Nate's 2002 TJ, simple but effective.... - Page 239 - JeepForum.com
 2Likes
post #3571 of 4896 Old 12-12-2013, 10:18 PM
Imped
Imped's Avatar
MUCH better. What's separation look like now?
OlllllllO
IndyORV
Imped is offline
post #3572 of 4896 Old 12-12-2013, 10:25 PM Thread Starter
gst95dsm
Chop, Wheel and Rebuild..
gst95dsm's Avatar
Looks to be right about 9" from a rough measurement I just took. It's not going any lower…. just need to level it out by notching the driver side.
gst95dsm is offline
post #3573 of 4896 Old 12-12-2013, 10:30 PM
Imped
Imped's Avatar
Perfect, run it.
OlllllllO
IndyORV
Imped is offline
post #3574 of 4896 Old 12-13-2013, 08:06 AM
jermeyg
Nate any reason why you can have your truss upper mount right on top of the cast mount if you performed the bit of surgery we Talked about? Is the triangulation of your frame mount driving you to place the truss mount to the passenger side?
I am not as experienced in setting up custom suspension as Imped so I can't comment on the right number for vertical separation for you but just the principle of keep the links parallel and the same length. I am sure at the of the day it will look superb!
jermeyg is offline
post #3575 of 4896 Old 12-13-2013, 08:49 AM Thread Starter
gst95dsm
gst95dsm's Avatar
Originally Posted by jermeyg
Nate any reason why you can have your truss upper mount right on top of the cast mount if you performed the bit of surgery we Talked about? Is the triangulation of your frame mount driving you to place the truss mount to the passenger side? I am not as experienced in setting up custom suspension as Imped so I can't comment on the right number for vertical separation for you but just the principle of keep the links parallel and the same length. I am sure at the of the day it will look superb!
It wants to be right there to keep the joint neutral. That's all good. I'll lop off the top of the stock mount and fill it in so it's not so ugly.
gst95dsm is offline
post #3576 of 4896 Old 12-13-2013, 08:56 AM
gspup
Nate if your near your jeep this afternoon can you measure the outside distance, frame to frame ?
I want to bend up some aluminum today and start making an AL bumper and I don't have my jeep at work.
gspup is offline
post #3577 of 4896 Old 12-13-2013, 09:20 AM Thread Starter
gst95dsm
gst95dsm's Avatar
I just measured 33 and 5/16ths…. get another measurement before you go cutting… I don't want to be the one to make you waste a sheet of AL!
I measured right about where the stock sway bar would go across the frame just behind my bumper.
gst95dsm is offline
post #3578 of 4896 Old 12-13-2013, 09:52 AM
gspup
Thanks man, I'll just do an even 34".
No worries I have about 20 pieces of 6061 T6 'scrap' laying in the shop.
gspup is offline
post #3579 of 4896 Old 12-13-2013, 12:10 PM Thread Starter
gst95dsm
gst95dsm's Avatar
Well were back to clean up, paint and assembly. I'm much happier with it. I'm off tomorrow so I should be able to get it together.
gst95dsm is offline
post #3580 of 4896 Old 12-13-2013, 12:13 PM
Imped
Imped's Avatar
Is there enough room to weld it to the chunk?
OlllllllO
IndyORV
Imped is offline
post #3581 of 4896 Old 12-13-2013, 12:35 PM Thread Starter
gst95dsm
gst95dsm's Avatar
Weld to the diff housing itself? Maybe in the back a little, but the front is right in line with the seam on the diff cover.
gst95dsm is offline
post #3582 of 4896 Old 12-14-2013, 11:55 AM Thread Starter
gst95dsm
gst95dsm's Avatar
It's a chilly 60 degrees today.... Paint taking a little while to dry. :-). I should be able to get it all together though. I'm excited.
gst95dsm is offline
post #3583 of 4896 Old 12-14-2013, 12:20 PM
bobthetj03
Looking good Nate!
Bob's boring build:
White Jeep club member #2003
bobthetj03 is offline
post #3584 of 4896 Old 12-14-2013, 12:24 PM
Imped
Imped's Avatar
Chilly? Are you kidding me?
OlllllllO
IndyORV
Imped is offline
post #3585 of 4896 Old 12-14-2013, 12:36 PM Thread Starter
gst95dsm
gst95dsm's Avatar
Yeah that was a jab at you easterners.... Haha
gst95dsm is offline
Nate's Jeep SOLIDJP44 Jeep Builds 438 06-24-2014 11:36 PM
93 YJ Clean and Simple mxr708 Jeep Builds 11 04-24-2011 07:54 PM
2004 WJ...simple for now... bleach1012 Jeep Builds 14 05-16-2009 10:01 PM
Nate's 4x4 Bumpers F+R Panici Jeep Picture Requests 27 12-21-2007 09:11 PM
Lights on Nate's Bumper 5artist5 Jeep Picture Requests 1 11-07-2007 10:19 AM
