Oscar the TJ gets a CUMMINS - Page 12 - JeepForum.com
post #166 of 544 Old 08-25-2012, 01:42 PM
lucious
haha. nice. props
lucious is offline
post #167 of 544 Old 08-25-2012, 02:23 PM
Luke95
I love it!
5.2 ZJ Pushing a dana 30 as far as it will go.
Luke95 is offline
post #168 of 544 Old 08-25-2012, 07:31 PM
lobi
WOW i want one in mine
lobi is offline
post #169 of 544 Old 08-27-2012, 01:40 PM
tdij
Originally Posted by 10-3-TJ
As to the price of this project. Lets just say i opened a can of worms that i cant close now. Have to see it to the end.
I hear that... My swap quickly grew more and more expensive... But once you have a diesel mounted in your jeep... There is no turning back. Once you drive it a bit... It will quickly make you forget how much you spent!
Looking forward to seeing the slave adaptation!
I have had the plan to route my intake into the cowl... But haven't found a filter option I really like for this. Can't wait to see what route you go!
BOBCAT: TDI powered YJ
tdij is offline
post #170 of 544 Old 08-27-2012, 02:32 PM
Bojon
1981 CJ5
Can't wait to see this done. I'd like to say you were the nail in the coffin for me. I had thrown the idea around of finding a 4BT. After seeing your thread I actually went out and got one!
Jered
Bojon is offline
post #171 of 544 Old 08-28-2012, 04:13 PM
Deanfly64
Subbed, for the finale.
Deanfly64 is offline
post #172 of 544 Old 08-29-2012, 10:21 PM Thread Starter
10-3-TJ
Well yesterday i worked on the jeep ALL day long.
The jeep project has reached that point which every build reaches. The two steps forward one step back..
Lets start with the steps forward.
I finished securing and reinforcing the ac mount.
The first picture i am showing the three spacers. The second pic shows how i used 1/8 plate and covered and connected the spacers.
Then moved onto the finishing touches of the fuel lines.
The line is a 5/16 line which runs all the way to the filler vent tube and is connected so that return fuel will basically recirculate back to the tank. Not pictured because its burried under the jeep is a check valve so that no air can enter the fuel lines via the new return line.
Then moved onto finishing up the boost air from the turbo to the engine. That was fairly simple just measure, cut and weld . I also shortened the turbo side of the intake in order for the coolant line not to interfere.
Then moved onto the cps . I got the sensor wires cur and stripped. So i got the old solder iron out and i had no sotter. Who uses all the sotter and just puts it away. Ohh thats right. This guy does.
"We have enough youth, how about a fountain of smart"
"Look no further than yourself, for all of the good and all of the evil that exist in this world, resides in the heart of man and his propensity to use it".
10-3-TJ is offline
post #173 of 544 Old 08-29-2012, 10:37 PM Thread Starter
10-3-TJ
Now the steps backward...
So i have to admit i didnt take many pictures of my backward steps. Although i can explain them clearly
First. I decided that i better check my hood clearance since i have been convinced the hood would latch.
So on went the gril and supports and the hood. I actually got really excited at this point because it looked soo good and all most done. I went to lower the hood and thats when the hood stoppes about 3 3/4 inches from the gril . The turbo, boost pipe and oil pressure feed line are holding the hood up.
So for those of you who thought i was crazy when i said the hood will shut. YOU WERE RIGHT I WAS WRONG.
So i have began the hunt for a weld on hood scoop. Jegs and summit racing have one which i will post a pic of.
Myself and Dan from Jeff Daniels are working on a differnt type of slave cylinder. We are designing a pulling slave cylinder setup. I have tons of room behind the clutch fork and trying ti work somthing that way. Although i havent ruled out using the orignal slave cylinder which pushes .
Then on to my biggest delima. I need your guys opinions . I cant seem ti figure out what i am going to do about the interferences between the upper control arms and my motor mounts. I used my jack tonight and jacked the jeep up as far as my jack would go. My tire was maybe 2 1/2 feet off the ground and maybe 4 --6 inches before my bump stops hit.
