Quantcast Orange Peel - Buggy Build - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Orange Peel - Buggy Build
Old 12-31-2009, 12:03 AM   #1
mferrari
DelmarvaOffroad.com
mferrari's Avatar
Delmarva Offroad - Orange Peel - TJ Buggy Build
2011 SEASON REBUILD STARTS ON PAGE 16
Figured it deserved its own thread... Here is the old thread of how I got to this point from a bone stock Jeep in 4 years I think.
http://www.jeepforum.com/forum/f9/slow-mo-tj-build-540449/
Here is what I am starting with. 98 TJ. Stretched 2 inches, 44 and 30. Teralow. Locked Front and Rear with 36" iroks. 2" of lift in the front, no lift in the rear.
The build...
Double triangulated 4 link rear, 3 link w/ pan hard front. HP60, 14B. 5.38s. D300. 39.5" Rockers. Tube from the seats back and from the motor mounts forward.
Started with hacking the tub:
Lost the little axles:
HP60 with the truss on it:
Started to shave the bottom of the 14b:
Axles waiting:
Plasma cutter came in so I began chopping the frame:
Tubing arrived:
Took the "body" off to start on a tranny mount and finish cutting and capping the frame rails:
Capped the frame, then put the body back on to get final measurements for the chassis:
Start of the layout on the new chassis:
And that is where I leave you today. Tomorrow I need to finish the tranny mount, then going to start bending for the chassis!
Michael Ferrari
TJ Based Buggy <BUILD THREAD>
Team 120 - DOR Racing - Racing for Operation Homefront
Thanks to our Sponsors:
Delmarva Offroad - F-O-A Shocks - BD Turnkey Engine - Under Cover Fab - Jer-C Transmissions - Quigley Driveshafts
Operation Homefront (OHF) provides emergency financial and other assistance to the families of our service members and wounded warriors.
Delmarva Offroad
You call it rolling, we call it R&D! 443-951-JEEP
mferrari is offline   Reply With Quote
Old 12-31-2009, 12:17 AM   #2
SnowYJ
Pavement Pounder
SnowYJ's Avatar
holy crap, look sgood
Account kindly upgraded out of pure kindness! JeepForum is like a second family.
Originally Posted by Slickbr View Post
Rules for the JEEP:
1. Yes, the suspension is same design as a covered wagon, & so is the soft top; it worked for the Cowboys & settlers.
SnowYJ is offline   Reply With Quote
Old 12-31-2009, 12:20 AM   #3
mferrari
DelmarvaOffroad.com
mferrari's Avatar
Thanks, sorry for the mess in the shop. Working on a cage for one customer and axles for another along with my personal buggy. I need a bigger shop
Michael Ferrari
Delmarva Offroad
Old 12-31-2009, 12:33 AM   #4
uvalax236
Looks awesome! Keep up the great work!
06 Solar Yellow AT
Banks Headers, ARB Periscope, Clayton LA/TT,
Coast 1350 Shaft, JKS BL/BMML/Quicker Discos/Adj BumpStops,
RE 4.5 Springs/BrakeLines/HD TB, Currie Steering, VVME 3000k, 6000k HID Systems, IPF H4 Headlights,
315/75/16 Nitto Terra Grapplers on Moab's, 5.13's and TruSpeed
uvalax236 is offline   Reply With Quote
Old 12-31-2009, 02:44 AM   #5
rs4race
I finally get to see the beginning of one of these builds! One question tho. Why hack up everything? Looks like you have tons of material, besides the body why not make a new frame that you can bolt the body to?
Its just something Ive always wondered with these builds.
rs4race is offline   Reply With Quote
Old 12-31-2009, 09:21 AM   #6
00jeepsahara
nice build. Like the new cage design. What are you planning for suspension?
Are you also using the stock d300 casing? Have you looked into STAKs replace a case. Works great when your flipping a 300.
