~ My Savvy Jeep Build ~ - Page 24 - JeepForum.com
post #346 of 427 Old 05-01-2013, 03:37 PM
rubidriver
I considered very strongly NOT doing a mid arm build strictly for the purpose of having a rig around continually that shows what can be done with short arms, good shocks, and JJ's.
There is a very popular misconception that JJ's transmit NVH into the cabin to a degree that it is perceptible by the driver and nothing is further from the truth. In fact I just had someone pick up their rig yesterday to drive it home about 300 miles. I called him this morning to check and he said it is perfectly stable at 75 on the freeway, no discernible NVH, and it is night and day difference from how he brought it to me.
That said, if I were to build an aluminum mid arm, I would go to the larger shank JJ's and 1.75" material for the arms.
I had a feeling you would say a larger rod. Next question. Are you using spray paint? Everyone is wondering why their frame and axles arent this pretty and I can tell its not a coincidence.
2005 Black Rubicon - OME 933/942 - 4" Bilstein 5100 (canister up) - JKS Adj Track Bars Front/Rear - JKS Quicker Discos - 285/75/16
Originally Posted by bigj1974 View Post
your money will go farther in College Station.
rubidriver is offline
post #347 of 427 Old 05-01-2013, 04:58 PM
Climbit
Being a SoCal jeep helps the paint last.
Climbit is offline
post #348 of 427 Old 05-01-2013, 04:58 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Krylon Rust Tough in Semi-flat black for the frame.
Krylon Industrial Rust Tough in Gloss black for the axle.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #349 of 427 Old 05-01-2013, 05:48 PM Thread Starter
JeepKat
Originally Posted by crateampscal View Post
wow kat that looks so nice. Blaines builds are always my favorite. once i get my surgery and heal, ill be calling you blaine. come on may 29th!
I'm so sorry that you need Surgery, I'm wishing you a speedy recovery! And yes, Blaine does some of the finest work I've ever seen but then I might just be a bit biased
I am Savvy!
JeepKat is offline
post #350 of 427 Old 05-01-2013, 07:16 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Its getting closer & closer to being ready for delivery.
Joe Dillard is offline
post #351 of 427 Old 05-01-2013, 09:14 PM Thread Starter
JeepKat
The 14" Light Bar Wiring
Pretty Slick!
I am Savvy!
JeepKat is offline
post #352 of 427 Old 05-01-2013, 09:17 PM Thread Starter
JeepKat
The Driver's Side is Finished!
The Front ARB Air Line is also hooked up and the Rancho Steering Stabilizer is installed.
I am Savvy!
JeepKat is offline
post #353 of 427 Old 05-01-2013, 09:18 PM Thread Starter
JeepKat
Thank you Joe! You are doing an Awesome job!
I am Savvy!
JeepKat is offline
post #354 of 427 Old 05-01-2013, 09:48 PM
Joe Dillard
Thanks. Assisting Blaine with your Jeep has been a GREAT learning experience.
post #355 of 427 Old 05-01-2013, 11:32 PM
rubidriver
Do the passenger side springs sit closer to the edge of the spring bucket than the drivers?
post #356 of 427 Old 05-02-2013, 07:17 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
I install a lot of front springs and I've yet to see any that were the same on both sides. That is likely due to two reasons, cross caster and the fact that the lower spring perches are rotated 180 from each other.
This axle is one of the best I've seen in recent memory.
I am Savvy
mrblaine is offline
post #357 of 427 Old 05-02-2013, 11:41 AM
4wdjeepguy
Where did you ground the light bar? Or are you just running it off the negative terminal? Work is super clean BTW
IG: CS_OFFROAD
YOUTUBE: CS OFFROAD
4wdjeepguy is offline
post #358 of 427 Old 05-02-2013, 03:19 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
I ran both wires up to the behind the headlight bucket on the passenger side, split the power off to go to the relay and the ground lead got a ring terminal and attachment under the ground lug at the headlight area.
I am Savvy
mrblaine is offline
post #359 of 427 Old 05-02-2013, 09:50 PM Thread Starter
JeepKat
Steering Stablizer
I am Savvy!
JeepKat is offline
post #360 of 427 Old 05-02-2013, 09:53 PM Thread Starter
JeepKat
Tires on and Front Flares too!
A huge thanks to Blaine, Joe and Colin for cleaning up my Jeep today! Those rims look really good!
I am Savvy!
JeepKat is offline
