My Jeep Wrangler truck build - Page 5 - JeepForum.com
 1Likes
post #61 of 296 Old 01-24-2013, 12:57 AM
LKrux
nice work. any updates? i also love how wrangler trucks look. sweet build.
4.0, 5sp, bfg33's, 3 1/2 lift
LKrux is offline
post #62 of 296 Old 01-24-2013, 05:02 AM Thread Starter
jpin86
I haven't had much time to work on it. I've been dealing with my Dad, who has dementia, and had to put him in a nursing home. We are on our 3rd nursing home, trying to find him good care. It's a shame that the elderly are treated as throw away human beings. OK, let me step off this soap box...
Back to the truck build...I'm not happy with the omix ada rear corners. Both corners need to be sectioned down. The tailgate hits the corners because the opening is too small. The corners should be 11 1/2 inch from the side of the jeep to the tailgate opening (measured off my TJ, using a square). The omix corners are 11 7/8 and 11 3/4. I need to cut these down or buy different corners. I have a long weekend coming up, and hope to get some Jeep time.
jpin86 is offline
post #63 of 296 Old 02-09-2013, 06:08 PM Thread Starter
jpin86
I got both corners sectioned down. The tailgate now fits between the corners. Now I have to grind down the welds. I hate grinding welds!
I am also trying to figure out a tailgate handle and latch system. With a tailgate only 1 inch thick, there aren't many options.
jpin86 is offline
post #64 of 296 Old 02-09-2013, 06:50 PM
kyle_craig
Pretty dang cool. Looking forward to seeing more of this.
kyle_craig is offline
post #65 of 296 Old 02-10-2013, 07:43 PM
G Beasley
Awesome metal work , keep up the good work.
G Beasley is offline
post #66 of 296 Old 03-27-2013, 01:26 PM Thread Starter
jpin86
I figured out my tailgate latches. I put the bearclaw latches on the tub. The latch bolts will be on the tailgate where the tailgate cables used to be. I had to build new tailgate brackets for the pins.
I will actuate the bearclaw latches with either solenoids or actuators. Anyone have any experience or can offer an opinion on which is better, actuators or solenoids?
I mocked up a Cadillac trunk actuator, but it didn't have enough umph to open the latches.
jpin86 is offline
post #67 of 296 Old 03-27-2013, 01:32 PM Thread Starter
jpin86
With the latches set up this way, I can still use a rubber tailgate seal. I plan on having a cloth tonneau cover made to keep the inside of the bed dry.
jpin86 is offline
post #68 of 296 Old 03-28-2013, 03:36 PM Thread Starter
jpin86
I just ordered a set of actuators for the bearclaw latches from ball's rods and Kustoms. Hopefully they will work.
http://www.ballsrodandkustom.com/ind...ct_detail&p=48
I am going to run a TJ licence plate holder. I'm thinking about putting the switch to active the latches on the bottom of the TJ plate holder.
jpin86 is offline
post #69 of 296 Old 04-01-2013, 10:41 PM Thread Starter
jpin86
I got the latch and pins installed. It worked out good. I have to finish welding the brackets. The tailgate cables will be mounted on the bottom of the latch pin brackets. After that I'll shape the brackets so there not so square looking.
jpin86 is offline
post #70 of 296 Old 04-01-2013, 10:47 PM Thread Starter
jpin86
The actuators will be mounted directly to the latches. I hope these will be strong enough. With the tailgate seal in, the latches are harder to unlatch. I may end up getting some stronger door pop solenoids.
jpin86 is offline
post #71 of 296 Old 04-01-2013, 10:56 PM Thread Starter
jpin86
One more option I am thinking about for the tailgate latches is to put a tailgate handle below the tailgate in the square tube that the tailgate hinges are bolted to. I would have to run cables and a single pulley from the handle to the latches.
jpin86 is offline
post #72 of 296 Old 04-09-2013, 08:34 PM Thread Starter
jpin86
I got the door lock actuators mounted to the tailgate bear claw latches. The actuators are not strong enough to open the latches when I have the tailgate seal installed. So now it's a set of strong solenoids (65 lbs), or a tailgate handle in the square tube below the tailgate.
jpin86 is offline
post #73 of 296 Old 04-11-2013, 08:48 AM
Hendrix
TJOTY 2013
Hendrix's Avatar
Looks great, when do you think it will be ready to put on your frame?
K.C.C.O.
Carpe Diem
Hendrix is offline
post #74 of 296 Old 04-11-2013, 12:20 PM
mulehead2
1981 CJ7
This is sharp. I'm ready to see what it's gone look like over some wheels and tires
mulehead2 is offline
post #75 of 296 Old 04-11-2013, 04:17 PM Thread Starter
jpin86
Because I'm working a lot of overtime and taking care of family stuff, it's taking me a lot longer than I thought it was going to take. I'm lucky if I get 2 hours a week to work on it. I have toyed with the idea of selling the bed. If its taking me this long to build just the bed, I don't how long it's going to take to build a whole Jeep.
Once I figure out how I'm going to actuate the latches (electrically or manually) I can get the corners welded and attached to the bed. I won't finish the floor until I get the bed mounts built and welded in.
jpin86 is offline
2000 jeep wrangler build mynameislarry Jeep Builds 274 10-15-2012 03:36 PM
Third Jeep Build (98 Wrangler) 98TJ162 Jeep Builds 61 06-16-2012 10:51 AM
97 jeep wrangler build trx450r1989 Jeep Builds 42 03-21-2012 05:33 AM
99' Jeep Wrangler Build Alexwest14 Jeep Builds 4 01-26-2012 09:01 AM
1998 Jeep Wrangler Build Kittie Jeep Builds 35 10-18-2010 12:31 PM
