My TJ LCOG build "Uncharted" - Page 9 - JeepForum.com
post #121 of 277 Old 09-16-2013, 10:13 PM
Hendrix
TJOTY 2013
Hendrix's Avatar
Great build man. Sorry you are always getting hurt, To better luck in the future. Keep it up.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #122 of 277 Old 09-17-2013, 01:10 PM
jeepwrangler97
Originally Posted by IceKnight View Post
That is really tight fit, I'm very interested to see how close mine is at full flex. Ill take some pics when I get into it. Hopefully next weekend.
Can't wait to see the pics...mine hits on any minor bumps & it sucks if I have people in the back
Sent by a messenger bird
jeepwrangler97 is offline
post #123 of 277 Old 09-20-2013, 06:59 AM Thread Starter
IceKnight
IceKnight's Avatar
Yeah I am hoping to be back to normal functionality soon. I am finally getting some movement in my wrist again. But its most definitely still healing so I have to remember to take things slow and easy and not push myself. Which is very hard for me.
I have made some progress over the past few days on some little stuff though.
I got to prime my front grille yesterday, I'm hoping to sand and paint it this afternoon. Working on installing a new heater core because its out now and I don't want to deal with it later. My luck it would blow right after I get the dash back in and all wired up. My fuel injectors came in and they are on the fuel rail, still have a few questions on those, they have plastic caps on the end that will not allow it to fully seat and seal, maybe I just need to push more but I don't want to hurt something so I'm awaiting an answer from the place I purchased them from. Got my Artec truss in the other day...all I can say about that is strait up beef, this thing is a perfectly crafted monster, really looking forward to getting it all set up over the next week or so. Also picked up a Rokmen Rear coil spring and adjustable bumpstop correction kit from a guy here on the board. So when I do my axle Ill get that done. One less thing to do down the road. Although I wish I had done this when it was just a frame, now I have to repaint the back end, not looking forward to that. Ill get some pictures of everything today.
Going to try and pull my 8.8 and start striping it this weekend or work on installing the grille if its dry and begin laying in the wiring harness. Also have to set the motor to TDC, prime the oil pump, and put the spark plug wires and distributed in. lol Not to mention the dash and all the fun that goes along with installing that. And the transfer case shifter. I'm going to stop thinking about everything I have to do still because I'm sure I could go on forever.
IceKnight is offline
post #124 of 277 Old 09-20-2013, 08:50 AM
AngryTJ
A lot of hard work going into this build. You posted earlier you were hoping to be done by spring so whats your new deadline?
AngryTJ is offline
post #125 of 277 Old 09-20-2013, 08:55 PM Thread Starter
IceKnight
IceKnight's Avatar
Well... spring lol
Honestly asap, but at the same time I don't plan on driving it during the winter, but a few runs in the snow before salt hits the ground would be fun. Like any project I take three steps forward one step back lol I'm hoping over the next few months that will change.
post #126 of 277 Old 09-30-2013, 09:54 PM Thread Starter
IceKnight
IceKnight's Avatar
So I've done quite a few things over the past week. And I have a bunch of photo's/write up's to go along with them.
Quick list
- Sanded and prep grille, prime
- install front fenders
- install fuel injector
- Artec 8.8 truss
- removal brackets from 8.8
- Rokmen upper spring seat, removal and installation
- stage and tack brackets on axle check everything
- fully weld all brackets
- and install Yukon ultimate 8.8 c-clip eliminator chromoly axle kit
The wife and I sanded down my front grille and I primed it in preparation for paint.
After that she helped me get the drivers fender bolted up to the firewall.
I tossed the factory intake in to see what the clearance is looking like. Have some ideas but I'll have to see what I can come up with.
Here are a few close-ups of the fuel injectors I'm going to be running. They will offer more flow for the 4.6 engine, along with better fuel atomization.
Then came the first look at the truss. box was weighty coming in at around 46 lbs. It made sense as soon as I opened in up
I was able to pull a few pieces out to mess with. This step-up is really heavy duty. Ill be very interested in the Dana 30 truss for my front axle from Artec.[/URL]
post #127 of 277 Old 09-30-2013, 10:31 PM Thread Starter
IceKnight
IceKnight's Avatar
Next came time to remove the brackets on the axle that where way off from where they should have been. My brother was over so he helped me get those removed.
It took much longer then I expected to get everything cut off and cleaned up. But it got done.
I just tossed the upper part of the truss on to see how it lined up and it fit perfectly. The keyed truss system they have is really nice, definitely allows for a easy set up.
After playing with that for a bit and checking out what was going to be trimmed and adjusted on the housing itself, I turned my attention to the next big thing...the Rokmen rear spring re-locators.
This is how the spring looked before.
The curve in the spring does nothing good for anyone, so on to cutting.
First up is the tub, I raised it up just with a 2x4 to get extra working room on the inside frame rail. That extra little bit made all the difference
Its a tight fit cutting on the inside of the frame but a Dremel did work alright.
Only about half way through here.
After that I moved on to the outside of the frame and used a cut off wheel and a chisel to remove the rest.
Cleaned up the frame rail and it was ready for installation.
Welded up the new spring perches.
post #128 of 277 Old 09-30-2013, 10:42 PM Thread Starter
IceKnight
IceKnight's Avatar
Didn't really get any pictures of the truss getting tacked up but really its not needed. We just tacked the major things together and slid the axle under the Jeep and bolted everything up to make sure, A. that everything fit, B. that clearance was not going to be an issue and C. to center the bump stop.
Clearly you can see how much the spring has been able to straighten out now that the perch has been moved.
