~ My Savvy Jeep Build ~ - Page 26 - JeepForum.com
post #376 of 427 Old 05-04-2013, 12:19 PM
crateampscal
how many hours do you think you're going to have into the suspension(including the shock mounts) by the time you're done? I know you're not done yet, but how long does this type of thing usually take you?
crateampscal is offline
post #377 of 427 Old 05-04-2013, 03:40 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
There are too many variables to guess at that one. Some of them fall together, some continually fight you. We just finished one that took several extra hours on the front due to interference issues with an ARB diff cover. That required lots of time to cycle, grind, clearance, cycle and then we ran into an issue with the upper hitting the truss on full stuff, so we clearanced the arm, tested it, still not enough and kept going until we got the bumpstop an inch and a half apart but only by putting a kink in the arm right at the front saddle.
Kat's will take longer than that because I work on it in the evenings which always takes a lot longer.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #378 of 427 Old 05-05-2013, 02:31 AM
crateampscal
I hear that. if you would, ballpark a relatively easy install compared to a hard one like the one you mentioned.
when i swapped to your currie 4 inch, it took me 10 hours just to swap kits, maybe a little more. i had a real hard time getting everything lined up. when we did my brothers rig, it took probably half that. the extra hand really helped and we didnt have to adjust too much. these were just kits using factory shock locations.
post #379 of 427 Old 05-05-2013, 04:18 PM
calsouthjeep
I would say that when I go help Blaine we get about 3x as much work done than I could if I was doing it by myself. All the little tricks that makes things easier and knowing what exactly needs to happen really cuts down on the time. Having any tool or part you could need doesn't hurt either
calsouthjeep is offline
post #380 of 427 Old 05-05-2013, 06:12 PM
crateampscal
Ya, that must be nice. having the tools is always nice but knowing what needs to be adjusted and how much is really a time saver. he'd probably have a restraining order out on me if i lived in so cal.
post #381 of 427 Old 05-06-2013, 11:25 PM Thread Starter
JeepKat
Hmm, A ballpark is a pretty big place. How about 5 days for the more difficult one and 3 days for the easy one? Did you fall out of your chair yet? Pretty much it takes as long as it takes.
It's like the "Rock God" thing when we go camping. If you ask how long its going to take to get from one end of the trail to the other, the only thing you can count on is not knowing how long it will take.
Or the only spare part you didn't bring will be the one you need the most. Lol, Blaine didn't have any spare Banjo Bolts for his Jeep when I decided that I wanted to drive up a waterfall, I spun the tires and wedged a flat rock between the brake caliper and the axle and broke the only spare part that we didn't have
I am Savvy!
JeepKat is offline
post #382 of 427 Old 05-07-2013, 12:19 AM
crateampscal
Actually, that's exactly the answer I was looking for. heres why, I had lifted my brothers jeep after mine(second tj ever). id cycle the suspension, then show him the adjustments needed. after a few cycles and adjustments, he started to get frustrated as he kept insisting that it was close enough. I didn't like that and powered through till it was right. I believe that mrblaine could look at his jeep and hound me about some stuff that could be better.
his rides considerably better than mine, but I am not strong enough (at the moment) to straighten mine out. Even if I were to get underneath it, id want to burn in some new shock mounts and have your guy(wayne) tune some real nice shocks for me. I don't feel comfortable doing this as Im afraid of cutting too much of something, mangling the shock towers etc.
oh, and sorry Kat, I realized after reading your post that I should quit clogging your thread up, write down all my questions, and just call the mad scientist.
post #383 of 427 Old 05-07-2013, 09:12 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
There are a lot of things I do that add small amounts of time but greatly decrease the aggravation factor. When I cut the spring perches loose, I jack up the tub, drop the gas tank, and pull the cat back exhaust.
I can drop a tank and exhaust in about 15-20 minutes which is right about the amount of time saved cutting off the passenger side spring perch, but it is a whole bunch easier to get in there, provided the exhaust doesn't fight me.
I am Savvy
mrblaine is offline
post #384 of 427 Old 05-08-2013, 10:33 PM Thread Starter
JeepKat
New Rear Back-Up Lights
Tied into the Reverse Light Wiring so I don't get a ticket by turning them on by accident and blinding the people following me.
I am Savvy!
JeepKat is offline
post #385 of 427 Old 05-08-2013, 10:34 PM Thread Starter
JeepKat
Savvy Gas Tank Skid Powder Coated Semi-Black
Ready to be installed.
I am Savvy!
JeepKat is offline
post #386 of 427 Old 05-08-2013, 10:35 PM Thread Starter
JeepKat
LED Head Lights
I am Savvy!
JeepKat is offline
post #387 of 427 Old 05-08-2013, 10:38 PM Thread Starter
JeepKat
Frame Looks Like New!
Before
Blaine and Joe did an excellent job painting my frame and coating my fender wells!
I am Savvy!
JeepKat is offline
post #388 of 427 Old 05-08-2013, 11:38 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
It is that AWESOME coffee you brought out that helped give us the motivating factor.
As good as the pics are, it looks WAY better in person!
Joe Dillard is online now
post #389 of 427 Old 05-09-2013, 12:38 AM
oalali
That looks awsome !
oalali is offline
post #390 of 427 Old 05-09-2013, 06:03 AM
MilMJ11
Love how clean this build is. Can't wait to see the finished product.
MilMJ11 is offline
