My TJ LCOG build "Uncharted" - Page 12 - JeepForum.com
post #166 of 277 Old 01-12-2014, 05:10 PM
jeepwrangler97
Wow, looks good!
...what'd you do with the old padding
I just added some 6.5" alpines, a few weeks back. Now my stock front speakers are way over powered
Sent by a messenger bird
jeepwrangler97 is offline
post #167 of 277 Old 01-12-2014, 06:03 PM
Hendrix
TJOTY 2013
Hendrix's Avatar
Originally Posted by IceKnight
Thanks. I've been doing audio for quite awhile. There are lots of different ways to do what I did, but this is how I have been building systems for years so I stuck with what I knew worked.
Very nice work on the sound bar.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #168 of 277 Old 01-12-2014, 08:08 PM
G Beasley
That is super clean work ...
G Beasley is offline
post #169 of 277 Old 01-12-2014, 11:40 PM Thread Starter
IceKnight
Thanks guys, I'm really looking forward to fully completing it over the next few weeks.
and it sounds like someone needs a new set of front speakers.
IceKnight is offline
post #170 of 277 Old 01-22-2014, 05:35 PM Thread Starter
IceKnight
Ordered up my Tom Woods drive shaft Monday cant wait to get it installed.
On a crappy note, I went to replace my clutch master cylinder ended up braking the plastic clip that holds the shaft to the pedal...I've checked the local stores and have found nothing for a replacement. Anyone have any fix it ideas?
post #171 of 277 Old 01-22-2014, 07:04 PM
jeepwrangler97
I read something about that clip in a build thread recently...I think
...I'll try to find whatever I read b/c I know they said it was hard to find
Edit: it was from 290tjjeep's build thread. I'm not sure if you two are talking about the same bushing.
Originally Posted by 290tjjeep View Post
Had quite the adventure today! Went to leave for work this morning and I decided the WD-40 my clutch linkage because it was squeaking and this plastic bushing/clip fell out...
Managed to find a new one at a local auto store so that was cool! Popped it in and everything seemed good. Took the jeep for a test drive and went driving back home the cable popped out lol. So I put the transfer case in neutral and pulled over. What I ended up doing is added a stainless steel cable tie along with the new bushing/clip. The real problem is that the cable linkage and the rod that it attaches to is worn out, causing the new bushing/clip to still pop out. So by adding the cable tie should keep it from popping out.
...don't know if that's helpful at all
post #172 of 277 Old 01-22-2014, 07:10 PM Thread Starter
IceKnight
Thanks, I have been looking and have not come up with much.
post #173 of 277 Old 01-23-2014, 10:27 AM Thread Starter
IceKnight
Ending up finding something I think will work. Ill post some pictures when I get around to installing it later on this week/weekend.
Another project I have to finish is mating up two jeep dash switch panels to fit as factory as possible for the switches I am going to have. That'll be a write up as well.
more to come...
post #174 of 277 Old 01-24-2014, 08:56 PM Thread Starter
IceKnight
I worked on my Jeeps switch panels this afternoon. I mounted two OEM panels next to each other and got switches that match as close as possible to factory.
Here are the switches I picked up, rear wiper is factory, then I picked up cooling fan for my FAL radiator fan, horn because my steering wheels horn button does not work, spot lights and soon a light bar.
Here are the two panels I was working with.
And removing the last three blanks from the second panel.
Dash panel before I started cutting and then after.
(Sorry about the crappy picture)
My first trimming of the switch panel, removed the mounting holes and support ribs of the second (passenger side) panel.
Next I created a cut out template of the shape I needed to replicate for the panels to mount flush against one other.
I then transferred the outline of the template onto the passenger side switch panel.
Next I used my dremel with a plastic cut off wheel to trim the outline.
After a bunch of sanding down of the edges to make the fitment just right, I bolted the two switch panels together. You’ll also notice that on the left hand side of the picture the panel has been cut off already. I did this before bolting them together. I placed both of the panels, switch side down but in opposite position of how they will be mounting in the Jeep and holding them flat on the bench I traced the mounting height of the side panel, on to the panel I needed to cut to match the correct height for the passenger side mounting location.
Here I marked out on the dash where I would be drilling the mounting holes.
