Nate's 2002 TJ, simple but effective.... - Page 148 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Nate's 2002 TJ, simple but effective....
Regear now with Gear Packages from JeepHut.comSmittybilt M1 Fender Flares + FREE Machete$40 off over $400 + FREE SHIPPING!!!
Unread 08-11-2013, 06:16 PM   #2206
yellow_snocone
It came out great Nate now all that's left are the easy things
Military Jeepers
S.W. New Mexico region
[URL="http://www.jeepforum.com/forum/f22/chesters-tj-build-1420405/"][COLOR="Green"]Chester TJ build[/COLOR][/URL]
[URL="http://www.jeepforum.com/forum/f330/rubicon-trail-august-9th-11th-2014-a-1550022/"][COLOR="Blue"]2014 JF RUBICON TRIP[/COLOR][/URL]
yellow_snocone is offline   Reply With Quote Quick reply to this message
Unread 08-11-2013, 07:37 PM   #2207
gst95dsm
Chop, Wheel and Rebuild..
gst95dsm's Avatar
Thanks Kyle, if you do decide to somewhat follow in my footsteps you've got a lot of work ahead of you buddy! At least you're buying your corners, I guess a third of my hours have been reworking those. I figure my thread should save you some quess work also. Looking forward to you starting and seeing what you come up with.
My Build Thread
gst95dsm is offline   Reply With Quote Quick reply to this message
Unread 08-12-2013, 08:47 AM   #2208
G Beasley
I like the corners painted to match much better . The stretch looks great , now for the painful part ... wallet opening .
G Beasley is offline   Reply With Quote Quick reply to this message
Unread 08-13-2013, 10:33 AM   #2209
gst95dsm
gst95dsm's Avatar
What???? No metal to cut today.... no grinding today???? No sanding!!!! Lol. Ok today's project is basically to run a hard line extension for the rear brakes, Do some painting, and just clean up a bit. If I get ambitious I'll pull the T-case. SYE has been ordered.
My Build Thread
Unread 08-13-2013, 02:41 PM   #2210
jeepinhokie
Don't pull the t-case for a sye. Just pull the back half of the case off.
HOKIES UNITED!
[B][COLOR="Navy"][URL="http://www.jeepforum.com/forum/f22/hokies-04-tj-build-1386453/"]A Hokie build[/URL][/COLOR][/B]
[URL="http://vimeo.com/user6111157/videos"]check out my jeepin videos![/URL]
[URL="http://hardrockcrawlers.org/"]Hardrock crawlers of southern Maryland[/URL]
jeepinhokie is offline   Reply With Quote Quick reply to this message
Unread 08-13-2013, 02:58 PM   #2211
gst95dsm
gst95dsm's Avatar
I know it can be done like that, but I think I'd rather plop it on the workbench and have at it, then be stuck under the jeep for an hour or so. We'll see, when I pulled it to install the Tera-low, I remember it being very easy to pull and re-install.
My Build Thread
Unread 08-13-2013, 03:09 PM   #2212
yellow_snocone
I would pull the T-case it was a pain working on it with it still in the jeep. Its to easy to take out the t-case not too. Only 6 nuts and a few wires.
Military Jeepers
Unread 08-13-2013, 05:30 PM   #2213
dayriesw
dayriesw's Avatar
1987 MJ Comanche
Take it from this guy who has worked on his tcase to much.... pull it. Best tool to do this is a wratcheting 9/16 wrench. Even full of fluid, I can remove it by myself and reinstall without a trans lift. Maybe 80 lbs full.
06 WK Hemi Overland.. stock DD
87 MJ project on 37s.. Waggy axles, 6 speed, flipped D300 and Bobbed 10" so far. 3 link coming soon.
Sold:
05 LJ.. Low and on 37s
79 FSJ.. 360/4speed on 38s
85 CJ-7 Renegade
Buy my AEV Pintler TJ Beadlocks. See the classifieds.
dayriesw is offline   Reply With Quote Quick reply to this message
Unread 08-13-2013, 05:50 PM   #2214
gst95dsm
gst95dsm's Avatar
Yup, maybe if I had a lift I wouldn't pull it, but I'm to big of a guy to be sitting hunched over under that jeep for very long. haha.
Well a pre made 8" section of brake line from NAPA has solved the rear brake problem. I'm not going to mount it until I get everything back together but it should work out well.
My Build Thread
Unread 08-13-2013, 05:55 PM   #2215
bobthetj03
What SYE did you go with?
Bob's boring build:
http://www.jeepforum.com/forum/f22/b...build-1304260/
White Jeep club member #2003
www.norcal-jeeps.com
bobthetj03 is offline   Reply With Quote Quick reply to this message
Unread 08-13-2013, 06:05 PM   #2216
gst95dsm
gst95dsm's Avatar
Rugged Ridge .. as far as I know, they are basically all the same. I did not go for the super short one.... since I don't need it. I think the parent company to a lot of these re-branded SYE's is Omix-ada. I admittedly did very little research though.
My Build Thread
Unread 08-13-2013, 06:08 PM   #2217
bobthetj03
I hear they are one of the more reasonably priced ones. Just was curious. A SYE is on my short list of needs.
Bob's boring build:
Unread 08-13-2013, 08:01 PM   #2218
gst95dsm
gst95dsm's Avatar
$165 shipped on Ebay was the best I could do.... I thought that was pretty good.
My Build Thread
Unread 08-13-2013, 09:00 PM   #2219
gst95dsm
gst95dsm's Avatar
Gettin stuff re-connected as much as I can at this point and some final painting. Feeling pretty sanitary. Looking good for link mounting as soon as I get the brackets.
My Build Thread
Unread 08-13-2013, 09:53 PM   #2220
AZdEvilYJ
RIP Anticanman
AZdEvilYJ's Avatar
Do you have 27spline chromos or is that a super 35?
'95 YJ 2.5L
March '15 YJ of the Month!
Exiled Offroad - Arizona
My Build Thread
http://www.jeepforum.com/forum/f22/a...nally-1575209/
AZdEvilYJ is online now   Reply With Quote Quick reply to this message
