My YJ build and need some answers... - JeepForum.com
post #1 of 1 Old 05-03-2016, 02:54 PM Thread Starter
firzout
1982 CJ8
Hello, everyone! I'm working on a 92 YJ build.
here is what I'm working on as my building...
92 YJ putting a AMC 360, TF727, NP208. I have a D30 front, 8.8 rear, matching 4:10 gears, 4" suspension lift, 1" BL, 1" shackle lift, running on 35x12.5x15 tires.
Jeep will be mostly street and some occasional (mild) off road
My 360 will have an edelbrock intake, GM TBI injection out of a Chevy v8 truck....AND I want to put a CAM in it!
HERE are my questions...
1- What CAM is best with this set up?
I was looking at the Comp cam 260 and the summit k8600, but found A LOT of mixed reviews.
2- Do I need to burn a chip with the set up I want or can I run the stock chip out of the Chevy ECM?
3- Can I run the cam, edelbrock intake, and TBI setup and still get good (better then stock) performance, AND still get away with stock ECM?
4- can I run a aftermarket CAM if I'm running the TBI, edelbrock intake setup?
PLEASE HELP.... If you are running a similar set up or have in the past I could use your feedback!!!
Thanks in advance Jeepers!!!
firzout is offline
