Operation Blackout YJ - Page 6 - JeepForum.com
post #76 of 128 Old 10-30-2013, 10:37 PM Thread Starter
hokusi
Had a leak in the fire wall and turns out ( I know what a shocker) the clutch master was leaking. I guess that explains why my shifting has been getting alittle rough. Removed the old piece of crap and put in a new one.
Also found a tranny mount in decent shape. Should be here in a few days. My current one is rusted out in 2 of the three mounting spots in the passenger side. Will feel much safer when replaced. Hopefully all the jolts don't break when I try to take them out.
My slo
build thread:
http://www.jeepforum.com/forum/f22/operation-blackout-yj-1410573/
hokusi is offline
post #77 of 128 Old 10-30-2013, 10:39 PM Thread Starter
hokusi
Time for alittle stretch. These finally came in. Lets see when I can get some time to install them.
My slo
build thread:
hokusi is offline
post #78 of 128 Old 11-05-2013, 11:33 AM Thread Starter
hokusi
Removed my tranny mount/skid this weekend and 4 out of the 6 bolts broke off/nutsert spun free. Also found a few small holes in the frame around the bolt holes. I Cut out the rusted parts and and broken bolts. Will weld in patch pieces with grade8 nuts welded to the insides.
While removing the skid i also found that on the passengers side 2 of the three bolt holes on the skid had rusted all the way threw so there was only one bolt on that side holding up the skid. Found a skid for sale in the forum classified section and plan to install it this weekend after all the welding is done.
My slo
build thread:
hokusi is offline
post #79 of 128 Old 11-27-2013, 11:41 AM Thread Starter
hokusi
Patch pieces and nuts welded in. Just have a bunch if grinding and painting and my skid problems are fixed.
My slo
build thread:
hokusi is offline
post #80 of 128 Old 11-27-2013, 03:40 PM
greenyj95
Rust is a killer.
greenyj95 is offline
post #81 of 128 Old 11-27-2013, 09:34 PM Thread Starter
hokusi
It is. In the process of bringing it back from the dead.
My slo
build thread:
hokusi is offline
post #82 of 128 Old 05-05-2014, 02:10 PM Thread Starter
hokusi
It been awhile since I have posted here but I have been slow with progress on the YJ. Currently the jeep is at a friends shop getting a customer roll cage made. Its taking foreverrrrrrr (almost 2 months) but one can not complain when calling in a few favors gets you a free roll cage. I hope it will be done in another week or two.
In the mean time I have started on the 8.8. Currently have the brackets grinded off, tubes cleaned down to metal, and started replacing the axles bearing and seals. The gears and axles look fine so I will reuse them for the time being till I get my 44 rebuilt for the front then I will upgrade the axles, carrier and gears. I also was able to find a good deal on a 4cyl D30 front axle to match the gear ratio of my 8.8 (410's). Cheap way to get through the summer till I get the 44 done.
My slo
build thread:
hokusi is offline
post #83 of 128 Old 05-05-2014, 02:14 PM Thread Starter
hokusi
Now I know by no means is my truck all that tall (on 33's) but this picture just makes mine look tiny. This is my jeep parked next to my friends truck when I dropped it off for the cage.
My slo
build thread:
hokusi is offline
post #84 of 128 Old 05-12-2014, 11:02 AM Thread Starter
hokusi
The cage is officially started finally! It's just starting to get warm out and I am dying to get the jeep on the road again. The JKU is nice but I miss the YJ. Hopefully another few days it will be do e and just need paint.
My slo
build thread:
hokusi is offline
post #85 of 128 Old 05-12-2014, 03:03 PM
skyj
looking good I really like the cage.
build thread:
skyj is offline
post #86 of 128 Old 06-03-2014, 08:42 PM Thread Starter
hokusi
Slowly coming together.
My slo
build thread:
hokusi is offline
post #87 of 128 Old 06-05-2014, 03:32 AM
Jeep_Porn
Junior Member
looking great!
Jeep_Porn is offline
post #88 of 128 Old 07-10-2014, 08:47 PM Thread Starter
hokusi
Cage is finally done. Just needs some paint now.
My slo
build thread:
hokusi is offline
post #89 of 128 Old 07-12-2014, 01:01 AM
Aaleck
2011 JK Wrangler
Starting to look good! Rust sucks.
Aaleck is offline
post #90 of 128 Old 07-13-2014, 08:36 AM Thread Starter
hokusi
Yes rust sucks and never seems to end.
Painted the roll Bar today. Went with vht epoxy satin black. Never used this paint before do let's see how it holds up.
My slo
build thread:
hokusi is offline
project blackout #2 01blackout Jeep Builds 1 06-19-2012 03:29 AM
01 60th blackout! finally!! 01blackout Jeep Builds 127 04-09-2012 05:41 AM
CJ5 Operation - More Leg Room turpehar Jeep Builds 7 07-13-2010 08:09 PM
Operation Blackout - my ZJ's build thread Black95ZJ Jeep Builds 21 02-07-2010 03:00 PM
Blackout!! (56k NO!) YJ_ Jeep Builds 10 02-26-2006 01:35 AM
