Nate's 2002 TJ, simple but effective.... - Page 239 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Nate's 2002 TJ, simple but effective....
FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectDan's 15% Birthday Sale!USA Standard Chromoly Front Axle Shaft Kits with Dana 30 4
Unread 12-12-2013, 10:18 PM   #3571
Imped
Imped's Avatar
MUCH better. What's separation look like now?
OlllllllO
Float Test Build
IndyORV
Imped is offline   Reply With Quote Quick reply to this message
Unread 12-12-2013, 10:25 PM   #3572
gst95dsm
Chop, Wheel and Rebuild..
gst95dsm's Avatar
Looks to be right about 9" from a rough measurement I just took. It's not going any lower…. just need to level it out by notching the driver side.
My Build Thread
gst95dsm is offline   Reply With Quote Quick reply to this message
Unread 12-12-2013, 10:30 PM   #3573
Imped
Imped's Avatar
Perfect, run it.
OlllllllO
Float Test Build
IndyORV
Unread 12-13-2013, 08:06 AM   #3574
jermeyg
Nate any reason why you can have your truss upper mount right on top of the cast mount if you performed the bit of surgery we Talked about? Is the triangulation of your frame mount driving you to place the truss mount to the passenger side?
I am not as experienced in setting up custom suspension as Imped so I can't comment on the right number for vertical separation for you but just the principle of keep the links parallel and the same length. I am sure at the of the day it will look superb!
jermeyg is offline   Reply With Quote Quick reply to this message
Unread 12-13-2013, 08:49 AM   #3575
gst95dsm
gst95dsm's Avatar
Originally Posted by jermeyg
Nate any reason why you can have your truss upper mount right on top of the cast mount if you performed the bit of surgery we Talked about? Is the triangulation of your frame mount driving you to place the truss mount to the passenger side? I am not as experienced in setting up custom suspension as Imped so I can't comment on the right number for vertical separation for you but just the principle of keep the links parallel and the same length. I am sure at the of the day it will look superb!
It wants to be right there to keep the joint neutral. That's all good. I'll lop off the top of the stock mount and fill it in so it's not so ugly.
My Build Thread
Unread 12-13-2013, 08:56 AM   #3576
gspup
Nate if your near your jeep this afternoon can you measure the outside distance, frame to frame ?
I want to bend up some aluminum today and start making an AL bumper and I don't have my jeep at work.
gspup is offline   Reply With Quote Quick reply to this message
Unread 12-13-2013, 09:20 AM   #3577
gst95dsm
gst95dsm's Avatar
I just measured 33 and 5/16ths…. get another measurement before you go cutting… I don't want to be the one to make you waste a sheet of AL!
I measured right about where the stock sway bar would go across the frame just behind my bumper.
My Build Thread
Unread 12-13-2013, 09:52 AM   #3578
gspup
Thanks man, I'll just do an even 34".
No worries I have about 20 pieces of 6061 T6 'scrap' laying in the shop.
Unread 12-13-2013, 12:10 PM   #3579
gst95dsm
gst95dsm's Avatar
Well were back to clean up, paint and assembly. I'm much happier with it. I'm off tomorrow so I should be able to get it together.
My Build Thread
Unread 12-13-2013, 12:13 PM   #3580
Imped
Imped's Avatar
Is there enough room to weld it to the chunk?
OlllllllO
Float Test Build
IndyORV
Unread 12-13-2013, 12:35 PM   #3581
gst95dsm
gst95dsm's Avatar
Weld to the diff housing itself? Maybe in the back a little, but the front is right in line with the seam on the diff cover.
My Build Thread
Unread 12-14-2013, 11:55 AM   #3582
gst95dsm
gst95dsm's Avatar
It's a chilly 60 degrees today.... Paint taking a little while to dry. :-). I should be able to get it all together though. I'm excited.
My Build Thread
Unread 12-14-2013, 12:20 PM   #3583
bobthetj03
Looking good Nate!
Bob's boring build:
http://www.jeepforum.com/forum/f22/b...build-1304260/
White Jeep club member #2003
www.norcal-jeeps.com
bobthetj03 is offline   Reply With Quote Quick reply to this message
Unread 12-14-2013, 12:24 PM   #3584
Imped
Imped's Avatar
Chilly? Are you kidding me?
OlllllllO
Float Test Build
IndyORV
Unread 12-14-2013, 12:36 PM   #3585
gst95dsm
gst95dsm's Avatar
Yeah that was a jab at you easterners.... Haha
My Build Thread
