My homeade long arm build + other mods. - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > My homeade long arm build + other mods.
1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ Rancho rockGEAR promotion gear from January 1-February 29,Zone Offroad Body and Suspension Lift Kits, Brackets, Disc
Unread 10-08-2015, 07:20 PM   #1
daninjabreadman
Hey guys, starting this thread because my jeep is going to be going through some major mods soon. Right now im ordering parts to build a long arm kit (parts listed below). The current bushings on my pro comp short arms are shot so i figured now would be a good time to swap out the arms to adjustable long arms. Of course kits are $8-900 and i figured i can make one that better suits my needs for roughly half of that. I have pretty good welding experience as I work on field equipment most of the summer and my plans dont seem too complex as far as suspensions go. Chime in if you guys think im doing something wrong or should have something else added. I'll post up details of all the other mods I have done to it in the future along with progress on the whole build. Ill be buying the tubing from a local steel shop once I get the inserts and specs on length I want. Also this weekend I should be finishing up on my homemade rear bumper, pics to come.
Weld on bushings
http://www.4wheelparts.com/Suspensio...t_pn=R/ERE3765
J Joints
http://jksmfg.com/i-22118543-2-1-2-f...-625-ball.html
Tube Inserts
http://catalog.foothilloffroad.com/p...roducts_id=346
daninjabreadman is offline   Reply With Quote Quick reply to this message
Unread 10-10-2015, 07:30 PM   #2
daninjabreadman
Update. Today i did more work on the bumper i made. I got it sand blasted, primed, and the front painted in matte black. I also did some painting on the frame over some rust spots. Tomorrow ill paint the back in gloss black and mount it.
Unread 10-13-2015, 08:25 PM   #3
daninjabreadman
Jjoints and threaded inserts came today. Tomorrow i shall travel the county in search of 12' of 2"x.25 1.5"id DOM tubing. Online its about 14.50 a foot and ill hopefully be able to find it close to that near by. I hope to have this done by Sunday to bring it to a truck show. Also my finished bumper looks pretty good.
Unread 10-15-2015, 10:16 PM   #4
daninjabreadman
Found lower tubing for a decent price and bought 12' of it. Cut it into 3 foot sections and welded the bushings on one end. Next is to make an axle truss for the 4 link rear and some brackets for my radius arm front so im ready when those parts come in. Ill have to make another trip to the tube shop for the upper material, i probably have square tubing for the truss lying around though.
Unread 10-16-2015, 04:20 PM   #5
daninjabreadman
Tacked up the axle truss and made brackets for that and some for the front lca's. Still need to drill holes in some. The truss fits pretty good, but not quite level. I also installed the bushings in the lca's. Now im mostly waiting on my uca parts and joints to come in.
Unread 10-30-2015, 07:23 AM   #6
daninjabreadman
So i finished up the 4 link and it seems to drive better than before but its almost like there's play in my steering wheel and it lets the jeep wander around the road. Ill be checking my joints soon. Im also waiting to get an alignment until iv finished the front next weekend. Otherwise i think it might be the power steering. I also stripped out the nuts that hold the drag link collars on so i drilled out the square hole and put normal bolts in there, is there any issue with this im not seeing? They're as tight as i can get them with a wrench so they shouldn't come off.
Drag link fix.
Frame side bracket with upper attached.
Unread 11-13-2015, 03:36 PM   #7
daninjabreadman
I have about 400 miles on the rear 4 link and it seems to be working well. I'll be doing the long arm front this weekend and some other steering work. Will report back with pictures of the final project.
Unread 11-13-2015, 04:40 PM   #8
arbakken
2015 JK Wrangler
Looks good as far as I can tell, but I can't make much sense of the pictures. Any bigger perspective shots?
arbakken is online now   Reply With Quote Quick reply to this message
Unread 11-15-2015, 09:27 PM   #9
daninjabreadman
Yeah sorry. I'll post some higher quality pics later. I got the front radius arms done this weekend and words can't describe how much better this rides as far as bumps go. I just have to get some correct size bolts tomorrow and I'll be done. A seperate issue that I'm just noticing now is that the jeep leans to the passenger side. It's about a two inch difference and I'm not sure what could be the cause. My only guess would be that the procomp (?) Springs are sagging weird. Next on the list is to correct caster angle, check all the steering joints, and bring it in for an alignment. This will hopefully resolve my wandering steering.
Complete radius arm.
Crap procomp arms I replaced.
Unread 11-17-2015, 05:39 PM   #10
daninjabreadman
Took it in for an alignment today and they told me my ball joints are bad. So it looks like I'll be changing those this weekend. While I'm at it I'll make some gussets for the cs and weld those in so I can run 35s a bit more safely in the future. I'm also gonna remove the trackbar drop bracket and put a normal pitman arm back on to correct the angle.
Unread 11-22-2015, 08:57 PM   #11
daninjabreadman
Changed the ball joints today which was a pita. The master pro brand joints have a rubber boot that I couldn't remove so I ended up ripping both the bottom ones when I tried to press them in place. The problem was that the rubber piece covered the lip that the press was supposed to be up against so I had no choice but to push on the rubber. Afterwards I tried to seal the boots with rtv as best I could. I'll just replace them with another brand once they go bad. Other than that the u joints went well and the axle gussets are ugly but seem like they'll be strong enough for 35s. Once I had all that together I realised that when I bled the rear brakes earlier, I forgot that I had the front brakes disconnected. So naturally the piston went out so far on the drivers side caliper that it came out of the housing and I couldn't get it back in. So I ordered a refurbished caliper for cheap and it will be done once I put that in.
Axles gussets.
Unread 11-27-2015, 06:57 PM   #12
daninjabreadman
So apparently if you don't put the dust shields back in around the axles the rotor rubs on the steering knuckle... that was kind of annoying to find out that the tires didn't turn once I had everything back together. Apparently that 1/16 of material gives them enough space to not rub. Anyways. I got the new caliper on and the brakes need a bit more bleeding tomorrow. I also got to cutting out the track bar drop bracket and replaced the drop pitman arm with a stock one. Everything should be set to finally get that alignment. I also have a coolant leak somewhere that I need to find. It only leaks when it's below freezing and it leaks really bead when it's below 0. Which makes me think it has to be a rubber seal somwhere.
New stock one vs old drop pitman
Unread 12-01-2015, 05:26 PM   #13
daninjabreadman
Well it seems that my calipers are hitting the gussets at full turn and compressing the piston. This makes my brakes go soft and they hardly work until I pump the pedal. Looks like I'll grind a bit on the gussets and adjust the steering stops out a bit to stop this. A good tip to anyone reading this is to weld gussets more inside of the c rather than on the outside edges like I did.
Unread 12-02-2015, 06:34 PM   #14
daninjabreadman
Took some pics today. Enjoy
Also need longer brake lines before I can do a flex test