Here is the pic of the upper driver side arm.
As you can see its nasty close. I am currently considering a long arm as the radius arms will not hit the mounts..
I appreciate all the motivational comments everyone has made and look forward to everyones suggestions.
10-3-TJ is offline
post #174 of 544 Old 08-29-2012, 10:42 PM Thread Starter
10-3-TJ
BOJON
You have start a thread. I would love to see other peoples ideas.
Congrats on pulling the trigger on the Cummins.
I almost started the engine the other day but whimped out because i will be honest i dont know how to turn it off. Nothing is wired and i was just gonna put a battery to the starter and let the smoke roll until it ran out of diesel. But the i remebered that running diesels out of fuel isnt a great idea.
So instead i got on youtube and enjoyed everyone elses cummins tunes
10-3-TJ is offline
post #175 of 544 Old 08-29-2012, 11:47 PM
tdij
Well... hood scoop is an easy fix... I almost did it to mine.
As far as the mount/control arm goes....
I know that upper is short... but could you make a custom shaped link to work within the clearances?
Radius arms... easy but not cheap solution. You'll love the long arm if you wheel much though
you could 3 link it?
Do you need the travel? Could you just bump stop it appropriately? I don't know what your intended use for the jeep is... do you need that up-travel?
Lift it to gain more clearance?
tdij is offline
post #176 of 544 Old 08-30-2012, 09:57 AM
CumminsYj88
CumminsYj88 is offline
post #177 of 544 Old 08-30-2012, 09:57 AM
CumminsYj88
Hood scoop sounds like your only bet.unless you got a different manifold to lower turbo..you would have to come up with a new intake idea but it may be worth it..and if you lower your turbo you could throw an intercooler on it,so it all goes around the engine instead of over top.you would have plenty of room if you went with an intercooler.plus if you had to put your air filter out side of the cowl.maybe the cooler would do just as good as the cold air intake.
I don't have much of an idea for your arms.if you don't need a lot of travel,might not be a big deal if your just doing mild off roading and street driving,although a long ARM would be a great upgrade,I guess it just all depends on how much time and money you want to spend.
post #178 of 544 Old 08-30-2012, 06:25 PM
ksilovich
Check out this hood scoop.
http://www.summitracing.com/parts/SUM-471520/
This guy has a 4bt also, and it is where I got my inspiration from. He only lives like 30mins from me.
If you dont want to do a hood scoop. I would say your best bet is to use a slanted intake manifold similar to mine. I not sure how it would change your exhaust tho. Like cumminsyj88 said you would be able to add an intercooler to is also.
I threw on in my grill but I know my friend has a cummins 3.3 and he used one off a Volvo. Ill have to post a photo of my cooler lines when I am done. but here is my friends 3.3 lines. There a little blurrly but you get the point.
And this is my others friends 3.3 cummins.
maybe some of this will help, if not i tryed
Jeffery 2.0 : Cummins 4bt, 40's, ORI's, D60, 14B, lots of AL
ksilovich is offline
post #179 of 544 Old 08-30-2012, 06:27 PM
Bojon
1981 CJ5
BOJON
I've got a build thread in my sig, ground up, it will be a while before anything gets fired up.
There should be one wire on the fuel pump that you need to supply 12v to for it to run. Then when you want to kill it you just cut the power to that switch.
Jered
Bojon is offline
post #180 of 544 Old 08-30-2012, 06:45 PM
robphillips00
2009 JK Wrangler
If your going to have to put a hood scoop on it, why not consider raising the motor mounts?
robphillips00 is offline
4bt , cummins , tj
Diesel Cummins 4BT TJ doc_dyer Jeep Builds 174 12-29-2013 04:10 PM
Show me your Cummins! Ptr Jeep Picture Requests 37 09-03-2013 02:37 PM
Cummins 4BT YJ TimP Jeep Builds 5 10-25-2011 04:11 PM
looking for used 4bt cummins engine bobbyp10 Jeep Builds 3 03-02-2010 01:51 PM
Cummins Diesel ralf Jeep Builds 6 03-02-2010 09:44 AM
