MY lil 2.4 TJ Build - Page 5 - JeepForum.com
post #61 of 178 Old 09-16-2013, 10:58 PM
officer_krupt
hey ....very nice rig...you are one very resoruceful @#$%...i mean that in a good way!im going to attempt to put jk headlights in my 97 tj...just wondering what bulb you used......the h4 or the h13/9003?
officer_krupt is offline
post #62 of 178 Old 09-16-2013, 11:36 PM
Jonathanjr1
Nice build! It's great to see another 2.4 out there being built up.
Jonathanjr1 is offline
post #63 of 178 Old 09-17-2013, 06:10 AM Thread Starter
TJRUSSELL
The bulbs came with the lamps, I forget what ones they are but they are the factory jk bulb. I got adapters off eBay to change the bulb type
My 2.4 turbo TJ-6 stretch build
http://www.jeepforum.com/forum/f22/my-lil-2-4-tj-build-1092494
TJRUSSELL is offline
post #64 of 178 Old 09-17-2013, 08:10 PM Thread Starter
TJRUSSELL
someone wants to go for a ride
post #65 of 178 Old 09-17-2013, 08:49 PM
95riograndeman
2015 JK Wrangler
That bumper is going to look great! Can't wait to see it.
2015 Jeep Wrangler Sport
SOLD: 1995 Jeep Wrangler
95riograndeman is offline
post #66 of 178 Old 01-20-2014, 04:05 PM Thread Starter
TJRUSSELL
Front bumper has been done, I'm currently working on the srt4 turbo
post #67 of 178 Old 01-20-2014, 10:06 PM
aw12345
Turbo setup that works with this engine now that I would be interested in
aw12345 is offline
post #68 of 178 Old 02-19-2014, 07:17 AM
ALS59LTD
ALS59LTD's Avatar
hi russell, how far have you gotten on your Turbo build? I'm going to partially copy Air Sierra's build. Got an adaptor plate made and have the injectors and a manifold/turbo from a PT cruiser. Waiting until I don't need the jeep for the snow then I'm going to lay it up in the garage for a couple of months and see if I can make it work. I'm going to have to seriously up my welding skills for the exhaust!
-Alex
http://www.jeepforum.com/forum/f22/turbocharged-2-4l-jeep-tj-me-too-2255329/
ALS59LTD is offline
post #69 of 178 Old 02-21-2014, 08:11 PM Thread Starter
TJRUSSELL
i got everything but the injectors, i've been working on my bathroom so i haven't been working on it. i got a u bend from summit racing a 3 to 2.5 reducer from advanced auto and i got plate steel for the flange that bolts to the manifold
post #70 of 178 Old 03-22-2014, 10:22 AM Thread Starter
TJRUSSELL
i cant wait for warmer weather so i can go to town on finishing my turbo install. the adapter plate is milled out and taped. this week i got the intercooler mounted inside the grill, radiator and fan assembly together. this morning i got the intake off and started on the factory exhaust and then it started snowing
post #71 of 178 Old 03-22-2014, 10:35 AM Thread Starter
TJRUSSELL
post #72 of 178 Old 03-22-2014, 06:43 PM Thread Starter
TJRUSSELL
srt4 parts list
-srt4 turbo/manifold -ebay
-intercooler -ebay cxracing
-intercooler pipe kit -ebay cxracing
-2.25 to 2.5 elbow -ebay
-coolant/oil lines diy td04 -ebay
-oil an fitting -5to-4 earls -ebay summit racing
-3''to2.5'' reducer -advance auto parts
-plate steel-exhaust flange -metal supermarket
-plate steel-manifold adapter -metal supermarket
-exhaust u-bend -ebay simmit racing
-steel rod & nuts -lowes
-o2 sensor bungs x2 -ebay
-bulk tube vac, heater, oil drain -advance auto
-m8 allen bolts -lowes
-exhaust gasket -advance auto
-exhaust manifold gasket -advance auto
-vac tee
-p/s cooler
-td04lr rebuild kit
-td04lr exhaust turbine
-3/8" brass nipple, tee, reducer to 1/8(oil)- Lowe's
-barbed 1/2 tee-Lowe's
-exhaust wrap-ebay
-coolant bottle-eBay
- ford fuel injectors-ebay
post #73 of 178 Old 03-23-2014, 08:49 AM Thread Starter
TJRUSSELL
http://forums.neons.org/viewtopic.php?f=131&t=294297
good info on lines and fittings
post #74 of 178 Old 03-25-2014, 11:08 AM
ALS59LTD
ALS59LTD's Avatar
Wow the fit on that intercooler looks great! I went with an air/water but seeing this makes me wonder... ahh too late.... I just found that my adaptor plate is a little off so I have some fun ahead to see if I can modify it a bit or ask my coworker to make me up another one. Did you make the adaptor yourself or send out to a shop?
Post more pics!!
-Alex
ALS59LTD is offline
post #75 of 178 Old 03-25-2014, 03:16 PM Thread Starter
TJRUSSELL
I made the plate myself, but I had a guy at a local hot rod shop mill out the exhaust ports. I just mounted it up today and the 2 lower inner bolt holes are a little low, ill be die grinding those a little higher.
99' MJ Build woodkrawler Jeep Builds 1176 09-18-2013 06:21 PM
My WJ Build 02WJmccormick Jeep Builds 2 09-27-2009 09:25 PM
