My TJ LCOG build "Uncharted" - Page 8 - JeepForum.com
post #106 of 277 Old 09-10-2013, 12:52 PM Thread Starter
IceKnight
Thanks
That's def true. Makes you appreciate everything a little more that's for sure.
So interestingly enough, apparently when I built my rear axle (welded the mounting hardware on), at that time I was not planning on running an SYE (not sure why) but now that its clearly installed on the transfer case and the axle is under the Jeep, I went to line up the pinion to the back of the transfer case housing and its clearly way off, as in shocks wont bolt up correctly because the mounting point is under the axle, and the track bar is no where near the correct location. So, I order up an Artec truss yesterday. Going to cut off and clean everything up and use this beefy kit instead. Cant wait to get this thing in and get the rear drive shaft ordered up.
Seeing as I'm pulling the axle apart again I'm thinking of picking up a Yukon 8.8 kit. Has anyone done this kit, and if so how do you like it?
IceKnight is offline
post #107 of 277 Old 09-11-2013, 04:02 PM Thread Starter
IceKnight
A little while back I pulled the fan shroud off my radiator and found it was junk, one of the spot welds had let go on the bottom and it had separated. At that moment I was not very happy about it.
Fast forward to yesterday when I took it down to a local guy that has been repairing radiators for over 40 years and he explained the ins and outs of cheaper replacement radiators and the junk materials they use. When I purchased this I thought I was getting A. A good deal and B. Not a cheap replacement.
He made a few phone calls for me gave me two numbers one to rebuild the one I had ($537) or a new aluminum USA made one ($210). I opted for the aluminum.
I was expecting to pick up a "decent" radiator from him because the cost was only $210. I'm happy to say that I'm very glad my other radiator broke. This new radiator he got me is almost double the thickness of my "stock replacement" it seems like. I definitely don't have to worry about this falling apart. Also combined with my F.A.L. fan this should do one heck of a job cooling the motor.
post #108 of 277 Old 09-13-2013, 01:59 PM Thread Starter
IceKnight
I'm seriously going out of my mind not being able to work on my Jeep.
I got my Novak transfer case shift setup in today and it's just mocking me sitting in the box here.
Along with my fenders, my grille that needs painting, my hood that needs cutting, my rear axle that needs preping... AARRRGHGHH so much to do why oh why am I stuck with a broken arm.
post #109 of 277 Old 09-13-2013, 09:44 PM
jeepwrangler97
That's sucks! When/how did that happen?
Sent by a messenger bird
jeepwrangler97 is offline
post #110 of 277 Old 09-13-2013, 09:51 PM Thread Starter
IceKnight
Well its been around two months since I've posted anything about my Jeep... you see about two days after I did the fuel pump and some brake line stuff (that will be up soon) I smashed my head and was lucky enough to get 7 staples in my head.
I healed up just in time for a trip to Duluth for an AMSOIL meeting. I came home and spent two weeks at work right before my vacation (Las Vegas and surrounding national parks for hiking) and a tire at my work (split rim) blew-up in my face while filling it with air (boss "set up" the rim and tire, he didn't bother to check and make sure the rim and tire size where compatible) and rocketed me across the garage. I was lucky enough to only have a large egg under my chin, extremely sore jaw (it was shifted 3/4 of an inch to the right) and a broken left arm. I finally have enough motion in my arm so I can type. Kinda funny because just this week I can give a thumbs up with my left hand now.
So back to my Jeep.
I got the brake lines installed before I got the tub on the frame. But because I built the upper control arm mounts I needed to build a small bracket for the brake line from the axle to attach to the brake line on the frame. So here are a few quick shots of that.
Yeah it does but I am determined to do something to my jeep tomorrow even if its something small.
Above is what happened.
post #111 of 277 Old 09-13-2013, 09:58 PM
jeepwrangler97
Oops...I guess I hadn't read all the way through the thread.
Glad you're relatively alright.
