My little YJ - JeepForum.com
post #1 of 157 Old 11-12-2010, 07:41 PM Thread Starter
nibstools
My little YJ
I bought this stock YJ in December 2009. Been slowly building it up. Still lots to do but very happy with the progress so far.
nibstools is offline
post #2 of 157 Old 11-12-2010, 07:49 PM Thread Starter
nibstools
First thing I did was buy some BFG at 30x9.5 but they were not around for long. I also installed 2 inch shackles. Also while the 30's were still on I installed a Rough country 4" lift. looked pretty goofy with 6" of lift and 30" tires! Oh yeah Tube fenders too.
freshly lifted jeep.jpg   Whole lift installed rear.JPG   first fit up.jpg   Passenger fender installed.jpg
post #3 of 157 Old 11-12-2010, 07:56 PM Thread Starter
nibstools
Had alot of vibes with that much lift so bought an SYE and double cardan driveshaft, much better! Found an almost brand new set of 33x9.50 bfg at's on cl for 200 bucks. So bye bye 30's! trimmed off the ends of the front bumper so it would not get in the way! Added d ring mounts front and rear too.
post #4 of 157 Old 11-12-2010, 07:58 PM Thread Starter
nibstools
installed a new smittybilt soft top. the old one was wipped!
post #5 of 157 Old 11-12-2010, 08:03 PM Thread Starter
nibstools
installed aussie lockers front and rear! What a difference. New u joints in fronst shafts too. Installed heavy duty front diff cover.
Aussie installed in carrier.jpg   carrier back in axle.jpg   old U joint bearing cups driver1.jpg   new%20diff%20cover.jpg   aussie locker.jpg
post #6 of 157 Old 11-12-2010, 08:06 PM
onelow1ton
1983 FSJ Wagoneer
looks good so far keep it up
NEW BUILD 1983 wagoneer bagged and bodydropped Click here for build -->
onelow1ton is offline
post #7 of 157 Old 11-12-2010, 08:06 PM Thread Starter
nibstools
Lots left to show, Installed discos. extended bumpstops. Winch (recon 10,500)
discos.jpg   Photo0473.jpg   new%20cnyjeep%20fairlead.jpg   Photo0474.jpg   front%20bumpstop.jpg
post #8 of 157 Old 11-12-2010, 08:09 PM Thread Starter
nibstools
Installed sliders, also picked up a set of 34x9.50 swampers on CL.
post #9 of 157 Old 11-12-2010, 08:13 PM Thread Starter
nibstools
The swampers were pretty beat but did some magic wit ha woodworking router. Now they gots tons of tread.
post #10 of 157 Old 11-12-2010, 08:19 PM Thread Starter
nibstools
few more swamper photos
post #11 of 157 Old 11-12-2010, 08:23 PM Thread Starter
nibstools
The whole time I was doing all this other stuff, I have been stripping the frame of rust and coating with bedliner. Used a needle gun and it made the work go pretty quick.
kbs on frame2.jpg   kbs on frame.jpg   not rusty skidplate.jpg   swaybar.jpg   rusty skidplate.jpg
post #12 of 157 Old 11-12-2010, 08:28 PM Thread Starter
nibstools
the wheels my bfg at's are on were very corroded, I stripped them and polished them. Turned out real nice! got new AR centercaps too.
uncleaned wheel1.jpg   uncleaned wheel2.jpg   cleaned wheel1.jpg   cleaned wheel2.jpg   center caps.jpg
post #13 of 157 Old 11-12-2010, 08:34 PM Thread Starter
nibstools
Along the way of course, did front and rear brakes, wheel bearings.
I did a shackle reversal on it, then this made the front driveshafts slip joint too short. So I had a custom made shaft with a 6" slip joint made up.
post #14 of 157 Old 11-12-2010, 08:37 PM Thread Starter
nibstools
Probably missed alot, but that seems like most of it for now. I have ordered Chromoly axles for the rear and a HD diff cover. Already have a truss to weld on to the rear axle as well. as soon as I have pics I'll post them too!
post #15 of 157 Old 11-13-2010, 01:49 PM
jlevin
I'm in the process of doing the same thing, sort of, starting with a stock yj going to turn it into a mean green car crushing machine. You definitely got some good deals on cl. Jeep looks awesome!
jlevin is offline
