Quantcast The "One Amongst The Fence" Build - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > The "One Amongst The Fence" Build
Old 09-07-2009, 08:25 PM   #1
TimeConsumer
well, after lurking for a long while, and gathering 25+ posts I guess its time to make a build thread.
Starting out, my base plan was as follows:
2.5" RC spring lift
1.25 JKS Body lift
Cragar Soft8 - Black - 4.0 BS
33x12.5R15 Goodyear Duratrac
I would add what I started with, but anyone interested in reading this is no doubt uninterested in reading about another 06 Wrangler, 4.0, X, blah blah blah
Sadly, my front tires gave out before I could get everything together along with the funds to begin my project. So I opted out for some 31x10.5R15 Duratracs (thanks 2006sport) and a 2" BB I got off craigslist. As always, a thread is worthless without pics:
Now the biggest question is: do I continue my effort to 33s? or set aside parts and build to 35s? I know it takes a lot more to correctly run 35s but i've always liked the look. Anyone have any regrets with doing either size?
P.S. Mad mad props to anyone who understands the title
Is it the dream that one day you might be something you're not?
TimeConsumer is offline   Reply With Quote
Old 09-07-2009, 08:28 PM   #2
2006_Sport
thanks for the props for the tires ahhaa.
I would wheel for a while and see what exactly you need as far as tire size and lift height goes. See what your limitations and the rigs limitations are and build from that. Jeep looks good btw
SUPPORT THE TROOPS
2006 Jeep Wrangler|BDS|BFGoodrich|Uniden|Upol|HiLift|Cragar| Hella|Alpine|JKS|PoisonSpyder|Delta|Aussie Locker|Bluetorch Fab|Novak|Trail Gear
-Zach
2006_Sport is offline   Reply With Quote
Old 09-07-2009, 09:02 PM   #3
kale2s
Nice Jeep, Ive always liked that color.
Y2K TJ with some stuff.....
kale2s is offline   Reply With Quote
Old 09-07-2009, 09:04 PM   #4
1997_Sport
You can go ahead and thank me about those tires. haha
But i say go with the 35s, and wait and get everything needed.
-Mike
I aint got the jeep no more, but I have a 91 f250 turbo diesel!!! :D
1997_Sport is offline   Reply With Quote
Old 09-16-2009, 08:57 PM   #5
AlTheKillerr
another coheed build! hell yeah
gotta say i regret taking the 33 step between my 31s and my 35s. waste of time and money. i was happy with it for a while but realized its not where i wanted to be.
AlTheKillerr is offline   Reply With Quote
Old 09-16-2009, 11:23 PM   #6
_TIM_
If you want to run 35s, build the jeep for 35s. You don't want to get it set up on 33s and a month later want the 35s
1998 tj|chili pepper red|
_TIM_ is offline   Reply With Quote
Old 09-17-2009, 12:01 AM   #7
Brandon97TJ
There is no "setting up" for 35's. All there really is to do is the lift (at least 4") and gears. And that's it. If you do heavy trail riding you may want to consider a v8 Grand Cherokee steering set-up. That's all I started with and I was PERFECTLY fine with 35's.
Brandon97TJ is offline   Reply With Quote
Old 09-17-2009, 12:05 AM   #8
2006_Sport
Don't forget brakes.
SUPPORT THE TROOPS
-Zach
Old 09-17-2009, 12:07 AM   #9
AlTheKillerr
and stronger axle upgrades. brakes is debatable and im sure ill catch **** for this but my stock brakes are doing great with 35s. in the future i will upgrade em to vanco though
Old 09-17-2009, 08:16 AM   #10
_TIM_
My point was, you don't want to lift the jeep 3in to squeeze 33s and gear it for 33s just to decide to rip the lift out for a taller one and change the gears to lower ones. Just do it once.
Old 09-17-2009, 08:33 AM   #11
TimeConsumer
Thats the deal, I trust my life to my jeep more than once every day. If im going to put something that big and heavy (35s, or hell, even 33s) I want to make sure I didnt cut corners in doing so. That mindset then spreads out to what you apperently must replace in building in a direction. And the gears thing I really only want to do once, doesn't seem like the most interesting way to spend money.
So while this 33 vs. 35 debate burns on, I cant decide what to replace this BB with.
And within the next few weeks a cobra75, hardtop and matching spare will be added.
Old 09-24-2009, 03:18 PM   #12
wahoojeep
I made many mistakes along the way with my build.
Decide how big you want to go, and do it one time.
I've had 31's, 33's, 35's, 37's, and now 39.5's.
It is truly sad how much money I wasted getting to the point where I am now.
One Ton LJ Build Thread
RCPFA
2005 LJ, 2007 JKU, 1978 J10
wahoojeep is offline   Reply With Quote
Old 09-24-2009, 04:14 PM   #13
Brandon97TJ
If you are looking for a cheap decent lift, the Rough Country long-arm is starting to look promising. And around $1,300 you can't beat the price. Keep in mind that 4" is more than enough to run 35's if that's what you're aiming for
Old 09-24-2009, 05:05 PM   #14
Imped
TITS
Imped's Avatar
I went through the same dilemma as you. I opted to go to 35's. I started out with D30/D35 and 3.07 gears just like you. I knew that I was going to swap the axles and regear regardless. Is this in your plans? Either way, I would also look into steering and brake upgrades. So why not go 35's? I'm running 35's on the same components as your base plan, FYI. Plenty of lift for 35's if you do it right. Nice looking rig. Let me know if you have any questions.
OlllllllO
Float Test Build
IndyORV
Best served cold
Imped is offline   Reply With Quote
Old 09-24-2009, 06:11 PM   #15
FknStn
1952 CJ3A
Nice clean rig, lets see some upgrade pics
FknStn is offline   Reply With Quote
Glock Forum