I've been looking at the artec setup myself...my 8.8 was not setup with a sye in mind. It works now but when I put new springs in the rear, it might not. & idk if is the brackets I got or what...but mine does not clear my gts & that's with.the savvy skid. It's not awful...but it hits on any bump past very minor.
post #112 of 277 Old 09-14-2013, 07:36 AM Thread Starter
IceKnight
The Artec stuff does look nice, I'm hoping to do a write up on the install. It should show up I think on Monday or Tuesday, then I have to pull my axle and strip it all down.
Do you have a thick diff cover? Or is your axle pushed back further than stock?
post #113 of 277 Old 09-14-2013, 11:09 AM
jeepwrangler97
I have a solid diff cover which is supposed to be pretty good clearance wise. I'm not sure why it hits so much. When it was originally installed (by a 4x4 shop that's now out of business), I had stock upper CAs, stock diff cover, stock gas tank skid & it was pretty much resting on the gts...once I had the diff cover, savvy gts & the adjustable uppers it was better. I'll get some pics tomorrow.
My pinion angle is ok now, but my uppers are fully extended, so when I lift at all I'll need more rotation....& even if I can make up the rotation with lowers, I'm not sure how the tb & the shocks & everything else will work
post #114 of 277 Old 09-14-2013, 09:45 PM Thread Starter
IceKnight
Yeah that's happened with mine. I originally set it up for a standard drive shaft but ended up getting an SYE so now that I have started to rotate the axle up for correct drive line angle the shock mounting points are under the axle by quite a lot and the TB mount is not even close.
I have the same differential cover so now I'm hoping at full stuff I don't run into any interference with my gas tank skid.
Do you have the factory ford LSD in yours?
post #115 of 277 Old 09-15-2013, 09:58 AM
darkknight1999
Looking good dude
darkknight1999 is offline
post #116 of 277 Old 09-15-2013, 12:36 PM
jeepwrangler97
I've heard & seen pics of other guys running the same diff cover on low/no lift & not having an issue, I'm not sure why mine does.
Yeah, I do have the factory LSD which seems to work pretty well. I've liked it on little climbs & things when I've had tires off the ground & it seemed to help.
post #117 of 277 Old 09-15-2013, 05:57 PM Thread Starter
IceKnight
I'll take a bunch of pictures after I'm done with my axle to show the clearance I have. Hopefully with the adjustable uppers and lowers I'll have enough clearance. I'm really shooting to make the control arms as long as I can with no interference while keeping the pinion angle happy.
Glad to hear it, I want to get a locker but its just not in the cards until I get super 8.8 axles in there to rid myself of the c clips. In the long run I'll be in and out of the housing a few times but I'd rather do it on my terms then stuck in the woods.
post #118 of 277 Old 09-15-2013, 06:40 PM
jeepwrangler97
Yeah, I've had a few times going up things where one front tire is off the ground, one rear & taking it slow the rear would kind of push it through without having to spin the tires or hit it hard.
Sorry, no pics of my pinion angle & everything else today, there was too much rain. I'll snap some tomorrow or the next day, depending on the weather.
post #119 of 277 Old 09-16-2013, 05:31 PM
jeepwrangler97
Pics of my diff. It's kind of dark in the pics, but you can see, it's very close to clearing, but is maybe 1/2" too far back. I posted some pics of the pinion angle in my thread.
post #120 of 277 Old 09-16-2013, 07:56 PM Thread Starter
IceKnight
That is really tight fit, I'm very interested to see how close mine is at full flex. Ill take some pics when I get into it. Hopefully next weekend.
10 years driving jeeps...finally got a rubi! Jeepson33s Jeep Builds 4 05-20-2011 08:54 PM
3rd Jeep in 4 years.. mjw22 Jeep Builds 35 02-04-2009 06:09 AM
My jeep over the years.. Dana44 Jeep Builds 5 06-14-2005 05:55 PM
day 1 and 2.5 years later DaMoose Jeep Builds 9 03-31-2005 12:02 PM
Took 3 years to get to do this!!! BESRK Jeep Builds 10 12-26-2002 08:49 PM
