Noob Build - Page 33 - JeepForum.com
 7Likes
post #481 of 1059 Old 07-28-2013, 08:32 AM Thread Starter
Holaday
Originally Posted by mcannon111 View Post
If you don't drive it down the interstate then you are perfectly fine with what you got. Hitting a bridge bump at 80 mph is scary as hell with bump steer. Only way I can see to fix it is a completely custom track bar but that is alot of work.
Also to get on the same page, when I say full bump I mean both sides full stuffed. I'm telling you to check because that is where I had issues and I had to limit my travel so that the tie rod doesn't go banging into the pitman arm. But I have roughly 2 inches of stretch in the front
I like to take it to work occasionally so that may be the route I take. I have been looking all morning, looks like Genright makes a good kit.
I only pushed the axle forward an inch. I checked clearances before I put the springs in with both sides stuffed. My TR is from Rock Krawler and is bent out pretty far. Not sure if this is why it cleared, but no contact on the pitman arm.
Holaday is offline
post #482 of 1059 Old 07-28-2013, 10:00 AM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
This is all the same exact stuff I have been looking into. Very tuned in.
16 Taco
87 MJ Chief in pieces
dayriesw is offline
post #483 of 1059 Old 07-29-2013, 06:26 AM Thread Starter
Holaday
Ran it on the highway last night. I wish I would have done this a long time ago. It tracks and handles great
Holaday is offline
post #484 of 1059 Old 07-29-2013, 06:32 AM
Imped
Imped's Avatar
Just wait until you have the track bar corrected. As it stands now, you've got a lot of room for improvement.
OlllllllO
IndyORV
Imped is offline
post #485 of 1059 Old 07-29-2013, 06:40 AM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
No bump steer or anything squirrelly?
16 Taco
dayriesw is offline
post #486 of 1059 Old 07-29-2013, 06:41 AM Thread Starter
Holaday
I do not doubt that. This has turned into quite the project. but compared to the original Rock Krawler setup this seems to be a huge improvement.
In your opinion is the Genright TB kit a good direction to go?
Holaday is offline
post #487 of 1059 Old 07-29-2013, 06:55 AM
Imped
Imped's Avatar
As long as the track bar is very close in length to the DL and the mounting points are parallel with the drag link's mounting points, then sure. Don't lock yourself into "kits".....you're past the point of off-the-shelf solutions being a sure solution.
OlllllllO
IndyORV
Imped is offline
post #488 of 1059 Old 07-29-2013, 07:00 AM Thread Starter
Holaday
Gotcha. Shouldn't be that hard to figure out right...
Holaday is offline
post #489 of 1059 Old 07-29-2013, 08:12 AM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
That kit is what I was looking into also. The "kit" just includes everything for you to make your own custom set up at a one stop shop.
16 Taco
dayriesw is offline
post #490 of 1059 Old 08-03-2013, 07:33 AM Thread Starter
Holaday
Fixed my pinion angle last night! Its almost weird to drive without vibrations now.
Holaday is offline
post #491 of 1059 Old 08-07-2013, 10:32 AM Thread Starter
Holaday
Buddy of mine posted a couple videos.
Holaday is offline
post #492 of 1059 Old 08-07-2013, 10:41 AM
purplepig
great videos! I had to look at your profile to see if you where in an auto or manual tranny. I was watching the first video thinking, having to work the clutch I would have just rolled back when you stopped half way.
purplepig is offline
post #493 of 1059 Old 08-07-2013, 10:48 AM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
Yeah. The give away was the brakes didnt light up when his wheels stopped moving. Looks good noob.
16 Taco
dayriesw is offline
post #494 of 1059 Old 08-07-2013, 11:09 AM
AngryTJ
That climb looks really wet and slick, cool to see you made it up
AngryTJ is offline
post #495 of 1059 Old 08-07-2013, 01:26 PM Thread Starter
Holaday
Stick would have been tough on that for sure. I had to put in a half quart of ATF for the wall
Thanks man
One of my favorite trails at SMORR. I'm in front of the Red JK. All this web wheeling is making me anxious for this weekend.
Holaday is offline
95 YJ NOOB build. 35s, ford 8.8, ls1 and other unknowns. m3ntal Jeep Builds 2 12-22-2011 09:32 PM
Noob build. need ideas capnsilver Jeep Builds 54 03-21-2011 09:00 AM
noob zj build (slow) awakejeep Jeep Builds 6 06-26-2010 10:30 PM
