Nate's 2002 TJ, simple but effective.... - Page 148 - JeepForum.com
post #2206 of 4895 Old 08-11-2013, 05:16 PM
yellow_snocone
It came out great Nate now all that's left are the easy things
Military Jeepers
S.W. New Mexico region
yellow_snocone is offline
post #2207 of 4895 Old 08-11-2013, 06:37 PM Thread Starter
gst95dsm
Chop, Wheel and Rebuild..
gst95dsm's Avatar
Thanks Kyle, if you do decide to somewhat follow in my footsteps you've got a lot of work ahead of you buddy! At least you're buying your corners, I guess a third of my hours have been reworking those. I figure my thread should save you some quess work also. Looking forward to you starting and seeing what you come up with.
gst95dsm is offline
post #2208 of 4895 Old 08-12-2013, 07:47 AM
G Beasley
I like the corners painted to match much better . The stretch looks great , now for the painful part ... wallet opening .
G Beasley is offline
post #2209 of 4895 Old 08-13-2013, 09:33 AM Thread Starter
gst95dsm
gst95dsm's Avatar
What???? No metal to cut today.... no grinding today???? No sanding!!!! Lol. Ok today's project is basically to run a hard line extension for the rear brakes, Do some painting, and just clean up a bit. If I get ambitious I'll pull the T-case. SYE has been ordered.
gst95dsm is offline
post #2210 of 4895 Old 08-13-2013, 01:41 PM
jeepinhokie
Don't pull the t-case for a sye. Just pull the back half of the case off.
HOKIES UNITED!
jeepinhokie is offline
post #2211 of 4895 Old 08-13-2013, 01:58 PM Thread Starter
gst95dsm
gst95dsm's Avatar
I know it can be done like that, but I think I'd rather plop it on the workbench and have at it, then be stuck under the jeep for an hour or so. We'll see, when I pulled it to install the Tera-low, I remember it being very easy to pull and re-install.
gst95dsm is offline
post #2212 of 4895 Old 08-13-2013, 02:09 PM
yellow_snocone
I would pull the T-case it was a pain working on it with it still in the jeep. Its to easy to take out the t-case not too. Only 6 nuts and a few wires.
Military Jeepers
post #2213 of 4895 Old 08-13-2013, 04:30 PM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
Take it from this guy who has worked on his tcase to much.... pull it. Best tool to do this is a wratcheting 9/16 wrench. Even full of fluid, I can remove it by myself and reinstall without a trans lift. Maybe 80 lbs full.
16 Taco
87 MJ Chief in pieces
dayriesw is offline
post #2214 of 4895 Old 08-13-2013, 04:50 PM Thread Starter
gst95dsm
gst95dsm's Avatar
Yup, maybe if I had a lift I wouldn't pull it, but I'm to big of a guy to be sitting hunched over under that jeep for very long. haha.
Well a pre made 8" section of brake line from NAPA has solved the rear brake problem. I'm not going to mount it until I get everything back together but it should work out well.
gst95dsm is offline
post #2215 of 4895 Old 08-13-2013, 04:55 PM
bobthetj03
What SYE did you go with?
Bob's boring build:
White Jeep club member #2003
bobthetj03 is offline
post #2216 of 4895 Old 08-13-2013, 05:05 PM Thread Starter
gst95dsm
gst95dsm's Avatar
Rugged Ridge .. as far as I know, they are basically all the same. I did not go for the super short one.... since I don't need it. I think the parent company to a lot of these re-branded SYE's is Omix-ada. I admittedly did very little research though.
gst95dsm is offline
post #2217 of 4895 Old 08-13-2013, 05:08 PM
bobthetj03
I hear they are one of the more reasonably priced ones. Just was curious. A SYE is on my short list of needs.
Bob's boring build:
post #2218 of 4895 Old 08-13-2013, 07:01 PM Thread Starter
gst95dsm
gst95dsm's Avatar
$165 shipped on Ebay was the best I could do.... I thought that was pretty good.
gst95dsm is offline
post #2219 of 4895 Old 08-13-2013, 08:00 PM Thread Starter
gst95dsm
gst95dsm's Avatar
Gettin stuff re-connected as much as I can at this point and some final painting. Feeling pretty sanitary. Looking good for link mounting as soon as I get the brackets.
gst95dsm is offline
post #2220 of 4895 Old 08-13-2013, 08:53 PM
AZdEvilYJ
Do you have 27spline chromos or is that a super 35?
'95 YJ 2.5L
March '15 YJ of the Month!
Exiled Offroad - Arizona
My Build Thread
AZdEvilYJ is offline
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
Nate's Jeep SOLIDJP44 Jeep Builds 438 06-24-2014 11:36 PM
93 YJ Clean and Simple mxr708 Jeep Builds 11 04-24-2011 07:54 PM
2004 WJ...simple for now... bleach1012 Jeep Builds 14 05-16-2009 10:01 PM
Nate's 4x4 Bumpers F+R Panici Jeep Picture Requests 27 12-21-2007 09:11 PM
Lights on Nate's Bumper 5artist5 Jeep Picture Requests 1 11-07-2007 10:19 AM
