nUcKiN fUtZ's WJ build - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > nUcKiN fUtZ's WJ build
WIN a Rough Country Forged Track Bar - ExtremeTerrain!FS: Wranger BRIGHT License Plate LED! Just $3! Great valueTime To Save On Yukon Lockers!
Unread 04-03-2014, 07:09 AM   #1
nUcKiNfUtZ
2003 WJ
In February of 2012 I bought my first Jeep, a 2003 Onyx Green limited with the 4.0 and quadradrive.
For nearly 2 years nothing was changed on the truck.
Then in October 2013 I bought a 6.5” critical path kit from IRO
After laying all the parts out I honestly thought I was in over my head. The most I had done mechanically before this was brakes.
But after a little bit of liquid courage I got started
Before I knew it the rear was almost done, I was running 2” wheel spacers before I bought my new wheels.
Rear done, took the entire first day
The front was way more rusted and difficult, and involved much more swearing. No pictures at all were taken while doing the front lol.
All done.
At the shop getting aligned for the first time with the lift on it.
The next weekend I took it to my buddies garage and used his lift to re torque everything
My buddy got me this because I’m always raggin on him for owning a Nissan
Found a stock one to compare with (sorry for the bad pic, it was raining)
After installing the lift kit I spend nearly 3 months chasing down thumps and clunks in my suspension, by the time I got it riding nice I had installed:
All 8 coil spring isulators
IRO barpin eliminators
IRO steering equalizer kit
KOR rear shock sleeve kit
JKS adjustable track bar
JKS HD tie rod w/ tre’s
JKS HD drag link w/ tre’s
JKS quick disconnects
ADDCO rear sway bar w/ greaseable bushings
New front sway bar bushings
Replaced IRO long arm flex joints with Johnny Joints
Not much else happened over the winter, got lots of salt on her.
February 2014 I installed a set of bushwacker flares and a set of steel 17x8” wheels w/ 4” of backspacing
Got more salt on her
I have a set of 4xguard rock sliders that I’m waiting on warmer weather to install. Since I have the flares on my truck, the sliders need to but cut, welded, and repainted.
Thats all for now.
I'm starting to think my parents didn't buy me enough tonka trucks as a kid.
nUcKiNfUtZ is offline   Reply With Quote Quick reply to this message
Unread 04-09-2014, 03:07 PM   #2
nUcKiNfUtZ
2003 WJ
Today I finished installing my CB. Wish I could say it was original, but it came straight from the forum
There don't seem to be any pics of this so heres how I trimmed the dash
With that cut out the radio sits nice,
The Firestik mount is just a scrap piece of steel above the tail light, nothin fancy
The 4' antenna is a bit taller than I expected, lol idk if I can go to taco bell anymore, maybe a 2' is in order for daily driving
Since it was only 10 bucks I threw in a PA speaker. My buddies already have a pool started to see how long it takes me to get arrested
It will probably get moved for a washer bottle swap eventually.
Here's how shes sittin now
Unread 04-11-2014, 12:59 PM   #3
nUcKiNfUtZ
2003 WJ
Got my 40" LED light bar and 4x4 fabworks brackets in the mail, the brackets require no drilling at all so the install was sweet and simple, very highly recommend these!
Didn't like the idea of drilling a hole in the roof or running the wires all the way to the back and then under so I went the easy route inside the door frame.
Really happy with how simple this went. Wired and working in an hr. Will post some night time shots later on.
Unread 04-12-2014, 01:20 AM   #4
nUcKiNfUtZ
2003 WJ
Factory low beams:
40" Light Bar:
honestly the pictures don't do it justice
Unread 04-12-2014, 05:48 PM   #5
JamieMCC
That's a bad *** rig man. How did you readjust your speedometer and Odometer? How much did the bigger tires change your Speedo and Odo?
JamieMCC is offline   Reply With Quote Quick reply to this message
Unread 04-12-2014, 07:53 PM   #6
nUcKiNfUtZ
2003 WJ
Thanks man! Speedometer is off about 10% at any given speed. Haven't done anything about that yet. Not a big problem since my in dash GPS has a speedometer always showing. Eventually I would like to get a superchips tuner to set the tire size correctly among other things.
Unread 04-28-2014, 02:01 PM   #7
nUcKiNfUtZ
2003 WJ
Got my rigid flush mount dually D2 knock offs installed. So far so good. These lights are such a copy of the rigid lights that the rigid accessories work with them. Cheap ebay lights and rigid 15 degree angle mount adapters
Bright as hell! Ill try to get some night time shots later
I also started on my rock sliders. They are 4xguard sliders which are meant for a stock WJ in good condition. Going to be alot of cutting and welding to get these around my flares and get them reinforced to the frame rails because of all my rot from the awesome salt we have on our roads 8 months out of the year. but heres what I have so far
need to weld this piece I made in to wrap around the flares and protect them
More work and pics to come in the following weeks. Turkey hunting opens this week so that will slow down some of the work for the time being.
Unread 05-16-2014, 09:04 PM   #8
nUcKiNfUtZ
2003 WJ
got some new parts this week, going to be a good weekend
NV242 TC Swap and new rear DS
IRO TC Skid
IRO HD Crossmember
going to be eliminating my TC drop bracket at the same time
Unread 05-18-2014, 10:20 PM   #9
JeepinAaron
2003 WJ
How rugged would you classify those sliders? Would you drop down on them hard on rocks? I have been doing research on them but haven't found any example of someone beating on them. My WJ rockers are in good condition, no rot.
2003 WJ Laredo
http://www.jeepforum.com/forum/f22/2003-wj-off-road-minivan-2346505/#post22320625
JeepinAaron is offline   Reply With Quote Quick reply to this message
Unread 05-19-2014, 10:01 AM   #10
nUcKiNfUtZ
2003 WJ
Even with how rotted mine are I was able to jump up and down on them and use a high lift to jack up the whole side of the truck. It would be even stronger with a good set of rockers.
Unread 05-22-2014, 07:34 PM   #11
nUcKiNfUtZ
2003 WJ
Got the 242 swap done and the new cross member in. Really happy with how easy it all went and the clearance that the crossmember gives
IRO TC Skid this weekend hopefully
Unread 05-28-2014, 07:44 PM   #12
nUcKiNfUtZ
2003 WJ
Picked up the new rockers/floor boards that I had made. Pulled the Sliders off with some help from the little man and then cut the old rusted rockers out.
Unread 05-29-2014, 07:35 AM   #13
Mark-318-IT
this is one bad as* wj! compliments
Mark-318-IT is offline   Reply With Quote Quick reply to this message
Unread 05-29-2014, 04:56 PM   #14
nUcKiNfUtZ
2003 WJ
Thanks!
Unread 06-25-2014, 11:38 PM   #15
nUcKiNfUtZ
2003 WJ
Done alot this past 2 weeks, Plasti dipped my bumpers, flares, cladding, gas door, and rear hatch
Then I installed new headlights and tail lights, along with a 55w 6k HID kit for the projectors
So far I'm likin it, when the plasti dip starts to wear I'll probably paint everything permanently.
