Nate's 2002 TJ, simple but effective.... - Page 183 - JeepForum.com
post #2731 of 4893 Old 10-16-2013, 08:37 PM Thread Starter
gst95dsm
Chop, Wheel and Rebuild..
gst95dsm's Avatar
Originally Posted by aw12345 View Post
There always is, you just have to try harder. You can flat belly and Atlas and stuff crossmembers in there. So it can be done.
My yellow one has something similar to your flatbelly and with 1" retangular tube welded to it, it will bend when turtled on the belly, had to straighten it a time or two. Try it, if it bends you know what to do, as long as it doesn't pull the nutserts out of the frame you are ok
When I pull the skid to mess with the cat hanger I think I'll at least add one across the back, There's plenty of room back there to lay down a piece of angle. The front however... is a little harder, I may be able to weld in some sections but not one all the way across in one piece.
gst95dsm is offline
post #2732 of 4893 Old 10-16-2013, 09:28 PM
MO2500
Brace as much as you can! My 1/4" flat skid is braced with several pieces of angle in the middle and is bent and twisted everywhere I didn't brace. I'll have to straighten it out and re-design this winter.
Instagram: @omsmike
MO2500 is offline
post #2733 of 4893 Old 10-16-2013, 09:42 PM Thread Starter
gst95dsm
gst95dsm's Avatar
Mike were the leading edges bent to add rigidity? I'm not saying if they are then you don't need to brace, I'm just curious. It's surprising it would bend that much. After hearing you and Art... and knowing that this skid will be wheeled regularly... the next time I pull it, it's getting braced where ever possible. My rough country skid that I replaced was just ever so slightly rain bowed in the front, it did not have any bracing other than being bent on 4 corners. Surprisingly....
gst95dsm is offline
post #2734 of 4893 Old 10-16-2013, 09:59 PM
MO2500
No, my skid is not bent on the leading edge. I have angle running across most of the front but like you I had to leave clearance for the cat and driveshaft. That just happens to be where its bent the worst though. The rear of my skid is bolted to the 4-link crossmember which is 2"x3"x3/16" rectangular tube, its not bending.
My skid is also skinned with 5/8" UHMW. It bent and snapped a big piece of UHMW off the front corner which sucks. I'll have to add more counter sunk screws on the UHMW when I straighten it.
Instagram: @omsmike
MO2500 is offline
post #2735 of 4893 Old 10-16-2013, 10:04 PM Thread Starter
gst95dsm
gst95dsm's Avatar
Right on, I think the bent leading edge helps the situation, but I'll add some more wherever possible. When I'm trying to keep up with Art at the Hammers this winter I don't want to have to worry about it!
gst95dsm is offline
post #2736 of 4893 Old 10-16-2013, 10:29 PM
aw12345
My 3/8" 6160t6 plate has 2 crossmembers and the angle going forward for the trans and engine skid and all that has held up very well.
Actually a flat plate bolted to a couple of crossmembers and the frame for the engine skid holds up very well.
aw12345 is offline
post #2737 of 4893 Old 10-16-2013, 10:43 PM Thread Starter
gst95dsm
gst95dsm's Avatar
My 3/8" 6160t6 plate has 2 crossmembers and the angle going forward for the trans and engine skid and all that has held up very well. Actually a flat plate bolted to a couple of crossmembers and the frame for the engine skid holds up very well.
Well obviously you never even wheel it! That looks substantial Art, to say the least.
gst95dsm is offline
post #2738 of 4893 Old 10-16-2013, 11:05 PM
aw12345
Gonna beat it, you build it to take a beating.
aw12345 is offline
post #2739 of 4893 Old 10-17-2013, 11:58 AM Thread Starter
gst95dsm
gst95dsm's Avatar
Had to dedicate this morning to my truck! Between the wrenching and wheeling lately it's been neglected. I don't think it was ever as dirty. Anyone else neglect their other vehicles for their jeep?? She's nice and clean again now.
gst95dsm is offline
post #2740 of 4893 Old 10-17-2013, 12:16 PM
yellow_snocone
You should see my car it was white but its a light tan now and believe it or not the jeep is cleaner
Military Jeepers
S.W. New Mexico region
yellow_snocone is offline
post #2741 of 4893 Old 10-17-2013, 12:19 PM Thread Starter
gst95dsm
gst95dsm's Avatar
Sometimes I wish I could have a dirty car and not go crazy about it.
gst95dsm is offline
post #2742 of 4893 Old 10-17-2013, 12:24 PM
yellow_snocone
I thought about hosing it down after the oil change last weekend but then I got busy with the house
Military Jeepers
post #2743 of 4893 Old 10-17-2013, 12:28 PM
gspup
I let my honda sit for the last 5 months because it had a crack in the radiator...just fixed it the other day so I could start DDing the jalopy again. This means the jeep will be getting the hartop treatment and some inner fenders soon.
gspup is offline
post #2744 of 4893 Old 10-17-2013, 02:13 PM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
I have heard that before.
16 Taco
87 MJ Chief in pieces
dayriesw is offline
post #2745 of 4893 Old 10-17-2013, 03:26 PM
gspup
Haha, true...but really it's happening this weekend.
I'll get you a quote tomorrow. My programmer left early.
gspup is offline
Nate's Jeep SOLIDJP44 Jeep Builds 438 06-24-2014 11:36 PM
93 YJ Clean and Simple mxr708 Jeep Builds 11 04-24-2011 07:54 PM
2004 WJ...simple for now... bleach1012 Jeep Builds 14 05-16-2009 10:01 PM
Nate's 4x4 Bumpers F+R Panici Jeep Picture Requests 27 12-21-2007 09:11 PM
Lights on Nate's Bumper 5artist5 Jeep Picture Requests 1 11-07-2007 10:19 AM
