My TJ LCOG build "Uncharted" - Page 5 - JeepForum.com
post #61 of 277 Old 01-05-2013, 07:34 PM Thread Starter
IceKnight
Next was back to the case to install the front and rear shafts along with the chain. (Side note, when we first installed it in the case the chain was slightly binding, this is normal, after you install the yoke is pulls everything into proper position.
Notice the cleaned edges of the mating surface of the case. Next came The Right Stuff for making the gasket and sealing the cover back on to the housing along with the installation of the oil pump. A lower retaining ring was placed on then the speed-o-drive gear and another retaining ring to top it all off.
On occasion the shift rail needs to be shortened to clear the new cover, I lucked out and didn't have to touch mine, it fit perfectly.
I place another proper coating of The Right Stuff on the rear housing and bolted it in place.
Re-installed the speedo gear
And last but not least we installed the new seal washers both front and rear along with both the yokes.
That's the short and dirty version of installing an SYE on an NP231
IceKnight is offline
post #62 of 277 Old 01-05-2013, 07:39 PM Thread Starter
IceKnight
I had some extra time so I bolted up my Rokmen transmission skid and fitted the JKS rear track bar as well.
post #63 of 277 Old 01-05-2013, 08:57 PM
TrailJ
Nice write up thanks!
'06 LJ
TrailJ is offline
post #64 of 277 Old 01-05-2013, 09:03 PM Thread Starter
IceKnight
Sure thing.
post #65 of 277 Old 01-05-2013, 10:56 PM
oalali
nice work man ..
I would love to see how it ends ..
oalali is offline
post #66 of 277 Old 01-05-2013, 11:17 PM
98grandcerokee
Great build, i'm gonna check on it more often
98grandcerokee is offline
post #67 of 277 Old 01-07-2013, 10:18 AM
Morris369
Larry's in Danielson is another shop around, he builds alot of the motors for the cars up at thompson speedway. I've had some good and bad experiences with both J&R and Larrys so I figured I'd ask to see if there were others around that I didn't know about. Regardless, I'd only be having them clean, magnaflux and bore my block (whenever I get my hands on one for cheap enough) and a valve job. I'd be porting and polishing the head myself and building the rest of the motor myself.
Can't wait to see this thing when it's done.
Morris369 is offline
post #68 of 277 Old 01-07-2013, 06:14 PM Thread Starter
IceKnight
Kinda funny because that is exactly what I am doing. Having him do most of the machine work (clean, magnaflux and bore) and then do the build and P&P myself. I'm thinking I'm going to do a write up of that also...that is going to be a lot of pictures.
And I cant wait to see it all finished up as well.
post #69 of 277 Old 01-07-2013, 06:23 PM
Morris369
Good deal, take lots of pics and post them for sure. I'm sure a lot of guys on here would be interested in seeing them.
post #70 of 277 Old 01-08-2013, 06:13 AM Thread Starter
IceKnight
Now i just need to get my block and head over to the shop and order up all the parts i need to put it back together.
post #71 of 277 Old 01-08-2013, 06:16 AM Thread Starter
IceKnight
And as soon as i get it back im going to start the build. I'll def keep the pictures coming.
post #72 of 277 Old 01-08-2013, 01:27 PM
djflyy
Great build. Jealous that you've got a garage to strip it down and rebuild in.
I do have one question/thought/concern - you posted recently the photos of installing the JKS rear track bar, it caught my eye that you installed it the way you did. I recently installed the identical bar in my TJ to replace the POS Rough Country that I had finagled a year and a half's use out of. When I installed the JKS, I put the rubber bushing on the frame side and the Johnny Joint on the axle side. Their website features a photo of the identical configuration:
Just wondering why you did it the way you did, and if there's anything you might know that I don't!
djflyy is offline
post #73 of 277 Old 01-09-2013, 05:07 PM Thread Starter
IceKnight
Kinda funny that you mention that, my friend found it in my pile of parts, grabbed it and put it in the other day. Although now that i'm looking at it your right...plus the bar has poly bushings on both ends...the only JKS bar that has ploy bushing on both ends is for the ZJ. Now I'm wondering if I was sent the wrong bar from the company I purchased it from. Ill have to call JKS tomorrow. Thanks for drawing my attention to this.
post #74 of 277 Old 01-14-2013, 04:41 PM Thread Starter
IceKnight
Finally dropped my completely stripped down block and head today at the machine shop.
What I am planning on for my motor is the following build specs.
4.6L Daily Driver
Jeep 4.2L 3.895 stroke crank out of an '87 or 88. Got the motor for free
Jeep 4.0L 6.125 rods from my motor
Just ordered KB IC944-030 pistons with Hastings rings
CompCam 252H Grind 68-200-4
Mopar Head Gasket 0.043
And have the block decked .020
Ford 24lb injectors
I am going to be doing a port and polish job on the head myself
I'm planning on using my over bored throttle body and a matched bore intake manifold along with my high flow exhaust. I'm still not sure what I am going to use for an intake. I wanted to use a Banks set up but not 100% sure what is going to fit with the Rokmen High Fenders, anyone with any ideas.
I am going to be, and others, driving this a lot on the road and want it to run a smooth as possible with as few issues as possible. Would love to get a little crazy, but having something that performs regularly and with out problems is more important to me.
post #75 of 277 Old 01-16-2013, 08:19 AM
oalali
Nice plan !
oalali is offline
10 years driving jeeps...finally got a rubi! Jeepson33s Jeep Builds 4 05-20-2011 08:54 PM
3rd Jeep in 4 years.. mjw22 Jeep Builds 35 02-04-2009 06:09 AM
My jeep over the years.. Dana44 Jeep Builds 5 06-14-2005 05:55 PM
day 1 and 2.5 years later DaMoose Jeep Builds 9 03-31-2005 12:02 PM
Took 3 years to get to do this!!! BESRK Jeep Builds 10 12-26-2002 08:49 PM
