Nate's 2002 TJ, simple but effective.... - Page 136 - JeepForum.com
post #2026 of 4893 Old 07-31-2013, 11:52 PM
gspup
Originally Posted by MO2500
Me too
Me too. Lol
So many people think toyos are mall crawler tires...but I've never seen proof of a sidewall issue ??? They are beef and perform awesome.
gspup is offline
post #2027 of 4893 Old 08-01-2013, 12:14 AM
Moabrubi
Toyo's MT's are good tires a few guys I know run them. They are very similar to the old Cooper I had. Don't know why the bro's like them so much for mallcrawling but for wheeling they seem to be pretty good with a bulletproof sidewall.
I'd like to know how blue label Krawlers compare to MTR's though. Price and weight aside.
Thread highjacked
Moabrubi is offline
post #2028 of 4893 Old 08-01-2013, 07:00 AM
mcannon111
I've been thoroughly impressed with my km2s. Hook up great in east coast wheeling. They definitely hold on to a line better on slick, wet rock than an mtrk from what i've seen. I don't have much to compare to as they are the only 35 I have ever run. They are pretty loud now though after all the side lugs are completely rounded off, and many chunks are missing out the the tred
no doors, no top, no problems
live in sc? join OffroadSC.com
mcannon111 is offline
post #2029 of 4893 Old 08-01-2013, 07:39 AM
Holaday
Thread highjacked
My Blue labels hook up far better than the MTRKs on the rocks wet or dry here in the Midwest. They really shine around 5 psi but weigh about 20lbs more per tire
Holaday is offline
post #2030 of 4893 Old 08-01-2013, 07:54 AM
AngryTJ
I think you have the best tire for all that right now.... I'm not a big Toyo guy though, I have no first hand experience with their MT, but seeing Toyo tires come in frequently, separated, worn funny, and worn quickly on all the crappy lifted trucks around here keeps them in the "poser" category for me.... basically good looking tires for pavement pounders with aftermarket wheels, with only one category they care about.... Looks. I also don't like that the 35" is 13.5 wide and around 10lbs. heavier per tire..... who know's though, they might actually work good. I see them on lot's of JK's in metric sizes.
Why Art..... with my little 10" of travel I haven't even been able to wear out the stock track bar! I could manage reinforcing it though if ever needed.
haha sorry to sidetrack your build Nate and get the tire discussion going. I love my mtrs I simply dont think they are very good when wet or muddy and I just want to try something different for east coast wheelin.
As far as the rear suspension goes is the plan to keep it as is due to costs and eventually 4 link?
AngryTJ is offline
post #2031 of 4893 Old 08-01-2013, 08:05 AM
IEcrawlerTJ01
Thread highjacked
As far as west coast. My wheeling bud has them
Both of us 35's. my Mtr/k's work better for the terrain out here IMO
SAVVY,CURRIE,GOODYEAR
Nuff said...
IEcrawlerTJ01 is offline
post #2032 of 4893 Old 08-01-2013, 08:53 AM Thread Starter
gst95dsm
Chop, Wheel and Rebuild..
gst95dsm's Avatar
It's all good Lu, and the decision to keep the rear basically as is, is based on me not being able to think of any performance based reason to change it. Besides changing the joints. My main motivation to change it was to gain more clearance by running double triangle with a flush mounted crossmember..... I just think that might be a little over my head at this point so I'm good with keeping things as is, saving some coin, and just running what I know worked fine for me. I know I probably seem pretty indecisive, but until I actually got into this stretch, and the reality of the costs vs. benefits vs. downtime set in..... it made things much easier to decide.
gst95dsm is offline
post #2033 of 4893 Old 08-01-2013, 09:02 AM Thread Starter
gst95dsm
gst95dsm's Avatar
As far as the tire talk goes...... my KM2's have been awesome, I'm a pretty die hard BFG fanboy though. I think the MTRK is actually the best M/T available right now, A lot of my buddies run them and they just seem to hook up well on dry rock, wear nicely without chunking and drive well on the street. I don't know about the wet, mud or snow. And I don't get the KM2 noise issues either.... Mine are perfectly acceptable, I'd even say quiet for an M/T. Oh well...... Toyo sucks.
gst95dsm is offline
post #2034 of 4893 Old 08-01-2013, 09:08 AM
Imped
Imped's Avatar
The MT/R isn't actually a mud terrain (M/T).....
