08-16-2012, 10:54 PM
#136
Cycleguy04
The picture with the mount and bolt length was taken with the bolt being held with only a couple threads. It wasnt holding anything but itself.
The actual mount will be approximately 1 inch lower. Although jeff daniels recommends mounting the mounts towards the top of the bolt to help absorb vibrations.
"We have enough youth, how about a fountain of smart"
"Look no further than yourself, for all of the good and all of the evil that exist in this world, resides in the heart of man and his propensity to use it".
08-16-2012, 11:10 PM
#137
GADUCKER
The pictures truly dont do the actual mounts justice. They are beefy, although your concern has made me consider putting triangle piece of steel in the front and back of the frame side mounts.
Tonight i was able to get the mounts tacked in and the engine test fitted. I couldnt be happier with how they turned out. Tomorrow i plan on finish welding the mounts and then start on the clutch.
Now if i could turn this damn t.v. off. Hatfiels and McCoys are on the history channel.
08-16-2012, 11:12 PM
#138
Cumminsyj88
Thanks man.. I am getting very excited about getting this thing in and running.
08-17-2012, 12:05 AM
#139
Uncollegemated.
You have good taste. That's an awesome show!
Sent from the far reaches of space.
'98 TJ, 3.5" RE, 33" BFG M/T's, Yukon 3.73's, open front, ECTED rear, ARB front bumper, Warn winch, Warn rear bumper with tire swing, 8.8 on it's way.
The only reason people get lost in thought is because it's unfamiliar territory.
08-17-2012, 08:04 PM
#140
The 4BT looks made to fit!! haha Keep us up to date!
JEEP
Just Emptying Every Pocket
08-18-2012, 07:46 AM
#141
Are you using a hydroboost for the brakes?
08-19-2012, 04:25 PM
#142
Okay guys. I made some more progress on the jeep. I have my engine mounts all welded up. I know a guy who works with the local natural gas company. He welds the steel pipes together that are under ground . He suggested that i make three passes of welds. First. Pass down the middle and the second and third down each side of the first weld.
It worked out nicely. My welds are nothing to write home about but u am sure they are plentu strong .
After i did the welds i moved onto the clutch. After cleaning the flywheel i test fitted the clutch. Well the darn clutch tool needed to be turned down on the end in order to securely fit into the flywheel centering hole. So after doing that the tool fit right in and the clutch went went on pretty simple .
Now to the throw out bearing. I am bot really sure about how this goes. Gonna have to start reading.. hopefully engine will be bolted in for good tonight.
08-20-2012, 07:01 AM
#143
What kind of clutch did you go with?
95 YJ 2.5 4 banger with 4"rancho lift on top of 33x12.5/15
08-20-2012, 02:07 PM
#144
08-20-2012, 11:29 PM
#145
Maybe this was covered but I cannot remember cause I read this thread in three seprate sittings but what coils are you going to go with up front? Are you going to have to have some made or are there some that fit that will take the extra weight? Or are you going to make something fit?
Also I really love this build. I am a diesel guy. I am sad I don't dd one. Someday though, maybe I can use this as a guide! Keep up the good work and the updates!
08-21-2012, 01:00 PM
#146
Very Cool!
1982 CJ5, Corvette 383... project
08-21-2012, 03:01 PM
#147
Uncollegemated.
Didn't Jeep sell a diesel liberty?
08-21-2012, 03:52 PM
#148
Subbed. Awesome thread and thank you for documenting this
08-22-2012, 05:02 PM
#149
Okay guys i have gotten a lot done since the last post. First off lets answer some questions..
The clutch is a centerforce heavy duty ford clutch. The throw out bearing that i was concerned with is completely fine.
I am sticking with my rough country coils right now. Actually the jeep sits no lower now with the engine in as it did before. I may buy a set or 4 inch springs and a long arm down the road. I have a feeling that my up travel may be limited because of the motor mounts. Absolutely nothing i can do about that now until i drive it and see what happens.
Now with the updates.
I got the engine all bolted up with the clutch installed.
As you can see in the picture i had my intake mocked up. I am using a 3 inch mild steel pipe with a 180 bend. I am going to use a Spectre inline airbox which will draw truly cold air from inside the cowling. I then plan on running a cowl scoop.
08-22-2012, 05:10 PM
#150
