My YJ LT1 build - Page 79 - JeepForum.com
post #1171 of 1295 Old 12-11-2012, 08:36 PM
87laredo
1987 YJ Wrangler
@Macerick331. If all of the injectors are working properly then there should NOT be fuel leaking out of them. However if the are bad the you will se a dribble of fuel coming out of them when you turn the key on. Hope this helps.
87laredo is offline
post #1172 of 1295 Old 12-11-2012, 08:36 PM
MR.CLIFFORD
MR.CLIFFORD's Avatar
I agree. This is the injectors out of my 2008 6.2l L92. They didn't sit as long but this is the flow rates before cleaning. They were all over the place.
After cleaning I still had a bad injector so it got replaced.
MR.CLIFFORD is offline
post #1173 of 1295 Old 12-18-2012, 06:14 PM
LT1YJ
Try the bucket I disconnected the coil pulled all the injectors (leaving them in the fuel rail) and cranked the motor a few times. I thought it would make a big mess but mine were so bad I had 1 spray out of half the injector nozzle and 7 dribble. The difference is my engine sat for a while with the fuel lines disconnected. From what I understand its common with LT1 injectors. I got a brand new set Venom I think, from summit. They work perfect now!
LT1YJ is offline
post #1174 of 1295 Old 12-18-2012, 06:57 PM
dnknme
Originally Posted by mavrick331
Front braka lines installed, other than exhaust, chassis is complete!!
Look at the tread on the Duratrac's..
Working on the pedal assembly, was hoping to finish before the rains came in...no luck
I really hope you didn't keep that cheap *** Fram oil filter on, because they design those really bad.
dnknme is offline
post #1175 of 1295 Old 01-05-2013, 07:34 AM
responder
Happy New Year! Hopefully everyone had a great Christmas and a good New Year? I am sure that the Christmas light display was a sight to see over the Holidays.
What are the plans for the build over the next little while as I (read the forum) am wondering when we will start to see some updates?
responder is offline
post #1176 of 1295 Old 01-05-2013, 10:52 AM
thebull84
Originally Posted by 5.7YJ View Post
Welcome to the forum and nice looking YJ! Looks like you have the perfect start for a SBC swap. Mine has a 5.7 TPI motor from an 88 Vette and can be driven all day long with absolutley no problems at all, I love it!
I wish my engine bay looked like that hahaha awesome job man
thebull84 is offline
post #1177 of 1295 Old 01-05-2013, 06:14 PM
5.7YJ
5.7YJ's Avatar
1987 YJ Wrangler
Thank you for the compliment, sure can't compare to mavricks' though! His is a work of art on wheels!
87 YJ, TPI 5.7, 700R4, NP231, BDS 3.5" lift, 1" front & 5/8" rear boomerang shackles, Rubicon Dana 44 rear axle, 33" Goodyear Duratracs
My brake boster/master cylinder upgrade:
5.7YJ is offline
post #1178 of 1295 Old 01-05-2013, 09:02 PM
TheYJnut
Sick build brother...
TheYJnut is offline
post #1179 of 1295 Old 01-22-2013, 06:14 AM
responder
Any updates with the project Mavrick?
post #1180 of 1295 Old 01-28-2013, 04:38 PM
jhardy6
Whats up any updates
jhardy6 is offline
post #1181 of 1295 Old 01-30-2013, 06:19 PM Thread Starter
mavrick331
1987 YJ Wrangler
As always, life and the holidays have gotten in the way of any progress, good news is that they are over, and I have a fresh set of vacation days!!
Bad news is that I am working on a house project, adding a half driveway to park this beast in on the side of my house. Adding concrete around my side yard, rebuilding the fence with and automatic gate and an awning to cover it.
Long story short, I'm looking at another month before I can start to finish the Jeep.
Pic from my Christmas decoration award...out of over 1,200 homes...yeah my head swelled up
Driveway project, you can tell where the old fence was and where ny AC compressor was..
Rick
87' YJ, Corvette LT1, Corvette 4L60e, NP241c, Ford 8.8 rear, 4.11, Duratrac 33's
11' JK 4-door, 2.5" Pro Comp, Blisteins, 4.88's. ,BFG 33's
03' Chevy 2500 Crew Cab 4x4
73' Corvette convertible, 4-speed
11' Cadillac CTS-V
My Wife has her Tahoe...
mavrick331 is offline
post #1182 of 1295 Old 01-30-2013, 06:35 PM
pete1991YJ
Hey wait, I notice you got some beers in the concrete project too... is there a pattern here?
***--- Wrecking Crew member ---***
"I've prolly been around longer than you think"
pete1991YJ is offline
post #1183 of 1295 Old 01-30-2013, 08:40 PM
responder
Congrats on the award for best lights! Looks like you have your hands full right now with the parking pad project.
We will be waiting for the latest updates on the jeep!
post #1184 of 1295 Old 02-01-2013, 12:33 AM
REDnBLUES
1977 CJ7
Do you still have the gas smell or did you ever get that resolved?
1977 CJ7 - LT1/700R4 Project
2015 JKU Rubicon Hard Rock - stock
2013 JK Sahara - gone
REDnBLUES is offline
post #1185 of 1295 Old 02-01-2013, 06:01 AM
titosgreen95yj
Originally Posted by mavrick331 View Post
I'm missing something in my fuel system. I can turn the key to run position and I can hear the fuel rails load up, and after a short while smell something like fuel, but the loading sound is constant. I'm thinking a sensor or something is missing somewhere...
Any thoughts?
don't know what exactly your running for a fuel pump relay but i know when I did my swap the tbi the computer put out a signal to run the fuel pump relay when ignition is switched on but would cut out after 10 seconds if not started , then on again when it got the crank signal from the distributor.
titosgreen95yj is offline
My YJ Build - Yet another build thread!! bluexj YJ Wrangler Technical Forum 28 07-11-2012 12:23 PM
My YJ Build provinT13 YJ Wrangler Technical Forum 1203 06-14-2011 09:29 PM
06flex's build (my build up) 06flex TJ Wrangler Technical Forum 131 07-03-2010 10:26 PM
Build advice for a high-line type build The Rat YJ Wrangler Technical Forum 1 02-11-2009 02:21 PM
how would you build it? dharmabum TJ Wrangler Technical Forum 4 07-27-2006 11:05 PM
