Nate's 2002 TJ, simple but effective.... - Page 144 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Nate's 2002 TJ, simple but effective....
1987-1990 Jeep Wrangler Engine Oil Pan for L6 4.2LBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 08-07-2013, 09:56 PM   #2146
gst95dsm
Chop, Wheel and Rebuild..
gst95dsm's Avatar
Originally Posted by JJeeper09 View Post
So much easier doing that with the wheel wells cut. I did this as best I could with my stock wheel well. I can't want to make it look like that.
Good work
Yeah with that vertical support I HATED sticking my hand in there! The taillight wiring was atrocious for years, Oh well you couldn't see it.
My Build Thread
gst95dsm is offline   Reply With Quote Quick reply to this message
Unread 08-07-2013, 09:57 PM   #2147
yellow_snocone
That's a good idea also, and one I may have pursued had I not already had all the work into relocating the coil mounts and the shock towers.
One of the major reasons I held back on doing all that.
Military Jeepers
S.W. New Mexico region
[URL="http://www.jeepforum.com/forum/f22/chesters-tj-build-1420405/"][COLOR="Green"]Chester TJ build[/COLOR][/URL]
[URL="http://www.jeepforum.com/forum/f330/rubicon-trail-august-9th-11th-2014-a-1550022/"][COLOR="Blue"]2014 JF RUBICON TRIP[/COLOR][/URL]
yellow_snocone is offline   Reply With Quote Quick reply to this message
Unread 08-07-2013, 10:01 PM   #2148
gst95dsm
gst95dsm's Avatar
Originally Posted by yellow_snocone View Post
One of the major reason I held back on doing all that.
I thought long and hard before I did all that....... then I wheeled with Art, Mike and Lu J/K, this was something that was supposed to happen in a few years, but I got this plan in my head and just couldn't wait. Oh well, hey Artec has a TJ back half kit now also..... that would be cool. It might be geared more for Coilovers only though.
My Build Thread
Unread 08-08-2013, 06:02 AM   #2149
jermeyg
Dude you need to put up some instruction on your method and cleaning agents so we can achieve half the results. Such a clean TJ!
jermeyg is offline   Reply With Quote Quick reply to this message
Unread 08-08-2013, 07:00 AM   #2150
yellow_snocone
Most of the kits I've seen seem to be geared towards coilovers. I may just go a custom route and stick to the coil springs.
Military Jeepers
Unread 08-08-2013, 07:14 AM   #2151
yellow_snocone
Nate heres another method for your rear flares that blaine did.
http://www.jeepforum.com/forum/f9/sl...l#post12237244
Military Jeepers
Unread 08-08-2013, 07:16 AM   #2152
AngryTJ
AngryTJ's Avatar
Shouldnt have followed us around in moab
I remember looking at that back half kit myself then just found it much easier to stick with what I had and just modify it.
Are you dreaming about what still needs to be completed yet? I remember I did, thats all I could think about when I was stretching.
Tarantula_TJ Build
AngryTJ is offline   Reply With Quote Quick reply to this message
Unread 08-08-2013, 08:07 AM   #2153
gst95dsm
gst95dsm's Avatar
Thanks Jermey, your work and Jeep is just as clean or cleaner though man! I still feel like a hack artist.
I would.
I'll check that out.
I'm having nightmares of dropping almost a grand on a small aluminum box.
I honestly can't wait to pull it out of the garage.
My Build Thread
Unread 08-08-2013, 08:40 AM   #2154
gst95dsm
gst95dsm's Avatar
Thanks for showing me that Kyle, that's as close a photo of what I need to do that i've seen. Actually besides the awesome tank work on that jeep, and just better fab all the way around.... that back end looks a lot like mine. That one is just a little more stretched. I honestly can't say I really love the look of the modified MetalCloak flare, but I can't think of any other way to do it, and It doesn't look terrible.
My Build Thread
Unread 08-08-2013, 08:44 AM   #2155
AngryTJ
AngryTJ's Avatar
You dont think you can leave your rear flare unmodified and just trim the gas bezel like I did?
That link Kyle provided is a good solution but as you mentioned that jeeps stretched a it more. You have some more real estate to work with on your corners.
Tarantula_TJ Build
Unread 08-08-2013, 08:56 AM   #2156
gst95dsm
gst95dsm's Avatar
Nope, it would put the end of the rail past the entire corner. I have to cut it, and I have to cut before the radius of the tub. It won't look much different than what's in that thread, maybe just an inch longer. I'm dedicating my entire Saturday to getting at least one side done, painted and bolted up. So we will see. I know it's gonna look ok, I'm just not in love with it.
My Build Thread
Unread 08-08-2013, 07:07 PM   #2157
aw12345
aw12345's Avatar
Looking at what Blaine did to Cliffy's Jeep I would extend the back end a lil more and bend the tube so it wraps around the corner a bit, would look cleaner.
aw12345 is offline   Reply With Quote Quick reply to this message
Unread 08-08-2013, 08:06 PM   #2158
gst95dsm
gst95dsm's Avatar
Got a link Art? I don't know who Cliffy is.
My Build Thread
Unread 08-08-2013, 08:14 PM   #2159
aw12345
aw12345's Avatar
It's the link Kyle send you. If you would extend the tube down turther and bend it so it follows the radius of the corner and ends where the radius of the corner ends it would look sweet.
Jeep on the left is Cliffy's if those fender flares extended further down they would look much better
cross mtn 20130012 by MJR RAT, on Flickr
This looks better
20130512_140143 by MJR RAT, on Flickr
Extend it all the way down or close to that would look better yet
This what I would try to make
8732403051_c1233e0a29_z by aartjestaartje, on Flickr
Unread 08-08-2013, 08:15 PM   #2160
gst95dsm
gst95dsm's Avatar
Ok I'm looking for suggestions or opinions on the what to do with the rub rail.
I made the cut for the new gas filler bezel. And I knew the rub rail would overlap the bezel quite a bit, but I'm not willing to move the bezel (actually I can't, unless I move it to the back of the tub) It's up as high, and as far over as possible. My thoughts right now are to cut off the two mounting brackets for the rail and have it only attached at the ends, much like the front rub rail. I think this will be a cleaner look.
I know it's not the cleanest with it overlapping like this, but I need to make the best of it.
I've got to cut it right at the beginning of the radius.
I'm thinking about just cutting these brackets off....
My Build Thread
