJ
Okay guys its been a minute since my last post but work has been stupid busy and have ben working a lot of overtime.. The progress I have made recently is. I think. fingers crossed that I have finished my wiring. It was stressful as hell cutting into a perfectly good wiring harness. I have been reading a lot of forum posts on 4BTSWAPS.com about the wiring and I am confident.
I also went and bought the remainder of my clamps, exhaust tubing for my exhaust and oil return line. I feel a start up coming in the VERY near future. my goal is to have the Jeep running by Tuesday night. Thanks to everyone for being patient with me as this project has slowed in progress recently..
Hey pappit I wasnt able to open that link. It told me something about that page doesnt exist anymore.
10-3-TJ is offline
post #195 of 544 Old 09-09-2012, 06:14 PM
papitt
Hey one thing to think of when you turn the switch to either just roll it over or try to start it up.
This happened to me.. I had not water hooked up so mine didn't need to start . I was just going to roll it over to see if I had oil pressure .. Well about the 5th roll it fired up on its own .. It would not kill with the key switch .. I really had no ideal how to kill it but the Kid '' SKITTER JOE'' He knew to reach over to the injection pump an pull the hot wire off it..
... So be prepared for the back side of what can happen upon fire up.
... You might even have a flat piece of wood handy just in case you had a run away.. You block the inlet of your turbo with a block of wood so the air will be cut off ..
papitt is offline
4bt , cummins , tj
Diesel Cummins 4BT TJ doc_dyer Jeep Builds 174 12-29-2013 04:10 PM
Show me your Cummins! Ptr Jeep Picture Requests 37 09-03-2013 02:37 PM
Cummins 4BT YJ TimP Jeep Builds 5 10-25-2011 04:11 PM
looking for used 4bt cummins engine bobbyp10 Jeep Builds 3 03-02-2010 01:51 PM
Cummins Diesel ralf Jeep Builds 6 03-02-2010 09:44 AM
