Noob Build - Page 45 - JeepForum.com
 6Likes
post #661 of 1053 Old 01-02-2014, 07:47 AM
OkLaHoMaTJ
Originally Posted by Holaday View Post
Thanks man I really appreciate it. The mounting brackets had to be modified slightly to work with the rails, but it was just a notch in the Genright mounts
Can you post a few pics of the modified brackets? I want to ditch my Exogate and Savvy rear bumper for something with less overhang and that will hold a 37'' tire.
My Thread - http://www.jeepforum.com/forum/f22/another-lj-rubicon-thread-1516486/
OkLaHoMaTJ is offline
post #662 of 1053 Old 01-02-2014, 08:08 AM Thread Starter
Holaday
Couple pics. Some of the group will probably post theirs too though
Holaday is offline
post #663 of 1053 Old 01-02-2014, 08:10 AM Thread Starter
Holaday
And finally made it to the knob.
Holaday is offline
post #664 of 1053 Old 01-02-2014, 10:01 AM
G Beasley
So Washi ta is still open ?
G Beasley is offline
post #665 of 1053 Old 01-02-2014, 02:13 PM Thread Starter
Holaday
Once a month it is.
Last ones:
Fun little notch at the top of Wa$hita.
Always just got wedged in there in the past
Hopefully it warms up in the next week. I need to change all the fluids, adjust parking brake, figure out the hydro assist before Flat Nasty
Holaday is offline
post #666 of 1053 Old 01-02-2014, 02:18 PM
janesy86
Nice work on that notch! Looks like fun!
03' Rubi: 2" BDS, 1.25" BL/MML, Hylined rollin' on 35" MTR's
janesy86 is offline
post #667 of 1053 Old 01-02-2014, 02:27 PM
AngryTJ
Originally Posted by janesy86
nice work on that notch! Looks like fun!
x2
AngryTJ is offline
post #668 of 1053 Old 01-02-2014, 09:30 PM
G Beasley
x2
X3 That looks like a sick line .
post #669 of 1053 Old 01-03-2014, 06:26 AM Thread Starter
Holaday
Crap I completely forgot to do this last night. I will get pics when I get off work tonight
Holaday is offline
post #670 of 1053 Old 01-05-2014, 08:41 AM Thread Starter
Holaday
OK TJ: Here is the Genright Bracket. It is supposed to have 4 bolts, but I am only running 2 because I butchered the bracket. Been running them for 18 months with no problem. I am going to order a new set so I can get a third bolt in. There is a high and low set on the stinger, but with the rails you can only run the lower setting. I have the aluminum one, so you can tell it bent when I slid into a tree last weekend and bent the tabs. a hammer fixes it though and the stinger goes right back into shape.
Hope this helps and let me know if you need any other pics.
Holaday is offline
post #671 of 1053 Old 01-05-2014, 11:17 AM
OkLaHoMaTJ
Perfect. The 2 mounting positions you're referring to are on the bumper correct? I see what you're saying there. 2 bolt holes, one higher, one lower, you use the lower one and then modded the bracket. I would feel more confident with the 3rd bolt in there too but I guess its working fine.
One more question. Is it a pain in the *** folding up and down the carrier with a tire in it? Mine isn't a daily driver and the only time I really open the back is for the dogs.
I like the idea of being able to take the stinger off with just 2 bolts and running no spare.
post #672 of 1053 Old 01-05-2014, 03:03 PM Thread Starter
Holaday
Correct, on the bumper. I could not figure out how to run it on the higher without cutting the tub rails, and that was not going to happen. I got Nylock nuts from Fastenall and check them religiously, but a 3rd will make me feel more comfortable.
Not really, but I don't run a top unless I have my kid with me and conditions require it. It takes slightly longer than my old swing out, but the advantages far outweigh the extra hassle for myself.
This is key for me. It takes less than 2 minutes to remove the stinger and strap the spare into the back. without the spare on, the aluminum stinger is not more than 10 lbs.
Holaday is offline
post #673 of 1053 Old 01-05-2014, 03:40 PM
OkLaHoMaTJ
Thanks Holaday. I have some interest in my Savvy rear bumper and exogate so once those are gone I'll be doing this.
Do you know how much more the steel version weights compared to the aluminum? The aluminum is $$$ compared to the steel. Cheapest I've found the steel is $650 or so without the bumper plate.
post #674 of 1053 Old 01-11-2014, 04:39 PM Thread Starter
Holaday
Ordered up the TNT outboard kit tonight. For those that have done it, what shocks/length do you recommend?
Holaday is offline
post #675 of 1053 Old 01-11-2014, 06:06 PM
plumber1
Gotta get this in before the weekend
The only thing I can you see have done wrong
Bush Light really Nice looking jeep
I can quit drinking anytime I want, but hey I'm no quitter :)
White Jeep Club #224
plumber1 is offline
95 YJ NOOB build. 35s, ford 8.8, ls1 and other unknowns. m3ntal Jeep Builds 2 12-22-2011 09:32 PM
Noob build. need ideas capnsilver Jeep Builds 54 03-21-2011 09:00 AM
noob zj build (slow) awakejeep Jeep Builds 6 06-26-2010 10:30 PM
