My Magnum TJ, project "Whoops my stroker wiped it's cam bearings" - Page 3 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > My Magnum TJ, project "Whoops my stroker wiped it's cam bearings"
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 05-06-2013, 07:45 PM   #31
CobraMarty
That's GREAT!! So what was the final gremlin?
1998 XJ 2D auto 4.0 160k Red Grey+Blk Si seats 32" MTR 4.5" RC Lift- full leaf Adj U+L Arm RE track bar JKS Disco SYE F+R Hitch SOLID Covers JCR Slider+Skid Plate Magnaflow TruckLites, 150rwHP/174rwTQ=>Sprintex S/C 6 lbs BOOST 7th Injector NO CEL'S 211rwhp/274rwtq 100-140* IAT's==>Now 12 lb BOOST! JeepM62superchargerkit.blogspot.com
CobraMarty is offline   Reply With Quote Quick reply to this message
Unread 05-06-2013, 09:00 PM   #32
doublins
doublins's Avatar
That's actually the jeep PCM with Durango PCM firmware flashed onto it via my SCT
98 TJ Street Sleeper- 408ci Stroked Magnum V8
My Magnum V8 Build Thread:
http://www.jeepforum.com/forum/f22/m...rings-1516649/
doublins is offline   Reply With Quote Quick reply to this message
Unread 05-07-2013, 06:05 AM   #33
CobraMarty
SCT- was that with ryan's help? How did you do that?
Unread 05-07-2013, 06:24 AM   #34
doublins
doublins's Avatar
Yeah, Ryan's been working with me on this- there's still a lot of kinks to work out- I've got a ton of codes in the ECU, some expected, like evap & auto tranny, but a couple unexpected like p0207 & p0208, injector circuit failure codes for #7 & #8, even though the injectors seem to be working fine. I'll have to hook an o-scope up to them and see what they're actually doing compared to 1-6. It could be a hardware or software issue- we're looking into it, but the point is that the thing is running right now, and that makes me super stoked!
Unread 05-07-2013, 06:31 AM   #35
doublins
doublins's Avatar
So, since I got it running, and since open headers are LOUD and a fire hazard, hehe... I decided to get started ASAP on my exhaust while I wait for my radiator to arrive.
I'm doing a stainless Y-pipe after the collectors, 2x 2.25" into 1x 2.5", the mating up with my existing 2.5" system at the skid plate.
Started routing the 2.25" pipes off of the header flanges...
And wound up with this thing tacked together a couple of hours later.
I've got to weld some o2 bungs into it and test fit the whole system before burning everything in, but so far so good!
Unread 05-07-2013, 04:22 PM   #36
CobraMarty
Minor details is all, which I am sure you will solve. Congrats on a great engine swap, far better than any SBC, etc. Keep'in it in the Family- Jeep-Dodge-Chrysler.
Unread 05-08-2013, 07:33 AM   #37
doublins
doublins's Avatar
Thanks!
I finished up the exhaust system last night, my radiator should be here on friday, I figure by saturday it'll be roadworthy.
Unread 05-08-2013, 08:24 AM   #38
jpin86
When you did your wiring harness, did you remove the pins from the connectors and reposition them where they needed to be, or cut and splice the wires?
jpin86 is offline   Reply With Quote Quick reply to this message
Unread 05-08-2013, 10:14 AM   #39
doublins
doublins's Avatar
Snip, strip, solder, heatshrink. I did it for lots and lots of wires because i wanted to get the wire length to the connector correct as well. Proper splicing/crimping with solder applied is a pretty bombproof connection.
Unread 05-09-2013, 04:47 PM   #40
doublins
doublins's Avatar
Just finished up my exhaust- sounds GOOD!! And hooked up the Ram PCM and my Evap system = no CELs!
Last edited by doublins; 05-10-2013 at 05:51 AM.. Reason: Fixed video link... whoops
Unread 05-10-2013, 04:25 AM   #41
jpin86
Awesome. Great job!
Unread 05-10-2013, 06:02 AM   #42
doublins
doublins's Avatar
Awesome. Great job!
Thanks!
Radiator should be here today- I am so stoked to drive this thing finally, rather than just look at it.
Unread 05-10-2013, 06:58 AM   #43
jpin86
I am sure you will be a lot happier with a V8 than the stroker. I built a stroker for my last Jeep. It ran good, but I thought it would have more power. Maybe a computer tune would have made a difference.
I have a 5.9 on a stand that will be going my next project, so I may have to pick your brain when I start my swap.
Unread 05-10-2013, 07:39 AM   #44
jeep50
Amazing job!
jeep50 is offline   Reply With Quote Quick reply to this message
Unread 05-10-2013, 08:10 AM   #45
doublins
doublins's Avatar
Yeah, I was seriously underwhelmed with my stroker- it made "more" power than the stock 4.0, and I had a usable 5th gear on highway hills, but it wasn't anything really special- even with the roller rockers, aftermarket cam, headwork, headers, 2.5" exhaust, etc.
Once Ryan (FlyinRyan on jeepstrokers) tuned it, my low-mid range torque was very improved, and it's operation became smooth as silk, but I was still turning high 7 second 0-60s with the thing.
Maybe I'm spoiled by motorcycles and fast cars, and to others the stroker would have seemed nicer, but to me, the jeep was always just a big pig, and with the stroker, was merely a not-as-slow-and-piggish pig as the stock 4.0. I don't even want to know what driving a 2.5 is like... I can't even imagine!
So, even with the 5.2, I'm not expecting a race car or anything, but I am expecting it to feel like an improvement over the stroker, which was just a big expensive disappointment. I'd never again recommend that route to anyone- the ONLY reason I went that route was the "plug and play" nature of removing my 4.0, building it, then just popping it right back in. V8 swaps were mysterious, seemed like they'd require some sort of special knowledge or skill set that I didn't possess, and the overall thought of them seemed overwhelming.
That being said, now that I've gone through the exercise- the entire thing took me about a month all by myself, using only my brain, hands, and the knowledge readily available on the internet. I would now definitely recommend a V8 swap over a stroker to nearly anyone that has general basic mechanical, fabrication, and electrical skills- if you can wire a stereo, swap an axle, and do a hi-line fender mod, you possess the skills necessary to complete a V8 swap. Oh, and learn how to weld. I used my welder extensively during this swap, mostly for the mounts, shifter modification, and the exhaust.
