Need pics of 15" wide tires - JeepForum.com
post #1 of 9 Old 05-17-2003, 04:09 PM Thread Starter
magicmudder
magicmudder's Avatar
Do any of you guys run 14.5 or 15.5 tires. And if so, can you post a picture of your jeep so I can see how it looks. I'm ordering 38x15.5x15 SSRs and just wanted to see how they look sticking out that far and see if I want to get wider flares or not. It doesn't matter about the height of your tire, I was just wondering about the width. Thanks
84 CJ7, 258, shackle reversal, 4.56 gears, lockrite , moser one piece axles, 37" SSR's
magicmudder is offline
post #2 of 9 Old 05-18-2003, 04:17 AM
foreverjeepin
Here is a pic of a friends TJ with 35x15.50-15's on a 15x12 wheel....
97 Sahara, dual tops, 4.5 Rubicon Express LA, 1" B/L and motor mounts, 33" Super Swampers or 35" MTR's, Warn 9.5ti, locked and geared, Warn bumpers at each end as well as other upgrades.
"LEAD TODAY OR BE LOST TOMORROW"
foreverjeepin is offline
post #3 of 9 Old 05-18-2003, 02:32 PM Thread Starter
magicmudder
I like. Thanks foreverjeepin. Not to sound like a biatch but do you happen to have one looking straight at the front or rear too. That's a good looking tj. (not to mention clean)
post #4 of 9 Old 05-18-2003, 04:15 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
35x15x15 TSLs (on 8.5" rims.. will swap to 10" soon).. testing the suspension after the buildup..
BESRK is offline
post #5 of 9 Old 05-18-2003, 05:42 PM
foreverjeepin
I would never call you a biaaatch........here ya go... It's the same jeep, on the left....little hard to see....
post #6 of 9 Old 05-18-2003, 07:05 PM Thread Starter
magicmudder
Thanks again foreverjeepin and thanks to you BESRK. Big Lime looks good in that picture. I had seen your pics before but I forgot you had wide tires on there. Looks great. I like the wider tire look. I was just wondering if I needed to order wider flares to make it look right but after looking at those pics, I think I'll leave it alone unless some cop says otherwise....but cops are cool about stuff like that around here so it shouldn't be a problem. Thanks again!
post #7 of 9 Old 05-18-2003, 09:36 PM
foreverjeepin
magicmudder,
Just a word of caution, if your axles are built, no problem. If not you can experience breakage. One of my other friends who runs the exact same tires as the blk TJ has gone through a few axle shafts already on his YJ. Those tires look great and do well off-road, but are hard on the drive train.....JP
post #8 of 9 Old 05-19-2003, 11:59 AM
tube yj
tube yj's Avatar
1949 CJ3A
Here are some old pics when my YJ was on 35*14.50 boggers. They measured 15.50 wide though
tube yj is offline
post #9 of 9 Old 05-19-2003, 01:35 PM Thread Starter
magicmudder
Thanks big yj...and foreverjeepin, thanks for the advice. I'm regearing right now and I'm also going with some one-piece axles in the AMC20. I was dumb in my decision to regear and go to one-piece axles instead of just swapping in some 44's or larger axles. It would have been cheaper/easier/stronger if I'd just swapped out axles, but I've got all the parts now (half way put together), so I'll run that setup for a while and go easy on it in the mud.
15x12" wheels with 11.5" wide tires Lostj Jeep Picture Requests 6 09-21-2011 11:17 AM
TJ with 31" in tires and 10" Wide wheels kk491745 Jeep Picture Requests 6 03-24-2009 07:31 PM
12.5" wide tires on 8" wide wheels with 4.5" backspacing nichols077 Jeep Picture Requests 0 10-21-2006 10:45 AM
wide 33" tires on 10" rims Bobbywolf Jeep Picture Requests 1 08-17-2006 09:33 PM
CJ-7, 33" tires on 10"wide rims 70cj5 Jeep Picture Requests 1 01-18-2006 07:50 AM
