Project SpeedBump | Full Frame Off Resto V8 LS Swap
This is my Frankenstein build. Goal is a mild off-road rig that can be also be used to kruze the highway to the beach, or enjoy mountain views from dirt roads with the family. Then of course some weekend warrior fun. Once all the new paint is scratched enough Ill move on to phase 2 and start really hitting the bigger trails.
Phase 1: 79 F250 D44/D60, 4.88s, 37s, 5.3 sbc, xj Ax15, tj np231
Phase 2: trussed + rcv d44, tbd tcase, and a wizard's tranny
Phase 3: 40s
Temporary lift - RC 2.5 - Click Here
Durango Box Swap - Click Here
Windshield Bracket Replace - Click Here
YJ Dewire (Prior to Ripping it All Out lol) - Click Here
RMS Replace - Click Here
Custom Flat Dash Arrival - Click Here
EZ Wire Harness Kit, HEI Install - Click Here
Custom Flat Dash Install - Click Here
D44 Arrival, Begin Dismantle - Click Here
D44 Bracket Cutoff, Primed - Click Here
D60 Dismantle Begin - Click Here
Some Sweet Axle Part Purchases - Click Here
Frame Clean & Paint Begin - Click Here
Tcase Dismantle - Click Here
Novak Mounts Welded On - Click Here
Tcase Rebuild - Click Here
Axle Install - Click Here
Knuckle/Hub&Rotor/Brake Install - Click Here
Rolling Chassis - Click Here
Flywheel/Clutch/Engine Install - Click Here
79 Ford D44 Cast Perch Notch for Ubotl - Click Here
Walbro Fuel Pump Install - Click Here
Np231 Clocking Ring - Click Here
Custom Crossmember for AX15 - Click Here
Headers & Novak Mount Notch - Click Here
Body Pull - Click Here
Underbody Herculiner - Click Here
Body Drop on New Frame/Powertrain - Click Here
YJ Body Mount Nut Replace - Click Here
Radiator, Misc Engine - Click Here
MBM Brake Booster and Camaro Clutch M/S - Click Here
Radiator Bolt On Fix - Click Here
First Start - Click Here
First Drive - Click Here
Anitwrap Bar Setup - Click Here
Front Shaft Shortening - Click Here
Floor Stripping for Monsta - Click Here and Here
And Final Monsta - Click Here
Front Shaft Install - Click Here
TJ Door Swap to YJ - Click Here
Brake Booster Adjustment & E350 MC Swap - Click Here
Rear Diff Cover - Click Here
Phase 3: 40s