And now that bump stop and the pad will actually hit one another where as before they would miss...making the rear bump stops completely useless.
That is almost at full compression and I still have about 1.5 inches of shock left which is what I was looking for.
The rear differential cover is...well...close. lol
We'll have to see what happens on the road.
One other thing I did was cut the abs sensor housing surround down a bit and make a block off plate for sway bar clearance.
post #129 of 277 Old 09-30-2013, 11:09 PM Thread Starter
IceKnight
IceKnight's Avatar
Next came the Yukon 8.8 Install
Tools
Slide hammer
Bearing puller
Grinder
Files
Wrenches 9/16
20 Ton shop press
and I used a band saw to make my life simple for cutting.
First thing you need to pull the seals and bearings out of each side of the axle and stuff a rag in the tube to catch the shavings for the cut.
Next make your cut, remember to leave the shoulder on.
Clean up the edge of the tube use files to deburr the edges.
Next take the bearing race, bolts, spacers and nuts and loosely place them on the axle. Don't forget to add some silicon to back side of the bearing race to seal it against the housing.
Tighten in a x-cross pattern until bearing race is fully seated.
At this time you can usually put on the backing plates, but I didn't bother because I still have painting on the axle to take care of.
Next its off the the press.
Stacking order is
Retaining plate
Spacer
Bearing seal
Bearing
Bearing retainer
Press everything together and then check for fitment.
Install the wheel studs with some red loctight and 90 ft lbs in your correct bolt pattern
post #130 of 277 Old 10-01-2013, 06:57 PM
jeepwrangler97
pics! Haha I like the look of that truss & whole setup.
On my phone now, but it looks like your diff cover does clear
...I think I said I have a solid cover, I have a riddler cover, but was looking at the solid for possibly more clearance
post #131 of 277 Old 10-01-2013, 09:53 PM Thread Starter
IceKnight
IceKnight's Avatar
Yeah its a tight fit that's for sure. Ill measure the depth of the solid cover so you can compare it to yours. The control arms are just about 1/2 inch longer then stock and it clears. As soon as my new order of rust bullet shows up tomorrow and I paint the frame, I'll get the axle bolted up and rerun the axle movement and check for clearance again. I also need to check and make sure my tires will stay out of my rear guards at full twist.
I'd like to paint my grille tomorrow morning if the weather is good. I'm just hoping the paint dries faster this time then it did last time. I'm using tractor paint from Tractor Supply, it takes along time to dry but does seem to hold up very well. I really want to get the front end buttoned up so I can really start wiring things under the hood.
I do still need to cut my hood... I keep putting it off maybe I'll try and do it as well tomorrow. I'm just nervous about making the cut wrong... Kinda funny seeing how much work I've done yet I'm nervous about cutting the hood. Lol
post #132 of 277 Old 11-04-2013, 12:45 PM Thread Starter
IceKnight
IceKnight's Avatar
So I haven't made much progress since my last post. I did try giving my hood the cut, which the initial three inch cuts came out very nice. It was that pesky second angle cut I completely botched up. Instead of cutting on a flat plane my stupid head thought an arched cut would be a good idea...sufficely to say I picked up a new hood for $25 I'm going to try again this week.
On another note, my rear axle is all painted and bolted in under my Jeep. I just have to check & re-check the pinion angle, then order a rear drive shaft and that will officially be put to bed.
Other things that need to be done. Start laying the wiring harness into the engine bay, dash and body, install radiator, gas filler neck (cant seem to find one of these anywhere) check torque on every suspension bolt, prelube oil pump and motor, set timing, install transfer case shifter, wire the head lights new turn signals and brake lights.
post #133 of 277 Old 11-12-2013, 05:48 PM
jeepwrangler97
I finally did my cowl intake, I'll post some pics/videos in my thread, once they upload.
I think it will be a good setup for keeping water out.
& the sound with the Stroker/exhaust/intake is absolutely awesome. The intake isn't annoying, I can only hear it when I play with it to make noise
post #134 of 277 Old 11-12-2013, 07:13 PM
gst95dsm
Chop, Wheel and Rebuild..
gst95dsm's Avatar
Just want to say nice work man. Lot's of very good photos also. You've inspired me to clean up a few things on my own rig. Keep up the good work.
gst95dsm is offline
post #135 of 277 Old 11-28-2013, 07:22 PM Thread Starter
IceKnight
IceKnight's Avatar
Thanks guys for the complements its been along process but I'm almost there. I'm glad that my contributions have motivated others to work on there own Jeeps.
I have made some progress over the past few weeks, I've installed all the wiring and dash is mostly in, its kind of funny how long simple wiring takes even though I had every single plug marked. I still have to rewire the new lights in the grille and the new taillights. I am waiting on some LED's for my front markers and my reverse lights as well. I modified and mounted the passenger side fuse box and drivers side fuel system on the fenders. Ill get some pictures up over the next day or so with the mounting locations so ppl can have a reference for the Rokmen fenders. Finally got and installed the rear sway bar links as well.
I think I also have come up with another idea for my intake but more on that later if I can make it work.
10 years driving jeeps...finally got a rubi! Jeepson33s Jeep Builds 4 05-20-2011 09:54 PM
3rd Jeep in 4 years.. mjw22 Jeep Builds 35 02-04-2009 07:09 AM
My jeep over the years.. Dana44 Jeep Builds 5 06-14-2005 06:55 PM
day 1 and 2.5 years later DaMoose Jeep Builds 9 03-31-2005 01:02 PM
Took 3 years to get to do this!!! BESRK Jeep Builds 10 12-26-2002 09:49 PM
