Nate's 2002 TJ, simple but effective.... - Page 235 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Nate's 2002 TJ, simple but effective....
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 12-11-2013, 10:27 AM   #3511
elclipo
One link welded up, gotta say I was a little nervous about having to weld around the bungs but it's looking good.
Attachment 909002
Nice! Are those 1.25" shanks on the joints? Mere curiosity here since you are using longer than stock arms.
elclipo is offline   Reply With Quote Quick reply to this message
Unread 12-11-2013, 10:42 AM   #3512
gst95dsm
Chop, Wheel and Rebuild..
gst95dsm's Avatar
Yup 1.25 shanks.
My Build Thread
gst95dsm is offline   Reply With Quote Quick reply to this message
Unread 12-11-2013, 10:45 AM   #3513
elclipo
Yup 1.25 shanks.
Thanks. All your building as of late makes me want to do the same. I would love to make my own arms but having to buy DOM at 20' increments locally makes it pretty much impossible.
Unread 12-11-2013, 10:54 AM   #3514
AngryTJ
So I assume you've received those joints I sent over?
Also are you using 3 same length arms and then welding the frame mounts to fit? Im just curious why you welded the arms already
[SIZE="5"][COLOR="Blue"]Follow me on Instagram @ Tarantula_TJ[/COLOR][/SIZE]
[URL="http://www.jeepforum.com/forum/f22/angrytjs-97tj-05-rubicon-build-1271051//"][SIZE="4"][B]
Tarantula_TJ Build[/B][/SIZE][/URL]
AngryTJ is offline   Reply With Quote Quick reply to this message
Unread 12-11-2013, 11:00 AM   #3515
gst95dsm
gst95dsm's Avatar
Barnes4wd for DOM, can't be beat!
My Build Thread
Unread 12-11-2013, 11:04 AM   #3516
gst95dsm
gst95dsm's Avatar
Originally Posted by AngryTJ
So I assume you've received those joints I sent over? Also are you using 3 same length arms and then welding the frame mounts to fit? Im just curious why you welded the arms already
I only made the lowers so far since I am using the same frame side link mounts as before. Today I'll get the upper link mount welded on, along with the upper axle link mount, and then set the pinion, take the measurement and construct the 3rd link. Hopefully.
And yes, got the joints, thanks for the hookup!
My Build Thread
Unread 12-11-2013, 11:11 AM   #3517
elclipo
Didn't know that! Do they sell "kits" or can I order specific pieces? I guess I should be asking them that
Unread 12-11-2013, 11:14 AM   #3518
Danno6102
We're lucky here in Indy! We have a place that sells everything by the foot at very good prices!
[url="http://www.indyorv.com"][B]IndyORV[/B][/url]
[URL="http://www.jeepforum.com/forum/f22/dannos-dd-tj-build-1320254/"][B][I]My Build[/I][/B][/URL]
"Evolution through carnage, the Jeep will keep what it needs."
Danno6102 is offline   Reply With Quote Quick reply to this message
Unread 12-11-2013, 11:17 AM   #3519
elclipo
Not here So far they give me a per foot price but you have to buy the whole stick that is ~20 feet. They'll cut it to length, in whole feet increments at $2 a cut
Unread 12-11-2013, 11:23 AM   #3520
gst95dsm
gst95dsm's Avatar
I bought 3, 24" sticks and am just cutting a bit to whatever I want the links to be. I think it was $20 or so per stick, I was fine with that. And their shipping is way cheap.
My Build Thread
Unread 12-11-2013, 11:35 AM   #3521
Imped
Imped's Avatar
Warner? That's where I go. They rock.
OlllllllO
Float Test Build
IndyORV
Imped is offline   Reply With Quote Quick reply to this message
Unread 12-11-2013, 11:36 AM   #3522
elclipo
That's pretty close to the pricing I get here not counting the cutting fees and the 20' required purchase.
Unread 12-11-2013, 11:45 AM   #3523
AngryTJ
Cant recall what you decided regarding the discussion on tracbar mounts. Will you be using the stock tracbar mount on the axle and frame?
Unread 12-11-2013, 11:57 AM   #3524
Danno6102
Yep! & Yep! I think 2"x1/4" wall DOM was about $12 a foot. You can usually get drops a lot cheaper on their sale days.
Unread 12-11-2013, 12:12 PM   #3525
gst95dsm
gst95dsm's Avatar
Yes, I'm not having or able to see any issues with either one at the moment.
My Build Thread
