Noob Build - Page 27 - JeepForum.com
 7Likes
post #391 of 1058 Old 06-25-2013, 01:55 PM
G Beasley
HP 30s make a nice strong axle , and thats a pretty fair price for it already set up and locked .
G Beasley is offline
post #392 of 1058 Old 06-25-2013, 01:56 PM
gspup
Originally Posted by Holaday View Post
Ordered an ECGS HP dana 30. With discount code and free shipping it is $1,200 with gears, ball joints, seals, bearings, and locker. All on 5 year warranty too Seemed like a good path to take.
Figure I will spend that at least getting everything else done and switched from my current axle.
I think a HP30 is a great choice especially if you never plan on going bigger than 35's.
gspup is offline
post #393 of 1058 Old 06-25-2013, 02:11 PM Thread Starter
Holaday
I hate spending the cash, that was my trailer.
Knock on wood. Plus this is the fastest possible way to get the Heep back on the trail.
Think I will have to shorten my Tom Woods DS?
Holaday is offline
post #394 of 1058 Old 06-25-2013, 04:04 PM
purplepig
That is not too bad of a price already set up. Keep us updated. I am getting ready to put 35's on and I have already been warned that my 30 will not keep up with my wheeling style. LOL
I am trying to figure out what route I should go for my axle, but still keep it daily driver friendly.
purplepig is offline
post #395 of 1058 Old 06-25-2013, 04:53 PM
LifeProof
SEMPER FIDELIS
LifeProof's Avatar
Sounds good, might have to look not that
SEMPER FI
LifeProof is offline
post #396 of 1058 Old 06-25-2013, 07:45 PM Thread Starter
Holaday
Second guessing my decision.
Might cancel and go with the g2 in the morning
Holaday is offline
post #397 of 1058 Old 06-25-2013, 07:49 PM
IEcrawlerTJ01
Don't. High pinion 30 over lp44 anyday in my book. And way cheaper. People that run the hammers out here swap rubi 44s out to hp30's constantly. Hp 30 with a full case locker should do just fine with the krawlers.
SAVVY,CURRIE,GOODYEAR
Nuff said...
IEcrawlerTJ01 is offline
post #398 of 1058 Old 06-25-2013, 07:49 PM
purplepig
^^^is that the 44? What is the difference vs HP30?
post #399 of 1058 Old 06-25-2013, 08:03 PM Thread Starter
Holaday
This is now my Nemesis
Holaday is offline
post #400 of 1058 Old 06-25-2013, 08:26 PM
G Beasley
HP30 is running on the drive side of the gear , in other words the gears are pulling themselves together where the 44 LP is running on the coast side and pushing apart . The knuckles out are the same here are some of the specs to compare .
Ring Gear Diameter 7.20 Inches vs 8.50 Inches
Pinion Shaft Diameter 1.38 Inches vs 1.38 Inches
Pinion Shaft Spline Count 26 26
post #401 of 1058 Old 06-25-2013, 09:04 PM
mcannon111
Whoever says a hp 30 ring gear is the same strength or stronger than a lp 44 is simply just wrong. Believe what you want to believe, but that's so far from the truth it's not even funny.
Have you ever had a 30 ring gear right beside a 44 ring gear? The contact patch on the 44 is damn near twice as big. Do you know how much more strength you have in your gears having 3 to 4 more teeth on your pinion? Yes they are deflecting but the casting of a 44 also has alot more strength than a 30. There is no comparison of strength I'm sorry to spoil your assumption. That's like saying a hp 44 is stronger than a Lp 60.
no doors, no top, no problems
live in sc? join OffroadSC.com
mcannon111 is offline
post #402 of 1058 Old 06-25-2013, 10:03 PM
G Beasley
Model........Ring gear size".....Max momentary output torque FT-lb
D30...............7.125.............2350 ft lbs
D44................8.5...............3460 ft lbs
Its a big difference in the max output rating, no debating that . But the HP 30 is a strong axle and holds up well to 35s .
post #403 of 1058 Old 06-25-2013, 10:08 PM
ashland82391
Realistically how often do you hear of people breaking there ring gears?!?! Lol
ashland82391 is offline
post #404 of 1058 Old 06-26-2013, 05:30 AM
mcannon111
Pretty often if you have chromos. I've watched 6 sets of 30 gears blow up now, and 2 of which were high pinion. But we are an extremely rowdy crowd.
35 inch krawlers are heavy bastards that straight hook on rocks. I don't think a hp30 will hold up if you get to hammering on it, but it might. My friend runs them on his hp jk30 and they have held up. But he has only been wheeling with them 3 times and never really gotten on it
post #405 of 1058 Old 06-26-2013, 06:46 AM Thread Starter
Holaday
After sleeping on it, I decided to stick with the HP 30 and Detroit. Hopefully it hangs in there for a while
Holaday is offline
95 YJ NOOB build. 35s, ford 8.8, ls1 and other unknowns. m3ntal Jeep Builds 2 12-22-2011 09:32 PM
Noob build. need ideas capnsilver Jeep Builds 54 03-21-2011 09:00 AM
noob zj build (slow) awakejeep Jeep Builds 6 06-26-2010 10:30 PM
