My TJ LCOG build "Uncharted" - Page 2 - JeepForum.com
post #16 of 277 Old 09-18-2011, 03:18 PM Thread Starter
IceKnight
Back to my Jeep. The last thing that was done to it before going under the knife was a new soft-top. I had been eyeing a Rampage top for quite a while now. I like the ability of going to a safari top in just a few moment works out great.
Best part, once again my awesome wife had ordered it through my own business contacts right under my nose and had it shipped to the house very sneaky sneaky.
IceKnight is offline
post #17 of 277 Old 09-18-2011, 03:25 PM
ctorres018
1930 JK Wrangler
How much did u get your manifold(headers) for and where? I bought my jeep with a cracked manifold also. I also just bought the rampage top for my tj, I like it alot
http://www.jeepforum.com/forum/f22/light-sleeper-2-0-a-1800073/
ctorres018 is offline
post #18 of 277 Old 09-18-2011, 03:35 PM
BrandonJames
1974 CJ5
Thats a nice looking H1, only hummer I would ever own. Theres a guy around here that drives a solar yellow one, its pretty sweet.
BrandonJames is offline
post #19 of 277 Old 09-18-2011, 07:50 PM Thread Starter
IceKnight
I think at the time I paid like $130 for it I got it off Ebay. But I have an account with Crown and can get them for about $130 still direct from them.
I can defiantly say that the top is nice, really easy to install and fits great.
post #20 of 277 Old 09-18-2011, 07:53 PM Thread Starter
IceKnight
They really are amazing trucks, the stuff they can do in stock form is awesome. I will own one someday, it was a tease having a close friend with one that didn't mind who drove it.
post #21 of 277 Old 09-19-2011, 11:21 AM Thread Starter
IceKnight
This it the HP Dana 30, I pulled it and my 8.8 from a local junk yard. $125 for the D30 and $150 for the 8.8. The D30 came out of a 1999 Cherokee and the 8.8 came out of a 2001 Ford Explorer. I ended up getting a set of 4:10ís for the D30 and 8.8 from a local club member that just swapped out his gearing for a great price.
I added a little strength in a few spots on the D30 and replaced the upper control arm bushings while I was at it. I sprayed on a little cover up paint for the time being, planning on doing Rust Bullet on it.
I shaved everything off the 8.8 after I got my mounting kit in from Iron Rock Offroad. Really nice kit, more pics of it to come. Also picked up the Currie brake hardware mounting kit. Here is a few quick picís of the spring perches.
post #22 of 277 Old 09-19-2011, 11:24 AM Thread Starter
IceKnight
The 8.8 came through with the factory LSD. I swapped the gears over on both of the axles. Ended up getting a new carrier for the D30, the axle I got had 3.55's in it. And I also got Yukon master rebuild kits for both. And a quick pic of my Rust Bullet stuff...gotta love living in the rust belt.
post #23 of 277 Old 09-19-2011, 11:31 AM Thread Starter
IceKnight
Currie brake parts kit.
Here are the rebuild kits and the brakes for the D30. As you can tell by now, I have been buying parts for just a little while now. And there's more to come.
post #24 of 277 Old 09-19-2011, 11:38 AM Thread Starter
IceKnight
On to the frame.
So here is the frame I am currently working on. Rear part of it near the control arms was already having problems so I solved that by cutting it out and replacing on both sides and then fish plateing over it. I only have a few pics of this, frame is still at a friendís house, hopping to get it home this weekend.
post #25 of 277 Old 09-19-2011, 11:44 AM Thread Starter
IceKnight
Also on the frame, the kid I bought it from partially cut the track bar mount off. So I finished cutting it off and picked up a TNT front track bar kit. Great product very beefy and keyed up right in place.
post #26 of 277 Old 09-19-2011, 12:49 PM Thread Starter
IceKnight
The last thing I wanted to do was replace all the nutserts for the transfer case skid a few of them where already broken so I ordered up 6 of them and got to work.
I cut the spot welds off of each one, and used and air chisel to get them off. The inside part falls into the frame but I will be getting those out when I move the frame to my house. Installing them is very easy, was most likely easier for me also because the frame was upside down. I used the install "tool" and I started each one with an impact so as to not kill myself making the metal initially start to flex and then finished each off with a torque wrench to 80ft lbs. Tacked them in and it was done. I think it was the easiest fix on the frame so far.
post #27 of 277 Old 09-19-2011, 12:55 PM Thread Starter
IceKnight
So this is what's left of my Jeep now, still in the process of pulling everything off my old frame and tub. Driveline is out and awaiting tear down which should be happening soon. I want to get my frame and tub out of the garage first, which shouldn't take to much more.
post #28 of 277 Old 09-19-2011, 01:20 PM Thread Starter
IceKnight
So that's basically where I am now. I have a pile of stuff waiting to be used like a Rokmen tansfer case skid and gas tank skid, F.A.L. electric fan, Old Man Emu 2.5 lift springs, JKS Rear adjustable track bar, all fluids for my Jeep will be from AMSOIL, Solid front and rear differential covers with LubeLocker gaskets.
Still have my ARB Rocker Guards and Mopar Rock Bumper, along with my JKS quicker discos, Rusty's Braided SS brake lines and my NRG / Momo removable steering wheel, will be transferring all stereo equipment with the additions of a newly redesigned sound bar that holds an 8 inch sub along with the normal 6.5 speakers and dome light.
And the big brown truck should be dropping more stuff off today.
post #29 of 277 Old 09-19-2011, 01:27 PM Thread Starter
IceKnight
So here is the removable steering wheel. I have a write up for this but never got around to posting it. Its a great system components are made by NRG a company more well known to car then Jeeps and trucks, super conformable steering wheel and the last picture has the steering wheel lock on it.
post #30 of 277 Old 09-19-2011, 01:33 PM
MagnumPI
Kick-*** steering wheel man. What all did you have to do to replace it I was thinking about changing mine out as well. Also How do you feel about not having an airbag now? Thats like the only thing stopping me from switching mine out...
Yellow Jeep Club Member #1337
MagnumPI is offline
10 years driving jeeps...finally got a rubi! Jeepson33s Jeep Builds 4 05-20-2011 08:54 PM
3rd Jeep in 4 years.. mjw22 Jeep Builds 35 02-04-2009 06:09 AM
My jeep over the years.. Dana44 Jeep Builds 5 06-14-2005 05:55 PM
day 1 and 2.5 years later DaMoose Jeep Builds 9 03-31-2005 12:02 PM
Took 3 years to get to do this!!! BESRK Jeep Builds 10 12-26-2002 08:49 PM
