New guy with a turbo diesel - Page 2 - JeepForum.com
post #16 of 50 Old 02-14-2014, 09:22 PM
jason280
Great conversion! How does the "responsiveness" feel compared with the stock 4.2?
jason280 is offline
post #17 of 50 Old 02-15-2014, 08:07 AM Thread Starter
diesel89yj
Originally Posted by imstillatwork View Post
too cool! Do you have plans to fuel it past the 180 lb-ft stock?
Thanks! No plans to do much to it, though I do have the fuel plate turned up all the way. It's more of a reliability build than power, lol.
Originally Posted by Dre40 View Post
Very cool build and welcome to the forum.
thanks!
Originally Posted by axxxgijoexxxa View Post
Thats awesome! I'm curious what kind of mpg you'll get with that.
Joe
Thanks, hopefully upper 20s from my research, which is 300% better than the 4.2, I was only getting 8-9 mpg
Not terrible, but it is sluggish until the turbo spools up, i can only liken it to be a little like riding a 2 stroke motorcycle,lol. Though a set of 3.73 or 4.10s would do wonders for it, I'm 99% sure it has 3.07s, which was even a little much with the 4.2, and with the the slightly higher max torque RPM of the diesel its time to find some axles out of a 4 cylinder.
89 YJ mercedes turbo diesel/AX15,4:10s,SYE,8.8, powertrax no-slip,31-10.50 BFG at KO, Ramsey RE 8000
diesel89yj is offline
post #18 of 50 Old 02-15-2014, 08:16 AM
pasinbuy
Very good write up. Thank you for taking the time.
From the looks of your profile picture is appears that you may still have your track bars attached. Do a track bar search and maybe think about getting rid of them. Your rig will be 100% better for it.
pasinbuy is offline
post #19 of 50 Old 02-15-2014, 08:29 AM
bpounds
bpounds's Avatar
Thanks for the video! That things sound friggen awesome!
Bill
Dodge did not build my Jeep.
1988 Wrangler,4.2L I-6, Howell EFI JP-1,CRT HEI Ign,AX15 ext slave conversion, Zone 2.5" lift + 1/2" booms, BFG 31 x 10.5, Bestop.
bpounds is online now
post #20 of 50 Old 02-15-2014, 08:34 AM Thread Starter
diesel89yj
Your welcome! Hope it's useful to anyone considering the swap.
I did give the rear track bar the boot when I was under it pulling the fuel tank etc. Unfortunately I'm going to keep the front one, as oil pan clearance is still tight near the diff, if I go with more lift in the future I may pull it.
post #21 of 50 Old 02-16-2014, 08:04 AM
tbart16
I can't see the pics or vid : (
'80 CJ 7 Laredo V-8
tbart16 is offline
post #22 of 50 Old 02-16-2014, 08:07 AM
Guns003
DROOOL! I love your diesel jeep! Why did you go with the 5 cyl mercedes over the cummins 4bt? Just because you had everything off hand?
1995 YJ
35" Procomp MT2s, 5.5 inches of lift, RE 4.5 XD, Bilsteins, MORE body lift, Bumpers,TJ flat fender flares, HD steering, Durango steering box, ZJ 136amp alt, Ford 8.8 Rear, 4.56s
Guns003 is offline
post #23 of 50 Old 02-16-2014, 03:52 PM Thread Starter
diesel89yj
The biggest reason is I got two diesels( the one in the jeep has a new turbo), an AX 15,new heavy duty clutch/ slave cylinder, full exhaust, and all adapters and engine mounts for $1200. Plus it was a super easy swap
post #24 of 50 Old 02-17-2014, 12:07 AM
Shadownwpa
Nice. How much time did you have in the swap itself?
http://www.jeepforum.com/forum/f22/shadownwpa-91ish-yj-build-thread-1857154/
Shadownwpa is online now
post #25 of 50 Old 02-17-2014, 09:50 AM
technologyteach
1957 CJ5
Cool Jeep, I teach across the border from you in Sparta. I'd love to do a diesel swap sometime. We make biodiesel at school from time to time.
technologyteach is offline
post #26 of 50 Old 03-02-2014, 08:59 AM Thread Starter
diesel89yj
It wasn't bad, it only took a weekend to pull the 4.2 and get the diesel mounted in, then a few weeks of working on it a few hours a day hooking stuff up.
Cool! I might drive it over that way with my brother if we make the flat fender swap meet.
Sorry for taking so long to post an update guys, finally got the gauges worked out, the oil and temp are now mechanical, so no worries there anymore.
post #27 of 50 Old 03-02-2014, 10:14 AM
Xpress
I wouldn't farkle with the stock Dana 35 rear... Dana 44 at least, just as a safety precaution with all that extra torque you have...
Great build sofar. Keep posting, diggin it!
All about that unibody life.
Xpress is offline
post #28 of 50 Old 03-07-2014, 07:17 AM Thread Starter
diesel89yj
Thanks, hoping to do a 44 or a 8.8 with a SYE so I can lose the trans drop.
I picked up this beast yesterday, a Ramsey 8000 for $160
post #29 of 50 Old 03-15-2014, 06:59 PM Thread Starter
diesel89yj
Got the winch done, fully disassembled and cleaned up/ repaired, new cable/ hook, and motor rebuilt. Now all I need is a set of of axles and lockers
post #30 of 50 Old 03-15-2014, 07:36 PM
The_Goob
Hell on Wheels
The_Goob's Avatar
well that was quick! looks good
YJoTM ~April '14 ~June '15 ~April '17
The_Goob is offline
