Nate's 2002 TJ, simple but effective.... - Page 183 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Nate's 2002 TJ, simple but effective....
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 10-16-2013, 09:37 PM   #2731
gst95dsm
Chop, Wheel and Rebuild..
gst95dsm's Avatar
Originally Posted by aw12345 View Post
There always is, you just have to try harder. You can flat belly and Atlas and stuff crossmembers in there. So it can be done.
My yellow one has something similar to your flatbelly and with 1" retangular tube welded to it, it will bend when turtled on the belly, had to straighten it a time or two. Try it, if it bends you know what to do, as long as it doesn't pull the nutserts out of the frame you are ok
When I pull the skid to mess with the cat hanger I think I'll at least add one across the back, There's plenty of room back there to lay down a piece of angle. The front however... is a little harder, I may be able to weld in some sections but not one all the way across in one piece.
My Build Thread
gst95dsm is offline   Reply With Quote Quick reply to this message
Unread 10-16-2013, 10:28 PM   #2732
MO2500
MO2500's Avatar
Brace as much as you can! My 1/4" flat skid is braced with several pieces of angle in the middle and is bent and twisted everywhere I didn't brace. I'll have to straighten it out and re-design this winter.
ODonnell Motorsports
Build Thread
Instagram: @omsmike
MO2500 is offline   Reply With Quote Quick reply to this message
Unread 10-16-2013, 10:42 PM   #2733
gst95dsm
gst95dsm's Avatar
Mike were the leading edges bent to add rigidity? I'm not saying if they are then you don't need to brace, I'm just curious. It's surprising it would bend that much. After hearing you and Art... and knowing that this skid will be wheeled regularly... the next time I pull it, it's getting braced where ever possible. My rough country skid that I replaced was just ever so slightly rain bowed in the front, it did not have any bracing other than being bent on 4 corners. Surprisingly....
My Build Thread
Unread 10-16-2013, 10:59 PM   #2734
MO2500
MO2500's Avatar
No, my skid is not bent on the leading edge. I have angle running across most of the front but like you I had to leave clearance for the cat and driveshaft. That just happens to be where its bent the worst though. The rear of my skid is bolted to the 4-link crossmember which is 2"x3"x3/16" rectangular tube, its not bending.
My skid is also skinned with 5/8" UHMW. It bent and snapped a big piece of UHMW off the front corner which sucks. I'll have to add more counter sunk screws on the UHMW when I straighten it.
Build Thread
Instagram: @omsmike
Unread 10-16-2013, 11:04 PM   #2735
gst95dsm
gst95dsm's Avatar
Right on, I think the bent leading edge helps the situation, but I'll add some more wherever possible. When I'm trying to keep up with Art at the Hammers this winter I don't want to have to worry about it!
My Build Thread
Unread 10-16-2013, 11:29 PM   #2736
aw12345
My 3/8" 6160t6 plate has 2 crossmembers and the angle going forward for the trans and engine skid and all that has held up very well.
Actually a flat plate bolted to a couple of crossmembers and the frame for the engine skid holds up very well.
aw12345 is offline   Reply With Quote Quick reply to this message
Unread 10-16-2013, 11:43 PM   #2737
gst95dsm
gst95dsm's Avatar
My 3/8" 6160t6 plate has 2 crossmembers and the angle going forward for the trans and engine skid and all that has held up very well. Actually a flat plate bolted to a couple of crossmembers and the frame for the engine skid holds up very well.
Well obviously you never even wheel it! That looks substantial Art, to say the least.
My Build Thread
Unread 10-17-2013, 12:05 AM   #2738
aw12345
Gonna beat it, you build it to take a beating.
Unread 10-17-2013, 12:58 PM   #2739
gst95dsm
gst95dsm's Avatar
Had to dedicate this morning to my truck! Between the wrenching and wheeling lately it's been neglected. I don't think it was ever as dirty. Anyone else neglect their other vehicles for their jeep?? She's nice and clean again now.
My Build Thread
Unread 10-17-2013, 01:16 PM   #2740
yellow_snocone
You should see my car it was white but its a light tan now and believe it or not the jeep is cleaner
Military Jeepers
S.W. New Mexico region
[URL="http://www.jeepforum.com/forum/f22/chesters-tj-build-1420405/"][COLOR="Green"]Chester TJ build[/COLOR][/URL]
[URL="http://www.jeepforum.com/forum/f330/rubicon-trail-august-9th-11th-2014-a-1550022/"][COLOR="Blue"]2014 JF RUBICON TRIP[/COLOR][/URL]
yellow_snocone is offline   Reply With Quote Quick reply to this message
Unread 10-17-2013, 01:19 PM   #2741
gst95dsm
gst95dsm's Avatar
Sometimes I wish I could have a dirty car and not go crazy about it.
My Build Thread
Unread 10-17-2013, 01:24 PM   #2742
yellow_snocone
I thought about hosing it down after the oil change last weekend but then I got busy with the house
Military Jeepers
Unread 10-17-2013, 01:28 PM   #2743
gspup
I let my honda sit for the last 5 months because it had a crack in the radiator...just fixed it the other day so I could start DDing the jalopy again. This means the jeep will be getting the hartop treatment and some inner fenders soon.
gspup is offline   Reply With Quote Quick reply to this message
Unread 10-17-2013, 03:13 PM   #2744
dayriesw
dayriesw's Avatar
1987 MJ Comanche
I have heard that before.
06 WK Hemi Overland.. stock DD
87 MJ project on 37s.. Waggy axles, 6 speed, flipped D300 and Bobbed 10" so far. 3 link coming soon.
Sold:
05 LJ.. Low and on 37s
79 FSJ.. 360/4speed on 38s
85 CJ-7 Renegade
Buy my AEV Pintler TJ Beadlocks. See the classifieds.
dayriesw is offline   Reply With Quote Quick reply to this message
Unread 10-17-2013, 04:26 PM   #2745
gspup
Haha, true...but really it's happening this weekend.
I'll get you a quote tomorrow. My programmer left early.
