My rig just got taller... OME HD, (and now) .75" spacers on all four corners - JeepForum.com
post #1 of 35 Old 11-21-2005, 01:52 PM Thread Starter
thejafe
thejafe's Avatar
PICS: just got taller... OME HD, (and now) .75" spacers on all four corners
Added .75" RE coil spring spacers in the rear to match the ones I've got up front. While I was at it I swapped my rear OME HD springs from side to side because the taller spring was on the driver side even though it was marked "A". Looks like she sits nice and level now. Enjoy:
thejafe is offline
post #2 of 35 Old 11-21-2005, 01:58 PM
Texas TJ
Texas TJ's Avatar
looks like its sittin higher in the back
about .75" mabey
Texas TJ is offline
post #3 of 35 Old 11-21-2005, 02:00 PM Thread Starter
thejafe
thejafe's Avatar
Garvin swingout going back there shortly so that should bring it down a bit...
thejafe is offline
post #4 of 35 Old 11-21-2005, 02:15 PM
Legacy
hey how do you like them tires? im planning on gettin a set of those exact ones.
and yes, she does look nice.
Legacy is offline
post #5 of 35 Old 11-21-2005, 02:17 PM
BlueJ
verrrrrrr nice
1998 XJ Up Country - "The Green Chili"
BlueJ is offline
post #6 of 35 Old 11-21-2005, 02:20 PM Thread Starter
thejafe
thejafe's Avatar
I like 'em a lot... I'm using my stock rims so I'm running Spidertrax 1.25" wheel spacers in order to run the 32x11.50's. BFG AT's perform very very well offroad and perform admirably in the snow as well. I've been getting good tread life out of mine.
thejafe is offline
post #7 of 35 Old 11-21-2005, 03:37 PM
Legacy
thats good to here, especially livin up here in ny, need a good tire that runs offroad/onroad/and snow very well.
Legacy is offline
post #8 of 35 Old 11-21-2005, 05:52 PM
G-M@n
I have those same tires on my jeep, however whenever I turn sharply they rub against the finder wells. Did you have that problem before you installed the spacers? If so, did it fix it?
BTW it looks awsome!
G-M@n is offline
post #9 of 35 Old 11-21-2005, 06:33 PM
xjeepn
xjeepn's Avatar
That jeep looks sweet. Was it supose to be level with 3/4 spacers upfront before you added the back spacers.
xjeepn is offline
post #10 of 35 Old 11-21-2005, 06:45 PM
pismo61
pismo61's Avatar
2015 JK Wrangler
Whos rocker guards are you running?
2015 Red 2 Door(half) 6sp.
pismo61 is offline
post #11 of 35 Old 11-21-2005, 06:48 PM
tpe187
tpe187's Avatar
I'm looking at putting the OME suspension on my 05 sport in a month or so. I'm going to be going with BFG AT's in 32x11.5x15 also. Do you really need the wheel spacers? Thanks
tpe187 is offline
post #12 of 35 Old 11-21-2005, 07:03 PM
Legacy
why was this moved to jeep registry?
Legacy is offline
post #13 of 35 Old 11-21-2005, 09:43 PM
CBlakeNS
Very nice pics!!! Looks good.
CBlakeNS is offline
post #14 of 35 Old 11-21-2005, 09:51 PM Thread Starter
thejafe
thejafe's Avatar
Yeah, if you don't run the spacers with stock rims and 32x11.50's you will rub the front lower control arms when you turn. Try a search for jdlawhon... he's running 32x11.50's without wheel spacers. He achieved this by trimming his spring perches and adjusting his steering stops.
thejafe is offline
post #15 of 35 Old 11-21-2005, 09:53 PM Thread Starter
thejafe
thejafe's Avatar
My rockers are made by Sun Performance...
thejafe is offline
Longshot but does anyone have... (TJ w/ 3.5" lift, 1.75" coil spacers, and 36" Iroks) Daylan Jeep Picture Requests 0 08-27-2009 01:58 PM
Rear corners with a 3" flare? Apex Jeep Picture Requests 3 08-23-2009 07:39 PM
TJ 4" lift (3" + 1"BL) 35s, T&T Corners & Phantom Fenders Dogman Jeep Picture Requests 5 05-21-2009 07:47 PM
TJ's with 2"coil spacers and 2" body blocks 6stringboarder Jeep Picture Requests 0 01-28-2009 08:38 PM
calling those w/ 17" rims or taller on mud tires CCJ Jeep Picture Requests 30 01-03-2009 06:16 AM
