Nate's 2002 TJ, simple but effective.... - Page 182 - JeepForum.com
 2Likes
post #2716 of 4896 Old 10-15-2013, 07:58 PM Thread Starter
gst95dsm
Chop, Wheel and Rebuild..
gst95dsm's Avatar
Yeah it did. I'm not bothered by it, I have prefer to use my tow hooks anyway.
Ok, just checking. I'm going to send them a message about it, because it's mildly annoying and pretty unnecessary.
gst95dsm is offline
post #2717 of 4896 Old 10-16-2013, 07:20 AM
Danno6102
The skid I'm working on has 90 bends on the front & back & is 1/4" thick. I also have an 1/8" bent tranny mount that runs the full width of the skid to add another stiffening member down the middle. I'll be working on it Saturday finally! Will post some pics on Monday in my build if you're interested.
Are you running stock exhaust? Any chance of getting a couple better pics of the cat & the exhaust? These are the areas I need to do a little more research on to make them installation friendly.
"Evolution through carnage, the Jeep will keep what it needs."
Danno6102 is offline
post #2718 of 4896 Old 10-16-2013, 07:53 AM Thread Starter
gst95dsm
gst95dsm's Avatar
I took another look last night and it looks like I could run a piece of angle all the way across towards the back of the skid that I might end up doing. The way you have yours set up sounds like a good idea also, But It might give you an issue hitting the cat if you have it in the factory spot still.
I'm running the stock exhaust but I've moved the muffler towards the center of the jeep several inches by cutting it off, flipping it and rewelding the flange on. The cat however and hanger have not been touched but the hanger is quite tweaked in it's mount as naturally it does not want to be that horizontal. I was looking at it last night and I think adding the angle iron, cutting the cat hanger and repositioning it and making some plates out of 1/4" to raise the motor a bit more. I noticed the fan is VERY close to hitting the bottom of the shroud now. Also planning the cable shifter because although during my testing it appeared to be shifting just fine, during another drive test last night it fought me a bit and I can only imagine how annoyed I'll be on the trail it if won't shift properly. After these tweaks this flat skid should be happy to be there, strong and trouble free.
gst95dsm is offline
post #2719 of 4896 Old 10-16-2013, 09:30 AM
gspup
^ ah the joys of tummy tucks.
gspup is offline
post #2720 of 4896 Old 10-16-2013, 09:57 AM
bobthetj03
I had to cut my cat hanger and shorten it when I installed my low pro mount. Maybe you could do something to that effect, or get a low pro mount to help drop the drivetrain down a little?
Bob's boring build:
White Jeep club member #2003
bobthetj03 is offline
post #2721 of 4896 Old 10-16-2013, 10:35 AM Thread Starter
gst95dsm
gst95dsm's Avatar
The drivetrain is pretty happy with the stock transmission mount surprisingly, the cat hanger would be happier welded on at a slightly different angle although it's height is perfect right now. Drove it to work and am surprised how good it feels, making the aforementioned tweaks will alleviate some stress on the mounts and hopefully restore NVH to near factory levels.
gst95dsm is offline
post #2722 of 4896 Old 10-16-2013, 11:30 AM
yellow_snocone
Those goodies sure look nice Nate .
Military Jeepers
S.W. New Mexico region
yellow_snocone is offline
post #2723 of 4896 Old 10-16-2013, 11:56 AM
Moabrubi
Must be nice having that smaller tcase and stretch. My DS is pretty steep as is and much more of a tuck would require a hammer
If I ever stretch mine I'll probably flat skid it too.
Moabrubi is offline
post #2724 of 4896 Old 10-16-2013, 12:03 PM Thread Starter
gst95dsm
gst95dsm's Avatar
Thanks Kyle, just adding to my money pit.
gst95dsm is offline
post #2725 of 4896 Old 10-16-2013, 12:04 PM Thread Starter
gst95dsm
gst95dsm's Avatar
Originally Posted by Moabrubi
Must be nice having that smaller tcase and stretch. My DS is pretty steep as is and much more of a tuck would require a hammer If I ever stretch mine I'll probably flat skid it too.
Yeah I think having an ax5 is helping also, the extra driveline length works out well, I couldn't imagine how steep it would be otherwise.
gst95dsm is offline
post #2726 of 4896 Old 10-16-2013, 01:39 PM
Imped
Imped's Avatar
Compact tranny/t- case and longer wheelbase = niiice
Flat belly looks good. Makes you wonder how anyone deals with the factory skid.
OlllllllO
IndyORV
Imped is offline
post #2727 of 4896 Old 10-16-2013, 06:37 PM Thread Starter
gst95dsm
gst95dsm's Avatar
So I went ahead and cut out some motor mount spacers on the plasma. Not sure if I need all 4 but just incase I made them. This should make the engine height perfect and give me the 1/4 inch more clearance I'd like to have between the front of the skid and the transmission.
gst95dsm is offline
post #2728 of 4896 Old 10-16-2013, 07:49 PM Thread Starter
gst95dsm
gst95dsm's Avatar
Thanks man, it sure looks good aesthetically and actually just visually made the Jeep look much sleeker. Even my link brackets don't look so low to me anymore. It's nice to be above 18", that seems like kind of the magic number for a decent belly height on a TJ that's not real high, and on a small tire.
gst95dsm is offline
post #2729 of 4896 Old 10-16-2013, 08:04 PM
aw12345
It seems unlikely to bend with the bent lip on both sides, and tight quarters it resides in but I am concerned about that. Room for any bracing would be interesting, there's not really any to be had.
There always is, you just have to try harder. You can flat belly and Atlas and stuff crossmembers in there. So it can be done.
My yellow one has something similar to your flatbelly and with 1" retangular tube welded to it, it will bend when turtled on the belly, had to straighten it a time or two. Try it, if it bends you know what to do, as long as it doesn't pull the nutserts out of the frame you are ok
aw12345 is offline
post #2730 of 4896 Old 10-16-2013, 08:29 PM Thread Starter
gst95dsm
gst95dsm's Avatar
Well the motor mount lift spacers worked out well, 2 on each side for a total of 3/8ths lift and motor mounts are fairly neutral, and I've increased the space between the trans and skid to avoid any contact at the very front of the skid. I'll tackle the cat hanger next.
gst95dsm is offline
Nate's Jeep SOLIDJP44 Jeep Builds 438 06-24-2014 11:36 PM
93 YJ Clean and Simple mxr708 Jeep Builds 11 04-24-2011 07:54 PM
2004 WJ...simple for now... bleach1012 Jeep Builds 14 05-16-2009 10:01 PM
Nate's 4x4 Bumpers F+R Panici Jeep Picture Requests 27 12-21-2007 09:11 PM
Lights on Nate's Bumper 5artist5 Jeep Picture Requests 1 11-07-2007 10:19 AM