As for your suspension, I can't argue with your reasoning. It's sound and you've arrived at your conclusion after researching the alternatives. The stock mount locations can work well as long as you bolt up good parts to them and keep your travel and height in check, which you do. I'd still recommend beefing up the lower mounts if you haven't already.
OlllllllO
IndyORV
Imped is offline
post #2035 of 4893 Old 08-01-2013, 09:38 AM
Danno6102
The 4 link wouldn't cost you that much extra.
You're already buying new joints & making new links, already have to lengthen your driveshaft & doing the new fuel tank anyway. You'd just need to buy a few brackets, which could be homemade quite easily to save some coin, & a truss which a basic truss can be made/bent by a local shop pretty cheap. I'd say you could get the stretch done for little more than what you're spending already. What am I missing? I say just do the stretch. You knocked out a ton of work already, I'm sure you could knock out the rest just as quick as if you would keeping the stock geometry. You have to do just about the same amount of work. Only additional work you'd need to do is frame side brackets.
"Evolution through carnage, the Jeep will keep what it needs."
Danno6102 is offline
post #2036 of 4893 Old 08-01-2013, 10:06 AM Thread Starter
gst95dsm
gst95dsm's Avatar
Ok you got me... "Maximum Traction" Tire...
As far as the lower mounts go, I don't think I'll worry much about the D35 mounts since it's now a short term item. The 8.8 will have some strong lower mounts though.
I agree with a lot of that, but I'm NOT making new links, and not deviating from the stock axle side link mounts. I'll basically be running a stock style mid arm with 27" links, using a simple combo bracket on the frame side. If I wanted to wait until I had the funding to build the 8.8, then I would probably go another route..... but just as it is i'm spending WAY more on consumables and raw material than I anticipated. Triangulating the uppers is about a $2000 decision for me right now (building the 8.8 + new links) as I'm not about to truss and change the brackets on the D35. If I set up the suspension just as it was, I can have my jeep up and running, and have several fun side projects waiting for me...... the duroflex joint swap, and a bolt in rear axle swap. As the funding comes in. It's all compromises man...... but in this case, I don't feel like I'm shorting myself anything at all.
gst95dsm is offline
post #2037 of 4893 Old 08-01-2013, 10:07 AM
Imped
Imped's Avatar
I was more referring to the frame mounts.......unless I'm confused, you're now sticking with the stock frame mounts right? If not, what exactly is your plan?
OlllllllO
IndyORV
Imped is offline
post #2038 of 4893 Old 08-01-2013, 10:11 AM
Danno6102
So you're putting the D35 back in? I thought the 8.8 was going in regardless of what you do with geometry. So, yea, that's a big chunk of change. I think I had about $800 in my 8.8 not including the ARB.
As far as the links go, I'm as confused as Connor. I thought you were sticking with all stock brackets & just making/modifying longer links to fit them.
post #2039 of 4893 Old 08-01-2013, 10:16 AM Thread Starter
gst95dsm
gst95dsm's Avatar
My stock frame mounts are long gone, sorry for all the confusion guys, I know I've been talking in circles. Specifically ill be using the combo bracket that UCF sells, that runs the links out to the factory axle side brackets.
gst95dsm is offline
post #2040 of 4893 Old 08-01-2013, 10:32 AM Thread Starter
gst95dsm
gst95dsm's Avatar
Here's the install I did last year..... this time it will be the same... just 6" further back.
gst95dsm is offline
Nate's Jeep SOLIDJP44 Jeep Builds 438 06-25-2014 12:36 AM
93 YJ Clean and Simple mxr708 Jeep Builds 11 04-24-2011 08:54 PM
2004 WJ...simple for now... bleach1012 Jeep Builds 14 05-16-2009 11:01 PM
Nate's 4x4 Bumpers F+R Panici Jeep Picture Requests 27 12-21-2007 10:11 PM
Lights on Nate's Bumper 5artist5 Jeep Picture Requests 1 11-07-2007 11:19 AM