First holes drilled in the dash and then I place the screw retainers in the holes.
I test fit the switch panel and it fit like a glove. I attached it with a piece of l-shaped plastic I had laying around. Some of you may recognize the piece it came from.
And here is the finished installation…still need to finish up the actual wiring part of things but Ill be working on that tomorrow.
Ill try and add some more details later on.
post #175 of 277 Old 01-26-2014, 06:07 PM
whiskeywiz
Originally Posted by IceKnight View Post
On to the frame.
So here is the frame I am currently working on. Rear part of it near the control arms was already having problems so I solved that by cutting it out and replacing on both sides and then fish plateing over it. I only have a few pics of this, frame is still at a friend’s house, hopping to get it home this weekend.
Nice work, looks familiar. Shouldn't have any problem getting that inspected, even if you don't know a guy.
whiskeywiz is offline
post #176 of 277 Old 01-26-2014, 06:16 PM
whiskeywiz
The last thing I wanted to do was replace all the nutserts for the transfer case skid a few of them where already broken so I ordered up 6 of them and got to work.
I cut the spot welds off of each one, and used and air chisel to get them off. The inside part falls into the frame but I will be getting those out when I move the frame to my house. Installing them is very easy, was most likely easier for me also because the frame was upside down. I used the install "tool" and I started each one with an impact so as to not kill myself making the metal initially start to flex and then finished each off with a torque wrench to 80ft lbs. Tacked them in and it was done. I think it was the easiest fix on the frame so far.
I was just looking at this to do on my frame today. Thinking it over. I was going to try a rethread. Did not know there was such a product out there, as the nutserts that you used.
post #177 of 277 Old 01-26-2014, 06:28 PM
whiskeywiz
So here is the progress I have made thus far with the frame, 4 coats of Rust Bullet and then two coats of the Black Shell top coat.
Gorgeous. Can't wait till I get there. I'm not far off!
post #178 of 277 Old 01-26-2014, 07:01 PM
Mattific
I worked on my Jeeps switch panels this afternoon. I mounted two OEM panels next to each other and got switches that match as close as possible to factory. Here are the switches I picked up, rear wiper is factory, then I picked up cooling fan for my FAL radiator fan, horn because my steering wheels horn button does not work, spot lights and soon a light bar.
Where did you get these? Much better than the switches I had to cut down to fit in those spots
Mattific is offline
post #179 of 277 Old 01-26-2014, 07:01 PM
whiskeywiz
So I finished up the body mounts today. I built them out of 3/16, and will be applying Rust Bullet inside the channel and outside to seal it off from the elements. Same process I used when I did my frame. Here are a few pics from today of cutting and welding. After my friend and I got going and I sort of forgot to take pictures. I am glad I chose to make them instead of buying new replacement parts (granted I have the tools to do it) and have to cut the entire channel out. Plus during the build I built those 4 locations to not need the 1/2 lift portion of my 1/2 Rokmen body lift. We'll see how it holds up.
Looks auwfly familiar! Lol. Looks like Jeep's making body mount nut replacement easier on us.
post #180 of 277 Old 01-26-2014, 07:20 PM
whiskeywiz
That same weekend I also picked up my 4" tail lights, grommets and plugs and put a hole saw to the tub. Rather simple process but something you want to take your time with and not rush. It came out really nice.
Find the center of the hole to be cut. (This was a little easier having the rear guards bolted to the Jeep that had the cutouts in it)
Pre-drill a pilot hole.
Next cut the hole
Deburr the sharp spots
Check light fitment
Paint
Drink beer for doing an awesome job
Whoa, what's up with the grab bar? For the rear-seaters?
10 years driving jeeps...finally got a rubi! Jeepson33s Jeep Builds 4 05-20-2011 08:54 PM
3rd Jeep in 4 years.. mjw22 Jeep Builds 35 02-04-2009 06:09 AM
My jeep over the years.. Dana44 Jeep Builds 5 06-14-2005 05:55 PM
day 1 and 2.5 years later DaMoose Jeep Builds 9 03-31-2005 12:02 PM
Took 3 years to get to do this!!! BESRK Jeep Builds 10 12-26-2002 08:49 PM
