#1 | |
My Monster
See link and description 2 posts below.
#2 |
you don't have the whole link i don't think...it isn't working
2002 TJ Blk, 4.0, 5spd, dual top/doors, Dana 30/44, 6", 35's, 4.88s, locked f/r, air, KC lights, CB, PSC rockers/cage/corners, m8000, flat fenders, custom front bumper, TXT rear 2003 F350 diesel....tow rig [COLOR=blue]NEJEEPZ[/COLOR] [URL=http://community.webshots.com/user/2k2blktj]My Jeep[/URL] |
#3 | |
this is the engine http://www.imagestation.com/mypictures/inbox/view.html?id=4190318484&url=http%3A%2F%2Fwww.imagestation.com%2Fpicture%2F sraid102%2Fp09dbbc7690600d421d1e4a5e95e12bf6%2Ff9c 32f94.jpg&caption=monster%20*****%20engine front view http://www.imagestation.com/mypictures/inbox/view.html?id=4190318486&url=http%3A%2F%2Fwww.imagestation.com%2Fpicture%2F sraid102%2Fp2a862f4b6d77d2d5b6ba0f9f56881301%2Ff9c 32f96.jpg&caption=monster%20*****%20lights side angle http://www.imagestation.com/mypictures/inbox/view.html?id=4190318492&url=http%3A%2F%2Fwww.imagestation.com%2Fpicture%2F sraid102%2Fpcb8c2188271318551cbe9fb06af49e60%2Ff9c 32f9c.jpg&caption=monster%20*****%20angle |
#4 |
Jeep Jedi Master
How do you like the Lund scoops? I've been running through that idea for quite awhile.
Hunter
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns and 33 Bridgestone Duelers Detroit and true trac Red Jeep Club Member REDNECK JCM Texas Jeep Owner #6 USN Jeep Club #4 http://www.kevinsoffroad.com/ 602.841.3355 For your performance needs: kolak@kolakperformance.com 480.998.3661 |
#5 | |
Mad Mike |
#6 |
how did you make them functional....aren't they just stuck on to the hood????
#7 | |
Bucket, I cut out the front end of them and put a mesh wiring there. Then I cut out 2 holes on each side of my hood right over the blue cone filters that you see in the pics. So I have heat shields under the cones and fresh air coming from the outside via "RAM AIR". On the 1998 Grand Cherokee 5.9 Hood on the underside there is a triangle pattern in the hood support bracket (located directly over each intake filter), I cut the hole out right in there so as not to compromise the structural integerity of the hood. You can, however, get a bracket that prevents hood warp if that isnt the case for you. And remember, engines run on 14 part air and 1 part fuel. The more air you get into the engine the more power and efficiency you get (depending on how you use the engine) within the limits set by the engine of course. Mad Mike |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
