My Official Build Thread 1992 YJ "Emma" - Page 15 - JeepForum.com
post #211 of 677 Old 09-08-2013, 07:33 PM Thread Starter
Gage56
Got some more of the rock lights done but i ran out so now i have to order another roll of them to finish up But none the less here are some more pics
Sun just going down
And After Dark
1992 YJ
Gage56 is offline
post #212 of 677 Old 09-08-2013, 07:49 PM
Dre40
Awesome lights idea. Very nice Job..
92 YJ 4.3L Vortec SM-465/NP241.
80 CJ-7 4.5BT Cumminns Diesel still in building stage.
Dre40 is offline
post #213 of 677 Old 09-08-2013, 08:54 PM
WidowYj91
Subbed! Just so sick! Waiting on the write up so I can order mine!
WidowYj91 is offline
post #214 of 677 Old 09-08-2013, 09:26 PM Thread Starter
Gage56
Ok so as for the writeup ... Really its not rocket science if you can use a soldering iron you good to go
Tools Needed
Solder and Soldering Iron 15-25 watt
Tape
Shrink tube
a few spade and ring connecters
Glue
16-20gauge wire
toggle switch
Ill start with the rock lights
Since they are "water proof" there is a bead of silicone over the whole roll of led's
they can be cut to any size you need by cutting after every 3 led's like so
i put a strip under each wheel and one on each side of the tub on the floor board's, they do come with 3M 2sided tape on them but its just not good enough for being "Exposed" so i also put a bead of body panel glue to hold them.
If you look close you can see the silicone and where i had to peel and cut it to get to the copper leads you will have to do this everytime you cut into strips
Step one, Measure and Cut all your strips and prep for soldering
Step two, tint all your leads and wires DON'T Try using plumbing solder use stuff like this
Step Three, attach you wires to the leads
Step Four, Attach to the location you want them
Step Five, run wires to the switch and hook to a 12v + and i just grounded all of then to the tub, ill have to get pic's of the tomorrow
Step Six, Enjoy
Real Simple Guy's
1992 YJ
Gage56 is offline
post #215 of 677 Old 09-09-2013, 10:46 AM
kgb_m3
Wow Gage, those lights are so freaking bad ***!! I just ordered myself.. Been a few years since I did any LED stuff, seems like prices have come down quite a bit.. Looks great as usual, hope you don't mind me copying your idea
89 YJ 4.2L
96 XJ 4.0L
http://www.jeepsunclassified.com
kgb_m3 is offline
post #216 of 677 Old 09-09-2013, 11:55 AM Thread Starter
Gage56
Thanks Man
And not at all i just wanted to make sure they would work the way i wanted before posting about it
1992 YJ
Gage56 is offline
post #217 of 677 Old 09-11-2013, 09:46 PM
AZdEvilYJ
Nice write up man. I like your soldering technique on coating everything first. I just twist, bend and solder.
'95 YJ 2.5L
March '15 YJ of the Month!
Exiled Offroad - Arizona
My Build Thread
AZdEvilYJ is offline
post #218 of 677 Old 09-12-2013, 05:18 AM
grandboost98
That looks great and nice write up too! I may have to copy this one
The only thing I could see being a problem is the strip in the rear wheel well. If you stuff that tire off road, you might rip those out
04 Grand Cherokee Overland
72 Chevy Nova-in progress
grandboost98 is offline
post #219 of 677 Old 09-12-2013, 05:46 AM Thread Starter
Gage56
Thanks
I thought the same thing so i tested it and it ends up the tires hit the rear of the tub first and don't get that high as seen here
I Guess it would help a little if i had bump stops on
1992 YJ
Gage56 is offline
post #220 of 677 Old 09-12-2013, 06:53 AM
ashland82391
Originally Posted by Gage56 View Post
Thanks
Braking stuff already lol
ashland82391 is offline
post #221 of 677 Old 09-12-2013, 08:51 AM Thread Starter
Gage56
LOL i did that on my first trip wheeling after the rebuild
1992 YJ
Gage56 is offline
post #222 of 677 Old 09-12-2013, 02:33 PM Thread Starter
Gage56
This Happened today any clue as to why i only have a little bit of power going to the middle pin of the fuel pump harness ??? i check the relay, its fine and all the fuses are good
1992 YJ
Gage56 is offline
post #223 of 677 Old 09-12-2013, 02:54 PM
AZdEvilYJ
A wire may be broken/breaking?
'95 YJ 2.5L
My Build Thread
post #224 of 677 Old 09-12-2013, 03:39 PM Thread Starter
Gage56
Ok so lets see,
the other day i went to take the jeep to the store.... No start, fiddled around a bit and changed out the fuel pump relay, pump kicked on and started up
This morning go to start the jeep No pump running Hmm well ill change the relay again yup pump kicked on and started right up. Drove it about 5miles stopped at the store came out started back up, drove another 2-3miles stopped at the ins company came out started the jeep and it stumbled and sputtered and then died WTF cycled the key No pump again , changed the relay and still nothing.
So at this point i thought fuel pump was bad, had it towed home and i started looking over things and found i have power to the relay, the relay is good ,and all the fuses are good.... But when the key is on i only have 7volts to the middle pin on the pump harness cranking i get 6 volts . Really stumped here guy's any help would be Great
1992 YJ
Gage56 is offline
post #225 of 677 Old 09-12-2013, 03:57 PM
Ken3783
Any voltage drops in the system would be caused by high resistance on the line, aka bad or loose connections or pins, bad splices along the run, corrosion in terminal lugs or pins. If you can get a meter set it to ohms and check for resistance along the line from the fuse to the pin on the pump. If your meter leads aren't long enough to do that, get a wire and ground that pin out to the chassis and put the meter lead in the fuse slot going back to the pump and ground the black lead to the chassis as well and check for resistance. Either method will work. While I don't have the schematic in front of me, I am an electrician. Just ensure power is off and look at the schematic to ensure the wiring from the pump to the fuse is properly isolated, meaning that wire doesn't T off anywhere else otherwise you'll get faulty resistance readings. If you do get a high resistance then check for bad splices and loose pin connections and clean all corrosion you find on the run. I hope that helps.
'95 Wrangler YJ:
'98 Cherokee XJ:
'07 Grand Cherokee WK ("No Mods"-The Wife)
Ken3783 is offline