2000 Jeep Wrangler Sahara
113" Wheelbase
42 Iroks
17" Allied Beadlocks
D60/14BFF
00jeepsahara is offline   Reply With Quote
Old 12-31-2009, 10:51 AM   #7
mferrari
DelmarvaOffroad.com
mferrari's Avatar
Originally I was planning on using more of the tub than I am going to end up using so I just decided to cut it all up. I also was thinking about selling the Jeep as a whole and starting from scratch but there was no way with the economy the way it is that the Jeep would have sold so I parted out what I wasn't using. Since I had the frame it made an easy starting point to work with. Plus now I can still say it's a Jeep
Michael Ferrari
Delmarva Offroad
Old 12-31-2009, 10:54 AM   #8
mferrari
DelmarvaOffroad.com
mferrari's Avatar
Suspension will be double triangulated 4 link in the rear. Front will be a 3 link w/ pan hard (not going full hydro at this time). Both should sit on 14" air shocks but waiting to get the chassis sqaured away before I order them.
Right now I am still deciding on using the stock casting or using a Stak case for it. I am more leaning towards using the stock case because within a year or 2 I want to get a 3 speed case.
Going out to the shop to finish up some axles for a customer and then gonna spend osme time and start on the chassis today.
Michael Ferrari
Delmarva Offroad
Old 12-31-2009, 11:23 AM   #9
Imped
TITS
Imped's Avatar
Awesome! Thanks for posting.
OlllllllO
Float Test Build
IndyORV
Best served cold
Imped is offline   Reply With Quote
Old 01-01-2010, 11:06 PM   #10
mferrari
DelmarvaOffroad.com
mferrari's Avatar
Spent some time today trying to figure out what to do with this D300. I broke out the bandsaw and cut down the old shifter crap:
Ok so now that made a little more clearance for the mount. But the next problem... The driveshaft and shifters. Looks like I am going to need a 2 piece shaft to fit around the transmission. Also may run into some trouble with clearance for the shifter but I may be able to work around that...
Shifter clearance:
Top View:
Back w/ "driveshaft":
Also while I had the D300 apart, I decided to grind the shift rail to allow me to use 2wd High in the Front with the rear in N.
Before (Marker is where you grind to):
Afer:
Also bent the first tubes for the chassis... The slider pieces to weld on the frame that will run right along the tub line.
Michael Ferrari
Delmarva Offroad
Old 01-01-2010, 11:14 PM   #11
Unlimited04
Unlimited04's Avatar
looks like you've got quite the shop there! how big? what kind fancy fab stuff you got?
nice work btw
Unlimited04 is offline   Reply With Quote
Old 01-01-2010, 11:38 PM   #12
wrangler2007
Looks nice
Other Vehicles:
07 Mustang, Whipple, 465 rwhp, Magnaflow, Hurst , AVIC D3, Spec 3+, BMR CA's, Autometer, FRPP Springs
08 F150 5.4L, Super 40 SIDO, Roush Grille, Edge Evolution, Truxport, 2.5" AS Level, 1.5" AAL, 35x12.5x20 Nitto Trail Grapplers
wrangler2007 is offline   Reply With Quote
Old 01-01-2010, 11:42 PM   #13
MO2500
Fabramicator
MO2500's Avatar
Looking good
Can't wait to see it when you get some more of that chassis bent up!
My Build Thread
Useful links:
Stu-Offroad - great technical write-ups!
What's a CV shaft and why do I need one?
Driveline 101
TJ Specs
-Mike-
MO2500 is offline   Reply With Quote
Old 01-01-2010, 11:57 PM   #14
mferrari
DelmarvaOffroad.com
mferrari's Avatar
Thanks for the comments, feel free to ask questions on here as well and I can answer stuff as I go along.
As for the shop it our new 30x30 I just built a couple months ago but already way too small... And the fancy fab stuff? The basics; welders, plasma, bender, notcher, grinders, torches, myself
Most of the chassis is going to be on hold until I can get the the t-case and driveshaft sqaured away. Its alot easier to work on it right now with the body off, but I need to put the body back on to get the chassis fitted in and welded up.
I'm on the search for a Yota 2-piece shaft right now. Once I find that I am going to finish the mock up on the tcase and all. Should end up similar to this:
Michael Ferrari
Delmarva Offroad
Old 01-02-2010, 12:04 PM   #15
97casteeltj
this is awesome!
needing a new rig....
97casteeltj is offline   Reply With Quote
Glock Forum
