My Jeep Wrangler truck build - JeepForum.com
 1Likes
post #1 of 272 Old 01-19-2012, 05:52 PM Thread Starter
jpin86
Ever since the Jeep brute came out, I've wanted one. Maybe some day I will own one...when I can cough up $10,000.00 for the kit. I love the way it looks with the hard top. The one thing I don't like about the Brute is how it looks with the top off. So I've decided to build my own bed. A jeep is flat sheet metal, so it can't be that hard...right?
I though about using scrambler sheet metal to build the bed. Everything can be bought new (sides, floor, wheel houses, corners ect.). The only part that would have to be fabricated would be the front part of the bed.
To save cost and to have fun manufacturing the bed myself, Ive decided to build a bed out of 16 gauge sheet metal.
I came up with some drawings and went to a local sheet metal shop. For two 4x8 sheets of 16 gauge cold rolled and labor to bend the sides cost $360.00 (I kept all the extra sheet metal).
jpin86 is offline
post #2 of 272 Old 01-19-2012, 06:06 PM Thread Starter
jpin86
I am using 16 gauge CJ-7 corners for the bed corners. I had to weld the little lip on the side of the corners to match the bed sides. I will use a little body filler to transition from the bed sides to the tailgate.
jpin86 is offline
post #3 of 272 Old 01-19-2012, 06:13 PM
Irongrave
very cool
Current
2002 WJ 2wd DD
Irongrave is offline
post #4 of 272 Old 01-19-2012, 06:23 PM Thread Starter
jpin86
The inner fenders are trailer fenders. They are 12 inches wide, and take up alot of bed space. They had to be that wide to get the center of the bed between the frame rails of a Jeep. The frame rails come up high to mount the coil springs. I could have used narrower inner fenders to get more room inside the bed, but then I would have to run a body lift, and I'm not real wild about body lifts. It may only take an inch or two to clear the frame rails... I don't know I don't have a donner Jeep yet. I can't cut up my daily driver 2003 wrangler.
I used copper weld primer between the lap joints for rust protection. I will seam seal all joints before I paint the bed.
jpin86 is offline
post #5 of 272 Old 01-19-2012, 06:31 PM Thread Starter
jpin86
The bed frame is made from 14 gauge 1 inch sqaure tubing with 1x2x.120 rectangle cross supports. I'll be using either 1/8 or 3/16 diamond plate aluminum for the bed floor. I'll probably attach it with automotive structural glue.
The bed sides will be the same hight as the back of the cab.
jpin86 is offline
post #6 of 272 Old 01-19-2012, 06:34 PM
93jeepyj
Thats way cool man, What kind of top are you planning to run?
93jeepyj is offline
post #7 of 272 Old 01-19-2012, 06:40 PM Thread Starter
jpin86
I'll be running a soft top. I am thinking about using a bowless top cut down to fit the cab. And I'll probably use the brute cab closeout. It looks like it is made really good and easy to install.
jpin86 is offline
post #8 of 272 Old 01-19-2012, 06:43 PM Thread Starter
jpin86
I'm not sure if I am going to use a CJ_7 tailgate or make my own. If I make my own tailgate I'll make it wider.
jpin86 is offline
post #9 of 272 Old 01-19-2012, 06:48 PM Thread Starter
jpin86
Right now I have $360.00 in bed sides and extra sheet metal, $50.00 each for the custom made wheel houses, around $40.00 each for the corners and under $100.00 for the frame tubing. I should be able to build this bed for under $1000.00.
jpin86 is offline
post #10 of 272 Old 01-21-2012, 02:05 PM Thread Starter
jpin86
I started on the front of the bed today. It will wrap around the back of the cab.
jpin86 is offline
post #11 of 272 Old 01-24-2012, 08:54 AM
jeepers92
Hey Dave, lookin good. Are you going to find an old TJ to modify for this or convert old grey? Let me know if I can help anyway.
Boyd
jeepers92 is offline
post #12 of 272 Old 01-24-2012, 10:10 AM Thread Starter
jpin86
Probably buy a 2000 TJ. That year had the nv3550 trans and CCD information bus that I will need for the 360 engine swap. I can't find a manual trans, 360, ECU with a PCI data bus. I don't think Chrysler ever made one. Plus I need something to drive while I'm building the truck.
jpin86 is offline
post #13 of 272 Old 01-24-2012, 10:12 AM
KillZone47
This is awesome! Great work!
KillZone47 is offline
post #14 of 272 Old 01-24-2012, 10:18 AM Thread Starter
jpin86
Thanks. It will be a slow build, but I'll post pics along the way.
jpin86 is offline
post #15 of 272 Old 02-02-2012, 07:47 PM Thread Starter
jpin86
I had a few hours today to get some work done. I made a slight change to the front of the bed. I had the cab recess set to far into the bed. I made a template from the back of my TJ. I had to move the front of the bed forward. I now will have a 1 inch gap between the bed and cab. The red line drawn on the top of the bed will be where the top of the bed folds over.
jpin86 is offline
2000 jeep wrangler build mynameislarry Jeep Builds 274 10-15-2012 03:36 PM
Third Jeep Build (98 Wrangler) 98TJ162 Jeep Builds 61 06-16-2012 10:51 AM
97 jeep wrangler build trx450r1989 Jeep Builds 42 03-21-2012 05:33 AM
99' Jeep Wrangler Build Alexwest14 Jeep Builds 4 01-26-2012 09:01 AM
1998 Jeep Wrangler Build Kittie Jeep Builds 35 10-18-2010 12:31 PM
