The new project... - Page 6 - JeepForum.com
post #76 of 171 Old 10-27-2010, 12:37 AM
nickagr
nice build!
nickagr is offline
post #77 of 171 Old 10-28-2010, 10:47 AM
98GP
im gona follow too...
98GP is offline
post #78 of 171 Old 10-28-2010, 06:08 PM
kabowabo
1988 MJ Comanche
can't wait to see the progress...
kabowabo is offline
post #79 of 171 Old 10-28-2010, 11:43 PM Thread Starter
red88MJ
I'll update this build again soon, I've been working on the thing pretty much every night after work and just dont have the energy to even get on lol. Its coming along though... more to come soon.
This must be a low range beer because it makes everything slower...
MY LJ BUILD...
red88MJ is offline
post #80 of 171 Old 10-29-2010, 09:06 AM
98GP
youd better eat ur Wheaties...
98GP is offline
post #81 of 171 Old 11-02-2010, 09:36 PM Thread Starter
red88MJ
Here's a massive picture update for ya... second to last crossmember is cut out, every stock bracket is ground smooth, upper coil mounts are welded in the rear, shock towers are wlded in the front, holes for mounting the frame rail brackets are drilled and crush sleeves are welded in, frame rail brackets and track bar bracket are bolted in, frame is painted, lower control arms are powdercoated and in, now measureing for all the upper control arms.
Crossmember cut out...
Everything ground smooth...
Front shock towers...
Track bar bracket crush sleeves...
Tank moved back 5"...
MY LJ BUILD...
red88MJ is offline
post #82 of 171 Old 11-02-2010, 09:37 PM Thread Starter
red88MJ
Drilling holes for frame rail brackets...
Rear coil mounts/bumpstops welded to the frame...
Frame painted...
Frame rail brackets bolted on for good...
Reid racing knuckles on the front (still have to gear)...
Axles and lower control arms under it to measure for the upper control arms...
That should keep you guys busy for a little while! lol, and remember if im not updating my build that just means im building my build. Got a lot of late nights behind me only to work more late nights in the near future but its starting to look like a jeep again.
MY LJ BUILD...
red88MJ is offline
post #83 of 171 Old 11-03-2010, 10:59 AM
mightydog78
i envy your frame, so clean and rust free
2013 JKU Sahara
Charlotte, NC / Southport, NC
Mechanical Engineer
mightydog78 is offline
post #84 of 171 Old 11-03-2010, 11:19 AM
Fischey
Incredible, love everything about this. Those wheels are sweet too.
If anyone is in the York area and wants to go wheeling let me know I'm always down!
Fischey is offline
post #85 of 171 Old 11-03-2010, 11:57 AM
IPB
Wow great progress man!
Too many toys not enough time....
IPB is offline
post #86 of 171 Old 11-03-2010, 01:29 PM
Recoil
Recoil's Avatar
1988 MJ Comanche
What kind of clearance do you have between the front lowers and the frame during uptravel?
Recoil is offline
post #87 of 171 Old 11-03-2010, 10:12 PM
BallerJeep
Sorry to sound dumb, but what are frame rail brackets used for?
"Do not go where the path may lead, go instead where there is no path and leave a trail." - Ralph Waldo Emerson
BallerJeep is offline
post #88 of 171 Old 11-03-2010, 10:15 PM
Mark4883
Those knuckles are awesome.
Mark4883 is offline
post #89 of 171 Old 11-03-2010, 10:51 PM
mallard15
Nice jeep man... consider me subscribed.
mallard15 is offline
post #90 of 171 Old 11-07-2010, 03:03 PM Thread Starter
red88MJ
BallerJeep - the Rock Krawler kits use the frame rail brackets to mount the contol arms because you cut off all the stock control arm mounts. It takes all the guess work out of positioning the contol arm mounts like some kits would have you do, perfect instant centers amd control arm positioning everytime. Also part of the kits is a 1/4 belly pan skid that ties both brackets together.
The front lowers tuck inside the frame quite a bit, i have about 7" of up travel from where the axle is sitting in the last few pics before anything comes close to contact.
MY LJ BUILD...
red88MJ is offline
'94 XJ Project DDR Jeep Builds 32 08-30-2011 09:50 PM
The TJ Project GriffTatum Jeep Builds 17 08-11-2011 01:44 PM
yj project cage013 Jeep Builds 5 08-01-2011 11:40 AM
my project YJ confusedYJTJ Jeep Builds 6 10-26-2010 08:04 PM
my 97 project andrew383 Jeep Builds 7 09-19-2010 01:08 PM
